[Bio] / Sprout / ERDBObject.pm Repository:
Log of /Sprout/ERDBObject.pm
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Mon Oct 18 19:23:24 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.14: +1 -3 lines
Fixed an error in the retrieval of secondary relation fields.
Thu Oct 14 17:27:37 2010 UTC (9 years, 4 months ago) by parrello
Changes since 1.13: +29 -13 lines
Changes for expression vector support.
Mon Nov 30 17:37:56 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.12: +35 -79 lines
Fixed a memory leak in the query handling.
Wed Nov 25 20:59:46 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.11: +19 -18 lines
Cleaned up some documentation.
Sun Oct 11 19:52:19 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.10: +24 -100 lines
Fixed the DecodeField bug.
Wed Sep 30 16:36:08 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.9: +94 -2 lines
Bulk query speedups:
ERDBQuery::Fetch uses a closure created by ERDBObject::_new_fast_helper that precomputes
the data needed for creating ERDBOjects.
Remove an inner-loop Trace(...) if T(..) that gets expensive.
Tue Jun 30 19:53:01 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.8: +9 -9 lines
Sat Mar 7 18:07:36 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.7: +48 -42 lines
Cleaned up some error messages. Fixed some bugs in search.
Mon Jan 19 21:46:21 2009 UTC (11 years, 1 month ago) by parrello
Changes since 1.6: +185 -266 lines
ERDB 2.0 support
Tue Sep 16 18:54:43 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.5: +1 -4 lines
Removed the obsolete new-record flag.
Tue Feb 5 04:54:38 2008 UTC (12 years ago) by parrello
Removed reference to AddToListMap.
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.3: +12 -12 lines
Mon Jul 16 20:04:51 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.2: +40 -1 lines
Mon Jun 11 18:52:07 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.1: +7 -6 lines
Fixed some comments so they will be applicable to the new E-R model.
Tue Apr 10 05:54:58 2007 UTC (12 years, 10 months ago) by parrello
Converted from DBObject.
