[Bio] / Sprout / ERDBTypeLink.pm Repository:
Log of /Sprout/ERDBTypeLink.pm
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Thu Feb 5 07:10:54 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.1: +11 -0 lines
Added an override to the ObjectType method that indicates this is a complex data type.
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
