[Bio] / Sprout / ERDBQueryConsole.pm Repository:
Log of /Sprout/ERDBQueryConsole.pm
Tue Jun 30 19:53:01 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.5: +10 -6 lines
Thu Jun 18 01:29:58 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.4: +52 -9 lines
Added a raw mode for the Sapling server's use.
Thu Jun 4 18:20:50 2009 UTC (10 years, 11 months ago) by parrello
Added a switch to turn off query caching in the debug console.
Thu May 28 18:07:36 2009 UTC (11 years ago) by parrello
Changes since 1.2: +76 -21 lines
Fixed to work better from inside the Seed Viewer.
Thu Apr 2 01:38:55 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.1: +0 -3 lines
Refactored to allow creation oif an ERDB console page in the Seed Viewer.
Mon Mar 23 19:36:37 2009 UTC (11 years, 2 months ago) by parrello
Support for SeedViewer version of query console.
