[Bio] / Sprout / FIGSproutTest.pl Repository:
Log of /Sprout/FIGSproutTest.pl
Links to rast_rel_2011_0928: (view) (download) (as text) (annotate)
Mon Mar 7 17:45:34 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.2: +3 -1 lines
Fixes to put XML file in FIGdisk/FIG.
Mon Mar 7 17:17:42 2005 UTC (15 years, 1 month ago) by olson
Use $FIG_Config::sproutData instead of FIG_Config::fig/SproutData
Sun Jan 23 16:12:29 2005 UTC (15 years, 2 months ago) by parrello
no message
