[Bio] / Sprout / FeatureSaplingLoader.pm Repository:
Log of /Sprout/FeatureSaplingLoader.pm
Tue Sep 13 21:07:59 2011 UTC (7 years, 7 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.18: +0 -18 lines
Diff to previous 1.18
Removed MD5 feature IDs.
Wed Aug 24 17:58:54 2011 UTC (7 years, 7 months ago) by parrello
Changes since 1.17: +4 -4 lines
Diff to previous 1.17
Modified to handle the new rules for MD5 identifiers.
Mon Jun 27 20:20:12 2011 UTC (7 years, 9 months ago) by parrello
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Diff to previous 1.16
Added more information to the MD5 computation error message.
Mon Jun 27 19:58:18 2011 UTC (7 years, 9 months ago) by parrello
Changes since 1.15: +15 -5 lines
Fixed to recover gracefully from invalid contig specifications in location strings.
Fri Jun 24 20:46:53 2011 UTC (7 years, 9 months ago) by parrello
Changes since 1.14: +9 -1 lines
Changes to support MD5 identifiers in the database.
Wed Jun 15 20:04:50 2011 UTC (7 years, 10 months ago) by parrello
Changes since 1.13: +4 -1 lines
Changed to read the protein sequences from the flat files.
Sat Feb 26 19:05:31 2011 UTC (8 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33
Changes since 1.12: +9 -3 lines
Even more loader fixes.
Sun Feb 13 13:02:30 2011 UTC (8 years, 2 months ago) by parrello
Mon Jan 24 03:52:18 2011 UTC (8 years, 2 months ago) by parrello
More loader fixes.
Wed Sep 29 18:00:40 2010 UTC (8 years, 6 months ago) by parrello
Changes since 1.9: +68 -20 lines
Mon Feb 1 20:14:28 2010 UTC (9 years, 2 months ago) by parrello
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.8: +38 -5 lines
Sapling model updates.
Wed Dec 16 01:45:19 2009 UTC (9 years, 4 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Sapling v08 changes.
Wed Nov 25 21:00:45 2009 UTC (9 years, 4 months ago) by parrello
Changes since 1.6: +15 -3 lines
Fixed handling of null assignments. Fixed to compute missing protein sequences.
Thu Oct 29 18:31:48 2009 UTC (9 years, 5 months ago) by parrello
Changes since 1.5: +0 -3 lines
Fixes for ACH processing.
Wed Jul 15 23:39:58 2009 UTC (9 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.4: +9 -5 lines
Tue Jun 30 19:53:01 2009 UTC (9 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Thu May 28 18:08:56 2009 UTC (9 years, 10 months ago) by parrello
Changes since 1.2: +51 -59 lines
Mon Mar 2 22:22:11 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.1: +67 -37 lines
Changed the way identifiers are handled.
Mon Jan 19 21:43:27 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Sapling support.
