[Bio] / Sprout / ERDBTypeText.pm Repository:
Log of /Sprout/ERDBTypeText.pm
Sat Oct 1 10:35:02 2011 UTC (8 years, 1 month ago) by parrello
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +47 -4 lines
Conversion to support Postgres for ERDB.
Tue Sep 8 21:31:56 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Fixed an error in the documentation.
Tue Jun 30 19:53:01 2009 UTC (10 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Mon Mar 2 22:18:36 2009 UTC (10 years, 8 months ago) by parrello
Increased the size of text fields.
Mon Jan 19 21:46:21 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
