[Bio] / Sprout / ERDBTypeShortString.pm Repository:
View of /Sprout/ERDBTypeShortString.pm
Sun Feb 22 03:28:31 2015 UTC (5 years, 1 month ago) by parrello
CVS Tags: HEAD
Removed Shrub stuff. Updated ERDB for compatibility with Shrub DBD.
#!/usr/bin/perl -w
# Public License.
package ERDBTypeShortString;
    use strict;
    use Tracer;
    use ERDB;
    use base qw(ERDBType);
=head1 ERDB Short String Type Definition
=head2 Introduction
This object represents the data type for short strings of 32 characters or less
with no odd control characters needing translation. Such strings are very limited,
but more of them can be crowded into an index and they do not require encoding or
decoding.
=head3 new
    my $et = ERDBTypeShortString->new();
Construct a new ERDBTypeShortString descriptor.
=cut
sub new {
    # Get the parameters.
    my ($class) = @_;
    # Create the ERDBTypeShortString object.
    my $retVal = { };
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head2 Virtual Methods
=head3 averageLength
    my $value = $et->averageLength();
Return the average length of a data item of this field type when it is stored in the
database. This value is used to compute the expected size of a database table.
=cut
sub averageLength {
    return 24;
=head3 prettySortValue
    my $value = $et->prettySortValue();
Number indicating where fields of this type should go in relation to other
fields. The value should be somewhere between C<1> and C<5>. A value outside
that range will make terrible things happen.
=cut
sub prettySortValue() {
    return 1;
=head3 validate
    my $okFlag = $et->validate($value);
Return an error message if the specified value is invalid for this field type.
The parameters are as follows.
=over 4
=item value
Value of this type, for validation.
=item RETURN
Returns an empty string if the specified field is valid, and an error message
otherwise.
=back
=cut
sub validate {
    my ($self, $value) = @_;
    # Assume it's valid until we prove otherwise.
    my $retVal = "";
    if (length($value) > 32) {
        $retVal = "Invalid short string field.";
    } elsif ($value =~ /[\%\\\x00-\x1F\x80-\xFF]/) {
        $retVal = "Invalid character in short-string field.";
    # Return the determination.
    return $retVal;
=head3 encode
    my $string = $et->encode($value, $mode);
Encode a value of this field type for storage in the database (or in a database load
file.)
=over 4
=item value
Value of this type, for encoding.
=item mode
TRUE if the value is being encoding for placement in a load file, FALSE if it
is being encoded for use as an SQL statement parameter. In most cases, the
encoding is the same for both modes.
=back
=cut
sub encode {
    my ($self, $value, $mode) = @_;
    # Return the input value.
    return $value;
=head3 decode
    my $value = $et->decode($string);
Decode a string from the database into a value of this field type.
=over 4
=item string
String from the database to be decoded.
=item RETURN
Returns a value of the desired type.
=back
=cut
sub decode {
    my ($self, $string) = @_;
    return $string;
=head3 sqlType
    my $typeString = $et->sqlType($dbh);
Return the SQL data type for this field type.
=over 4
=item dbh
Open L<DBKernel> handle for the database in question. This is used when the
datatype may be different depending on the DBMS used.
=item RETURN
Returns the datatype string to be used when creating a field of this type in
an SQL table.
=back
=cut
sub sqlType {
    return "VARCHAR(32)";
=head3 indexMod
    my $length = $et->indexMod();
Return the index modifier for this field type. The index modifier is the number of
characters to be indexed. If it is undefined, the field cannot be indexed. If it
is an empty string, the entire field is indexed. The default is an empty string.
=cut
sub indexMod {
    return '';
=head3 sortType
    my $letter = $et->sortType();
Return the sorting type for this field type. The sorting type is C<n> for integers,
C<g> for floating-point numbers, and the empty string for character fields.
The default is the empty string.
=cut
sub sortType {
    return "";
=head3 documentation
    my $docText = $et->documentation();
Return the documentation text for this field type. This should be in TWiki markup
format, though HTML will also work.
=cut
sub documentation() {
    return 'A short string of 32 or fewer chaaracters.';
=head3 name
    my $name = $et->name();
Return the name of this type, as it will appear in the XML database definition.
=cut
sub name() {
    return "short-string";
=head3 default
    my $defaultValue = $et->default();
Default value to be used for fields of this type if no default value is
specified in the database definition or in an L<ERDBLoadGroup/Put>
call during a loader operation. The default is undefined, which means
an error will be thrown during the load.
=cut
sub default {
    return '';
=head3 align
    my $alignment = $et->align();
Return the display alignment for fields of this type: either C<left>, C<right>, or
C<center>. The default is C<left>.
=cut
sub align {
    return 'left';
1;
