[Bio] / Sprout / ERDBTypeProteinData.pm Repository:
Log of /Sprout/ERDBTypeProteinData.pm
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Mon Nov 1 15:17:52 2010 UTC (9 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Protein-data type.
