Log of /Sprout/GenomeStats.pl
Mon Mar 2 22:25:08 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.35: +2 -0 lines
Diff to previous 1.35 , to selected 1.12
Made organism stats tables sortable.
CVS Tags: rast_rel_2009_02_05
Changes since 1.34: +9 -5 lines
Diff to previous 1.34 , to selected 1.12
ERDB 2.0 support
Sat Sep 20 14:31:22 2008 UTC (11 years ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.33: +5 -10 lines
Diff to previous 1.33 , to selected 1.12
Removed all the links from the statistics table: they all go to pages that no longer exist.
Tue Apr 29 20:50:13 2008 UTC (11 years, 5 months ago) by parrello
Diff to previous 1.32 , to selected 1.12
Sun Mar 23 16:10:47 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Diff to previous 1.31 , to selected 1.12
Diff to previous 1.30 , to selected 1.12
Removed obsolete use clauses.
Diff to previous 1.29 , to selected 1.12
Mon Aug 20 23:14:33 2007 UTC (12 years, 1 month ago) by parrello
Diff to previous 1.28 , to selected 1.12
Tue Apr 10 06:01:56 2007 UTC (12 years, 6 months ago) by parrello
Diff to previous 1.27 , to selected 1.12
Sun Oct 8 20:55:06 2006 UTC (13 years ago) by parrello
Diff to previous 1.26 , to selected 1.12
Fixed the comments.
Sun Oct 8 05:44:55 2006 UTC (13 years ago) by parrello
Diff to previous 1.25 , to selected 1.12
Fixed the evil "my my" bug.
Wed Oct 4 16:02:41 2006 UTC (13 years ago) by parrello
Diff to previous 1.24 , to selected 1.12
Tue Oct 3 02:48:59 2006 UTC (13 years ago) by parrello
Diff to previous 1.23 , to selected 1.12
Fixed default trace level.
Wed Sep 13 04:26:44 2006 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.22 , to selected 1.12
Wed Sep 6 19:28:47 2006 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.21 , to selected 1.12
Sun Aug 27 00:05:04 2006 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.20 , to selected 1.12
Thu Aug 24 18:13:50 2006 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.19 , to selected 1.12
Thu Aug 24 17:29:45 2006 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.18 , to selected 1.12
Added a subsystem button.
Thu Aug 10 07:34:13 2006 UTC (13 years, 2 months ago) by parrello
Diff to previous 1.17 , to selected 1.12
Thu Jul 13 07:08:42 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.16 , to selected 1.12
Tue Jun 27 16:44:18 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.15 , to selected 1.12
Fixed a comment.
Fri Jun 23 23:12:43 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.14 , to selected 1.12
Fri Jun 23 23:09:04 2006 UTC (13 years, 3 months ago) by parrello
Diff to previous 1.13 , to selected 1.12
Fixed file names used.
Sun Jun 18 10:07:00 2006 UTC (13 years, 3 months ago) by parrello
Revision 1.12 - (view) (download) (as text) (annotate) - [selected]
Sun Jun 18 10:03:38 2006 UTC (13 years, 3 months ago) by parrello
Sun Jun 18 08:55:16 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.10 , to selected 1.12
Sun Jun 18 08:52:31 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.9 , to selected 1.12
Sun Jun 18 08:10:42 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.8 , to selected 1.12
Sun Jun 18 07:53:45 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.7 , to selected 1.12
Sun Jun 18 07:39:38 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.6 , to selected 1.12
Sun Jun 18 07:33:37 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.5 , to selected 1.12
Sun Jun 18 07:16:57 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.4 , to selected 1.12
Sun Jun 18 07:12:58 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.3 , to selected 1.12
Sun Jun 18 07:01:33 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.2 , to selected 1.12
Sun Jun 18 07:00:00 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.1 , to selected 1.12
Sun Jun 18 05:37:14 2006 UTC (13 years, 4 months ago) by parrello
Diff to selected 1.12
