[Bio] / Sprout / ERDBTypeLink.pm Repository:
Log of /Sprout/ERDBTypeLink.pm
Tue Jun 30 19:53:01 2009 UTC (10 years, 7 months ago) by parrello
Thu Feb 5 07:10:54 2009 UTC (11 years ago) by parrello
Changes since 1.1: +11 -0 lines
Added an override to the ObjectType method that indicates this is a complex data type.
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
