[Bio] / Sprout / FeatureQuery.pm Repository:
Log of /Sprout/FeatureQuery.pm
Revision 1.22
Mon Jul 16 20:06:30 2007 UTC (12 years, 8 months ago) by parrello
CVS Tags: HEAD
Changes since 1.21: +0 -0 lines
FILE REMOVED
Obsolete modules, replaced by RHFeatures and SHToolSearch.
Thu May 17 23:41:05 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.20: +6 -6 lines
Diff to previous 1.20
Turned off ShowPDB option.
Fri May 11 06:23:21 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.19: +11 -1 lines
Diff to previous 1.19
Added support for displaying PDBs that match the selected features.
Sat Apr 14 21:40:09 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.18: +9 -3 lines
Diff to previous 1.18
Added the Favored Alias option.
Tue Apr 10 05:56:27 2007 UTC (13 years ago) by parrello
Changes since 1.17: +5 -5 lines
Diff to previous 1.17
Converted from DBObject to ERDBObject.
Wed Feb 21 13:17:42 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.16: +31 -17 lines
Diff to previous 1.16
Added support for splitting the filter rows.
Wed Dec 6 03:35:06 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.15: +1 -0 lines
Added tracing.
Sat Dec 2 09:43:32 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.14: +4 -4 lines
Fixed the SpecialOptions method.
Wed Nov 15 12:09:19 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.13: +5 -0 lines
Added keyword validation.
Thu Nov 9 21:22:41 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.12: +3 -6 lines
Changed to allow search helpers to use the checkboxes without pulling in the rest of the feature filter.
Wed Nov 8 23:17:36 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.11: +65 -1 lines
Added support for searches that do not need feature filtering but still want to use the special options.
Fri Nov 3 00:35:22 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.10: +32 -3 lines
Added an option for displaying subsystem data in the results.
Mon Oct 16 22:58:02 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.9: +30 -348 lines
Removed confusing search options from the standard filter. Added a warning to the subsystem dropdown.
Mon Oct 16 07:44:13 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.8: +25 -141 lines
Factored the FeatureQuery module into a base class that handles feature manipulation and a subclass that handles feature manipulation and query support.
Sat Oct 14 18:14:10 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.7: +7 -7 lines
Let the underlying object do the keyword cleaning.
Fri Oct 13 21:45:11 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.6: +96 -7 lines
Sat Oct 7 13:19:05 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.5: +9 -3 lines
Changed so we can give the feature types display names different from their values in the database.
Tue Oct 3 11:05:45 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.4: +49 -30 lines
Upgraded to allow specification of multiple property values per property.
Mon Oct 2 03:14:53 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.3: +106 -1 lines
Moved the show aliases option to this object. Added sort by function.
Fri Sep 29 17:03:21 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.2: +24 -16 lines
Made the query smarter in the case where the user is searching all genomes.
Fri Sep 29 15:10:05 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.1: +211 -35 lines
Wed Sep 27 16:55:38 2006 UTC (13 years, 6 months ago) by parrello
