[Bio] / Sprout / GenomeSproutLoader.pm Repository:
Log of /Sprout/GenomeSproutLoader.pm
Mon Mar 16 00:15:39 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.3: +44 -9 lines
Added support for representative genomes and more robust group assignment.
Mon Mar 2 22:24:42 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.2: +3 -2 lines
Added contig lengths.
Mon Jan 19 21:46:21 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.1: +72 -21 lines
ERDB 2.0 support
Thu Oct 9 18:16:26 2008 UTC (11 years, 3 months ago) by parrello
New Sprout loaders.
