[Bio] / Sprout / FidCheck.pm Repository:
Log of /Sprout/FidCheck.pm
Thu Dec 6 14:58:03 2007 UTC (12 years, 3 months ago) by parrello
Tue Apr 10 05:59:07 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.1: +36 -5 lines
Converted so that non-features are treated in a more similar way in Sprout and SEED.
Sun Jun 25 00:00:18 2006 UTC (13 years, 9 months ago) by parrello
Diff to selected 1.3
Created to allow a slimmer shim to be passed to the similarities method.
