[Bio] / Sprout / EvCodeRefresh.pl Repository:
Log of /Sprout/EvCodeRefresh.pl
Tue Aug 12 06:06:02 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.3: +13 -87 lines
Converted to new multi-table design concept for attributes.
Fri Jul 11 01:05:46 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806
Changes since 1.2: +305 -95 lines
Incorporated methods from get_ev_codes.
Wed Jul 2 06:20:30 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_07_21
Changed so that a missing evidence code file name is not an error.
Wed Jul 2 05:54:55 2008 UTC (11 years, 4 months ago) by parrello
New script for loading evidence codes.
