[Bio] / Sprout / FeatureSaplingLoader.pm Repository:
View of /Sprout/FeatureSaplingLoader.pm
Revision 1.3 - (download) (as text) (annotate)
Thu May 28 18:08:56 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.2: +51 -59 lines
#!/usr/bin/perl -w
# Public License.
package FeatureSaplingLoader;
    use strict;
    use Tracer;
    use ERDB;
    use CGI qw(-nosticky);
    use BasicLocation;
    use HyperLink;
    use AliasAnalysis;
    use LoaderUtils;
    use base 'BaseSaplingLoader';
=head1 Sapling Feature Load Group Class
=head2 Introduction
The Feature Load Group includes all of the major feature-related tables.
=head3 new
    my $sl = FeatureSaplingLoader->new($erdb, $options, @tables);
Construct a new FeatureSaplingLoader object.
=over 4
=item erdb
[[SaplingPm]] object for the database being loaded.
=item options
Reference to a hash of command-line options.
=item tables
List of tables in this load group.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $erdb, $options) = @_;
    # Create the table list.
    my @tables = sort qw(Feature FeatureEssential FeatureEvidence FeatureLink
                         FeatureVirulent IsOwnerOf IsLocatedIn Identifies
                         Identifier IsNamedBy ProteinSequence Concerns
                         IsAttachmentSiteFor Publication IsProteinFor);
    # Create the BaseSaplingLoader object.
    my $retVal = BaseSaplingLoader::new($class, $erdb, $options, @tables);
    # Return it.
    return $retVal;
=head2 Public Methods
=head3 Generate
    $sl->Generate();
Generate the data for the feature-related files.
=cut
sub Generate {
    my ($self) = @_;
    # Get the database object.
    my $erdb = $self->db();
    # Only proceed if this is a normal section. There's no global feature data.
    if (! $self->global()) {
        # Get the section ID.
        my $genomeID = $self->section();
        # Load this genome's features.
        $self->LoadGenomeFeatures($genomeID);
=head3 LoadGenomeFeatures
    $sl->LoadGenomeFeatures($genomeID);
Load the feature-related data for a single genome.
=over 4
=item genomeID
ID of the genome whose feature data is to be loaded.
=back
=cut
sub LoadGenomeFeatures {
    my ($self, $genomeID) = @_;
    # Get the source object.
    my $fig = $self->source();
    # Get the database.
    my $sapling = $self->db();
    # Get the maximum location  segment length. We'll need this later.
    my $maxLength = $sapling->TuningParameter('maxLocationLength');
    # Get the genome's aliases.
    my $aliasDir = $sapling->LoadDirectory() . "/AliasData";
    my $aliasHash = LoaderUtils::ReadAliasFile($aliasDir, $genomeID);
    if (! defined $aliasHash) {
        Trace("No aliases found for $genomeID.") if T(1);
        $self->Add(missingAliasFile => 1);
        $aliasHash = {};
    # Get all of this genome's features.
    my $featureList = $fig->all_features_detailed_fast($genomeID);
    # Loop through them.
    for my $feature (@$featureList) {
        # Get this feature's data.
        my ($fid, $locationString, $aliases, $type, undef, undef, $assignment,
            $assignmentMaker, $quality) = @$feature;
        $self->Track(Features => $fid, 1000);
        # Fix the assignment for non-PEG features.
        if (! defined $assignment) {
            $assignment = $aliases;
            $assignmentMaker ||= 'master';
        # Convert the location string to a list of location objects.
        my @locs = map { BasicLocation->new($_) } split /\s*,\s*/, $locationString;
        # Now we need to run through the locations. We'll put the total sequence
        # length in here.
        my $seqLen = 0;
        # This will track the ordinal position of the current location segment.
        my $locN = 1;
        # Loop through the location objects.
        for my $loc (@locs) {
            # Add this location's length to the total length.
            $seqLen += $loc->Length();
            # Extract the contig ID. Note that we need to prefix the
            # genome ID to make it unique.
            my $contig = $loc->Contig();
            my $contigID = "$genomeID:$contig";
            # We also need the location's direction.
            my $dir = $loc->Dir();
            # Now we peel off sections of the location and connect them
            # to the feature.
            my $peel = $loc->Peel($maxLength);
            while (defined $peel) {
                $self->PutR(IsLocatedIn => $fid, $contigID, ordinal => $locN++,
                            begin => $peel->Left(), len => $peel->Length(),
                            dir => $dir);
            # Output the residual. There will always be one, because of the way
            # Peel works.
            $self->PutR(IsLocatedIn => $fid, $contigID, ordinal => $locN,
                        begin => $loc->Left(), dir => $dir, len => $loc->Length());
        # Is this an attachment site?
        if ($type eq 'att') {
            # Yes, connect it to the attached feature.
            if ($assignment =~ /att([LR])\s+for\s+(fig\|.+)/) {
                $self->PutR(IsAttachmentSiteFor => $fid, $2, edge => $1);
            } else {
                Trace("Invalid attachment function for $fid: $assignment") if T(1);
                $self->Add(badAttachment => 1);
        # Emit the feature record.
        $self->PutE(Feature => $fid, feature_type => $type,
                    sequence_length => $seqLen, function => $assignment,
                    locked => $fig->is_locked_fid($fid));
        # Connect the feature to its genome.
        $self->PutR(IsOwnerOf => $genomeID, $fid);
        # Now we have a whole bunch of attribute-related stuff to store in
        # secondary Feature tables. First is the evidence codes.
        my @evidenceTuples = $fig->get_attributes($fid, 'evidence_code');
        for my $evidenceTuple (@evidenceTuples) {
            my (undef, undef, $code) = @$evidenceTuple;
            $self->PutE(FeatureEvidence => $fid, 'evidence-code' => $code);
        # Now we have the external links. These are stored using hyperlink objects.
        my @links = $fig->fid_links($fid);
        for my $link (@links) {
            my $hl = HyperLink->newFromHtml($link);
            $self->PutE(FeatureLink => $fid, link => $hl);
        # Virulence data is next. This is also hyperlink data.
        my @virulenceTuples = $fig->get_attributes($fid, 'virulence_associated%');
        for my $virulenceTuple (@virulenceTuples) {
            my (undef, undef, $text, $url) = @$virulenceTuple;
            my $hl = HyperLink->new($text, $url);
            $self->PutE(FeatureVirulent => $fid, virulent => $hl);
        # Finally, the essentiality stuff, which is the last of the hyperlinks.
        my @essentials = $fig->get_attributes($fid, undef, ['essential', 'potential-essential']);
        for my $essentialTuple (@essentials) {
            my (undef, undef, $essentialityType, $url) = @$essentialTuple;
            # Form a hyperlink from this essentiality tuple.
            my $link = HyperLink->new($essentialityType, $url);
            # Store it as essentiality data for this feature.
            $self->PutE(FeatureEssential => $fid, essential => $link);
        # If this is a PEG, we have a protein sequence.
        my $proteinID;
        if ($type eq 'peg') {
            # Get the translation.
            my $proteinSequence = $fig->get_translation($fid);
            # Compute the ID.
            $proteinID = ERDB::DigestKey($proteinSequence);
            # Create the protein record.
            $self->PutE(ProteinSequence => $proteinID, sequence => $proteinSequence);
            $self->PutR(IsProteinFor => $proteinID, $fid);
            # Get the publications for this PEG.
            my @pubs = $fig->get_attributes($fid, 'PUBMED_CURATED_RELEVANT');
            for my $pub (@pubs) {
                # Parse out the article title from the data.
                my (undef, undef, $data, $url) = @$pub;
                my @pieces = split /,/, $data, 3;
                if (defined $pieces[2]) {
                    # Create the publication record.
                    my $hl = HyperLink->new($pieces[2], $url);
                    my $key = ERDB::DigestKey($url);
                    $self->PutE(Publication => $key, citation => $hl);
                    # Connect it to the protein.
                    $self->PutR(Concerns => $key, $proteinID);
        # Now we need to compute the identifiers. We start with the aliases.
        # Get the alias data for this feature. If there is none, we force an
        # empty list.
        my $aliasList = $aliasHash->{$fid} || [];
        # Loop through the aliases found.
        for my $aliasTuple (@$aliasList) {
            my ($aliasID, $aliasType, $aliasConf) = @$aliasTuple;
            # Get the natural form. If there is none, then the canonical
            # form IS the natural form.
            my $natural = AliasAnalysis::Type($aliasType => $aliasID) || $aliasID;
            # Create the identifier record.
            $self->PutE(Identifier => $aliasID, natural_form => $natural,
                        source => $type);
            # Is this a protein alias?
            if ($aliasConf eq 'C' && $proteinID) {
                # Yes. Connect it using IsNamedBy.
                $self->PutR(IsNamedBy => $proteinID, $aliasID);
            } else {
                # No. Connect it to the feature.
                $self->PutR(Identifies => $aliasID, $fid, conf => $aliasConf);
        # Finally, this feature is an alias of itself.
        $self->PutE(Identifier => $fid, natural_form => $fid,
                    source => 'SEED');
        $self->PutR(Identifies => $fid, $fid, conf => 'A');
        if ($proteinID) {
            $self->PutR(IsNamedBy => $proteinID, $fid);
1;
