[Bio] / Sprout / FidCheck.pm Repository:
Log of /Sprout/FidCheck.pm
Links to rast_rel_2008_10_09: (view) (download) (as text) (annotate)
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Tue Apr 10 05:59:07 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.1: +36 -5 lines
Converted so that non-features are treated in a more similar way in Sprout and SEED.
Sun Jun 25 00:00:18 2006 UTC (13 years, 8 months ago) by parrello
Created to allow a slimmer shim to be passed to the similarities method.
