[Bio] / Sprout / ERDBTypeFloat.pm Repository:
View of /Sprout/ERDBTypeFloat.pm
Revision 1.6 - (download) (as text) (annotate)
Sun Dec 9 01:36:05 2012 UTC (7 years, 3 months ago) by parrello
CVS Tags: rast_rel_2014_0912, rast_rel_2014_0729, HEAD
Changes since 1.5: +28 -2 lines
Added support for nullable floats and integers.
#!/usr/bin/perl -w
# Public License.
package ERDBTypeFloat;
    use strict;
    use Tracer;
    use ERDB;
    use base qw(ERDBType);
=head1 Double Precision Floating-Point Numeric Type Definition
=head2 Introduction
This object represents the primitive data type for IEEE 8-byte floating-point
numbers. The allowable values are -1.7976931348623157E+308 to
-2.2250738585072014E-308, 0, and 2.2250738585072014E-308 to
1.7976931348623157E+308.
=cut
=head3 new
    my $et = ERDBTypeFloat->new();
Construct a new ERDBTypeFloat object.
=cut
sub new {
    # Get the parameters.
    my ($class) = @_;
    # Create the  object.
    my $retVal = { };
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head2 Virtual Methods
=head3 numeric
    my $flag = $et->numeric();
Return TRUE if this is a numeric type and FALSE otherwise. The default is
FALSE.
=cut
sub numeric {
    my ($self) = @_;
    # Return the result.
    return 1;
=head3 nullable
    my $flag = $et->nullable();
Return TRUE if this type allows null-valued fields, else FALSE. The default is
FALSE.
=cut
sub nullable {
    my ($self) = @_;
    return 1;
=head3 averageLength
    my $value = $et->averageLength();
Return the average length of a data item of this field type when it is stored in the
database. This value is used to compute the expected size of a database table.
=cut
sub averageLength {
    return 8;
=head3 prettySortValue
    my $value = $et->prettySortValue();
Number indicating where fields of this type should go in relation to other
fields. The value should be somewhere between C<1> and C<5>. A value outside
that range will make terrible things happen.
=cut
sub prettySortValue() {
    return 1;
=head3 validate
    my $okFlag = $et->validate($value);
Return an error message if the specified value is invalid for this field type.
The parameters are as follows.
=over 4
=item value
Value of this type, for validation.
=item RETURN
Returns an empty string if the specified field is valid, and an error message
otherwise.
=back
=cut
sub validate {
    my ($self, $value) = @_;
    # Assume it's valid until we prove otherwise.
    my $retVal = "";
    if (not $value =~ /^[+-]?(?:\d+\.?|\d+\.\d+|\.\d+)(?:[Ee][+-]?\d+)?$/) {
        $retVal = "Floating-point value \"$value\" is not numeric.";
    # Return the determination.
    return $retVal;
=head3 encode
    my $string = $et->encode($value, $mode);
Encode a value of this field type for storage in the database (or in a database load
file.)
=over 4
=item value
Value of this type, for encoding.
=item mode
TRUE if the value is being encoding for placement in a load file, FALSE if it
is being encoded for use as an SQL statement parameter. In most cases, the
encoding is the same for both modes.
=back
=cut
sub encode {
    my ($self, $value, $mode) = @_;
    # Get the value.
    my $retVal = $value;
    # If we are going into a load file and the value is NULL, convert it to an
    # escape sequence.
    if ($mode && ! defined $retVal) {
        $retVal = "\\N";
    return $retVal;
=head3 decode
    my $value = $et->decode($string);
Decode a string from the database into a value of this field type.
=over 4
=item string
String from the database to be decoded.
=item RETURN
Returns a value of the desired type.
=back
=cut
sub decode {
    my ($self, $string) = @_;
    return $string;
=head3 sqlType
    my $typeString = $et->sqlType($dbh);
Return the SQL data type for this field type.
=over 4
=item dbh
Open L<DBKernel> handle for the database in question. This is used when the
datatype may be different depending on the DBMS used.
=item RETURN
Returns the datatype string to be used when creating a field of this type in
an SQL table.
=back
=cut
sub sqlType {
    return "DOUBLE PRECISION";
=head3 indexMod
    my $length = $et->indexMod();
Return the index modifier for this field type. The index modifier is the number of
characters to be indexed. If it is undefined, the field cannot be indexed. If it
is an empty string, the entire field is indexed. The default is an empty string.
=cut
sub indexMod {
    return '';
=head3 sortType
    my $letter = $et->sortType();
Return the sorting type for this field type. The sorting type is C<n> for integers,
C<g> for floating-point numbers, and the empty string for character fields.
The default is the empty string.
=cut
sub sortType {
    return "g";
=head3 documentation
    my $docText = $et->documentation();
Return the documentation text for this field type. This should be in TWiki markup
format, though HTML will also work.
=cut
sub documentation() {
    return "Floating-point number, approximately 15 significant digits, from 10^-308 to 10^+308.";
=head3 name
    my $name = $et->name();
Return the name of this type, as it will appear in the XML database definition.
=cut
sub name() {
    return "float";
=head3 default
    my $defaultValue = $et->default();
Default value to be used for fields of this type if no default value is
specified in the database definition or in an L<ERDBLoadGroup/Put>
call during a loader operation. The default is undefined, which means
an error will be thrown during the load.
=cut
sub default {
    return 0;
=head3 align
    my $alignment = $et->align();
Return the display alignment for fields of this type: either C<left>, C<right>, or
C<center>. The default is C<left>.
=cut
sub align {
    return 'center';
=head3 html
    my $html = $et->html($value);
Return the HTML for displaying the content of a field of this type in an output
table. The default is the raw value, html-escaped.
=cut
sub html {
    my $retVal = "";
    if (defined $value) {
        $retVal = sprintf("%.8g", $value);
    return $retVal;
1;
