[Bio] / Sprout / FeatureSproutLoader.pm Repository:
Log of /Sprout/FeatureSproutLoader.pm
Thu May 28 18:10:03 2009 UTC (11 years ago) by parrello
Changes since 1.9: +3 -16 lines
Updated to conform to new loading model.
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Thu Apr 2 01:42:00 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.8: +58 -140 lines
Redid the alias logic. Added memory tracing. Fixed to clear the subsystem cache more frequently.
Mon Mar 16 00:11:19 2009 UTC (11 years, 2 months ago) by parrello
Changes since 1.7: +99 -1 lines
Diff to previous 1.7 , to selected 1.9
Added support for harvesting aliases from the annotation clearinghouse.
Mon Mar 2 22:22:54 2009 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.6: +32 -15 lines
Diff to previous 1.6 , to selected 1.9
Fixed an error in alias formatting.
Mon Jan 19 21:46:21 2009 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +117 -61 lines
Diff to previous 1.5 , to selected 1.9
ERDB 2.0 support
Fri Oct 17 16:48:32 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.4: +13 -3 lines
Diff to previous 1.4 , to selected 1.9
Fixed handling of hyphenated words.
Thu Oct 9 17:23:54 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_10_09, rast_rel_2008_10_29
Diff to previous 1.3 , to selected 1.9
More loading bug fixes.
Thu Oct 2 16:32:42 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.2: +4 -3 lines
Diff to previous 1.2 , to selected 1.9
Wed Oct 1 03:07:08 2008 UTC (11 years, 8 months ago) by parrello
Diff to previous 1.1 , to selected 1.9
Tue Sep 30 15:23:55 2008 UTC (11 years, 8 months ago) by parrello
Diff to selected 1.9
New loader technology.
