[Bio] / Sprout / ExportAttributes.pl Repository:
Log of /Sprout/ExportAttributes.pl
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Tue Feb 5 05:47:32 2008 UTC (11 years, 7 months ago) by parrello
Removed obsolete use clauses.
Thu Nov 16 22:57:40 2006 UTC (12 years, 10 months ago) by parrello
Added to export attribute data to TBL files.
