[Bio] / Sprout / ERDBTypeImage.pm Repository:
Log of /Sprout/ERDBTypeImage.pm
Thu May 28 18:08:05 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.2: +3 -2 lines
Fixed some bugs revealed by the Sapling database.
Thu Feb 5 06:53:08 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.1: +12 -0 lines
Added an override to the ObjectType method that indicates this is a complex data type.
Mon Jan 19 21:46:21 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
