[Bio] / Sprout / ERDBObject.pm Repository:
Log of /Sprout/ERDBObject.pm
Tue Sep 16 18:54:43 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.5: +1 -4 lines
Removed the obsolete new-record flag.
Tue Feb 5 04:54:38 2008 UTC (12 years, 2 months ago) by parrello
Removed reference to AddToListMap.
Changes since 1.3: +12 -12 lines
Mon Jul 16 20:04:51 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.2: +40 -1 lines
Mon Jun 11 18:52:07 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.1: +7 -6 lines
Fixed some comments so they will be applicable to the new E-R model.
Tue Apr 10 05:54:58 2007 UTC (12 years, 11 months ago) by parrello
Converted from DBObject.
