[Bio] / Sprout / FeatureSproutLoader.pm Repository:
Log of /Sprout/FeatureSproutLoader.pm
Thu May 28 18:10:03 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.9: +3 -16 lines
Updated to conform to new loading model.
Thu Apr 2 01:42:00 2009 UTC (10 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.8: +58 -140 lines
Redid the alias logic. Added memory tracing. Fixed to clear the subsystem cache more frequently.
Mon Mar 16 00:11:19 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.7: +99 -1 lines
Added support for harvesting aliases from the annotation clearinghouse.
Mon Mar 2 22:22:54 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.6: +32 -15 lines
Fixed an error in alias formatting.
Mon Jan 19 21:46:21 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +117 -61 lines
ERDB 2.0 support
Fri Oct 17 16:48:32 2008 UTC (10 years, 10 months ago) by parrello
Changes since 1.4: +13 -3 lines
Fixed handling of hyphenated words.
Thu Oct 9 17:23:54 2008 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2008_10_09, rast_rel_2008_10_29
More loading bug fixes.
Thu Oct 2 16:32:42 2008 UTC (10 years, 10 months ago) by parrello
Changes since 1.2: +4 -3 lines
Wed Oct 1 03:07:08 2008 UTC (10 years, 10 months ago) by parrello
Tue Sep 30 15:23:55 2008 UTC (10 years, 10 months ago) by parrello
New loader technology.
