[Bio] / Sprout / ExportAttributes.pl Repository:
Log of /Sprout/ExportAttributes.pl
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Removed obsolete use clauses.
Thu Nov 16 22:57:40 2006 UTC (12 years, 11 months ago) by parrello
Diff to selected 1.2
Added to export attribute data to TBL files.
