[Bio] / Sprout / GenomeSaplingLoader.pm Repository:
Log of /Sprout/GenomeSaplingLoader.pm
Thu Oct 14 17:27:37 2010 UTC (9 years, 7 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Diff to previous 1.11 , to selected 1.8
Changes for expression vector support.
Mon Oct 11 16:22:43 2010 UTC (9 years, 7 months ago) by parrello
Changes since 1.10: +2 -0 lines
Diff to previous 1.10 , to selected 1.8
Numerous load fixes.
Wed Apr 28 14:04:49 2010 UTC (10 years, 1 month ago) by parrello
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.9: +27 -4 lines
misc load fixes
Thu Mar 25 16:20:40 2010 UTC (10 years, 2 months ago) by parrello
Changes since 1.8: +2 -2 lines
Misc load fixes.
Wed Dec 16 01:45:19 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.7: +12 -2 lines
Sapling v08 changes.
Wed Nov 25 22:01:03 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.6: +21 -18 lines
Fixed to skip obsolete genomes in the genome-set processing.
Wed Nov 25 20:38:13 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.5: +10 -20 lines
Changed to preserve genome set IDs.
Wed Sep 9 16:30:22 2009 UTC (10 years, 8 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Added "domain" to Genome record.
Wed Aug 19 17:08:32 2009 UTC (10 years, 9 months ago) by parrello
Changes since 1.3: +8 -3 lines
General fixes to make the load smoother.
Tue Jun 30 19:53:01 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Mon Mar 2 22:24:06 2009 UTC (11 years, 3 months ago) by parrello
Changes since 1.1: +248 -59 lines
Converted to use NCBI taxonomy dumps. Added genome sets.
Mon Jan 19 21:43:27 2009 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Diff to selected 1.8
Sapling support.
