[Bio] / Sprout / ERDBQuery.pm Repository:
Log of /Sprout/ERDBQuery.pm
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Thu Apr 2 01:38:15 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Fixed a comment.
Mon Mar 23 19:36:37 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.3: +70 -2 lines
Support for SeedViewer version of query console.
Mon Mar 2 22:17:49 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.2: +65 -13 lines
Refactored field and objecy name parsing.
Thu Feb 5 06:50:51 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.1: +21 -0 lines
Added a method to extract the default object name for a query.
CVS Tags: rast_rel_2009_02_05
Diff to selected 1.5
ERDB 2.0 support
