[Bio] / Sprout / ERDBType.pm Repository:
Log of /Sprout/ERDBType.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Tue Jun 30 19:53:01 2009 UTC (10 years, 7 months ago) by parrello
Thu Feb 5 06:51:30 2009 UTC (11 years ago) by parrello
Changes since 1.1: +13 -0 lines
Added a virtual method that indicates whether or not a type is scalar or complex.
Mon Jan 19 21:46:21 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
