[Bio] / Sprout / GeneFile.pl Repository:
Log of /Sprout/GeneFile.pl
Tue Feb 5 05:47:32 2008 UTC (12 years ago) by parrello
Changes since 1.3: +0 -2 lines
Removed obsolete use clauses.
Tue Oct 3 02:48:59 2006 UTC (13 years, 4 months ago) by parrello
Fixed default trace level.
Wed Aug 30 15:01:59 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.1: +13 -9 lines
Changed to specify genomes to include rather than genomes to exclude.
Sat Jul 15 07:31:38 2006 UTC (13 years, 7 months ago) by parrello
Diff to selected 1.2
Added to permit creation of a gene file.
