[Bio] / Sprout / ERDBQuery.pm Repository:
Log of /Sprout/ERDBQuery.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Fri Dec 11 21:21:26 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.11: +8 -4 lines
Server database recovery fix.
Fri Dec 11 17:15:08 2009 UTC (10 years, 2 months ago) by parrello
Fixed error message from Fetch.
Mon Nov 30 17:37:56 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.9: +41 -6 lines
Fixed a memory leak in the query handling.
Wed Nov 25 20:59:46 2009 UTC (10 years, 2 months ago) by parrello
Cleaned up some documentation.
Sun Oct 11 19:52:19 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.7: +7 -11 lines
Fixed the DecodeField bug.
Wed Sep 30 16:36:08 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.6: +11 -2 lines
Bulk query speedups:
ERDBQuery::Fetch uses a closure created by ERDBObject::_new_fast_helper that precomputes
the data needed for creating ERDBOjects.
Remove an inner-loop Trace(...) if T(..) that gets expensive.
Tue Jun 30 19:53:01 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.5: +6 -6 lines
Thu Apr 2 01:38:15 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Fixed a comment.
Mon Mar 23 19:36:37 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.3: +70 -2 lines
Support for SeedViewer version of query console.
Mon Mar 2 22:17:49 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.2: +65 -13 lines
Refactored field and objecy name parsing.
Thu Feb 5 06:50:51 2009 UTC (11 years ago) by parrello
Changes since 1.1: +21 -0 lines
Added a method to extract the default object name for a query.
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
ERDB 2.0 support
