[Bio] / Sprout / FigConfigFix.pl Repository:
Log of /Sprout/FigConfigFix.pl
Thu Feb 14 19:05:35 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +6 -0 lines
Fixed to properly update the url_base configuration items.
Tue Feb 5 04:59:51 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.1: +6 -6 lines
Upgraded to a new interface for the config-file modify methods.
Mon Nov 5 21:28:30 2007 UTC (12 years ago) by parrello
New script to simplify NMPDR updates.
