[Bio] / Sprout / ExportAttributes.pl Repository:
Log of /Sprout/ExportAttributes.pl
Tue Feb 5 05:47:32 2008 UTC (12 years, 1 month ago) by parrello
Removed obsolete use clauses.
Thu Nov 16 22:57:40 2006 UTC (13 years, 4 months ago) by parrello
Added to export attribute data to TBL files.
