[Bio] / Sprout / FigConfigFix.pl Repository:
Log of /Sprout/FigConfigFix.pl
Wed Oct 15 11:42:47 2008 UTC (11 years, 1 month ago) by parrello
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +0 -4 lines
Removed obsolete typing code.
Tue Sep 16 18:53:47 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.3: +30 -52 lines
Revamped to fit the new NMPDR procedures.
Thu Feb 14 19:05:35 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +6 -0 lines
Fixed to properly update the url_base configuration items.
Tue Feb 5 04:59:51 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.1: +6 -6 lines
Upgraded to a new interface for the config-file modify methods.
Mon Nov 5 21:28:30 2007 UTC (12 years ago) by parrello
Diff to selected 1.2
New script to simplify NMPDR updates.
