[Bio] / Sprout / ERDBTypeFloat.pm Repository:
Log of /Sprout/ERDBTypeFloat.pm
Tue Jun 30 19:53:01 2009 UTC (10 years, 7 months ago) by parrello
Tue Apr 7 14:12:29 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Fixed the pattern string for validation.
Mon Mar 2 22:20:58 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Increased number of significant figures when converted to HTML.
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
