[Bio] / Sprout / FIGSproutTest.pl Repository:
Log of /Sprout/FIGSproutTest.pl
Mon Mar 7 17:45:34 2005 UTC (15 years, 3 months ago) by olson
Changes since 1.2: +3 -1 lines
Fixes to put XML file in FIGdisk/FIG.
Mon Mar 7 17:17:42 2005 UTC (15 years, 3 months ago) by olson
Use $FIG_Config::sproutData instead of FIG_Config::fig/SproutData
Sun Jan 23 16:12:29 2005 UTC (15 years, 4 months ago) by parrello
Diff to selected 1.2
no message
