[Bio] / Sprout / FigConfigFix.pl Repository:
Log of /Sprout/FigConfigFix.pl
Tue Sep 16 18:53:47 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.3: +30 -52 lines
Revamped to fit the new NMPDR procedures.
Thu Feb 14 19:05:35 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +6 -0 lines
Fixed to properly update the url_base configuration items.
Tue Feb 5 04:59:51 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.1: +6 -6 lines
Upgraded to a new interface for the config-file modify methods.
Mon Nov 5 21:28:30 2007 UTC (12 years ago) by parrello
New script to simplify NMPDR updates.
