[Bio] / Sprout / ERDBTypeImage.pm Repository:
Log of /Sprout/ERDBTypeImage.pm
Sat Oct 1 10:35:02 2011 UTC (7 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +21 -2 lines
Conversion to support Postgres for ERDB.
Thu May 28 18:08:05 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.2: +3 -2 lines
Fixed some bugs revealed by the Sapling database.
Thu Feb 5 06:53:08 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.1: +12 -0 lines
Added an override to the ObjectType method that indicates this is a complex data type.
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
