[Bio] / Sprout / ERDBLoader.pl Repository:
Log of /Sprout/ERDBLoader.pl
Revision 1.19 - (view) (download) (as text) (annotate) - [selected]
Sat Apr 30 15:21:18 2011 UTC (8 years, 4 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.18: +7 -0 lines
Diff to previous 1.18
Fixed to save the section list in a file.
Fri Jan 28 19:55:38 2011 UTC (8 years, 7 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.17: +12 -12 lines
Diff to previous 1.17 , to selected 1.19
Latest load-process fixes.
Mon Jan 3 18:16:47 2011 UTC (8 years, 8 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Diff to previous 1.16 , to selected 1.19
More tracing for collation check.
Mon Jan 3 18:08:10 2011 UTC (8 years, 8 months ago) by parrello
Changes since 1.15: +0 -1 lines
Diff to previous 1.15 , to selected 1.19
Another attempt to fix the duplicate-subsystem problem.
Sat Dec 25 15:57:45 2010 UTC (8 years, 8 months ago) by parrello
Changes since 1.14: +43 -50 lines
Diff to previous 1.14 , to selected 1.19
Fixes for duplicate-subsystem problem.
Wed Nov 25 20:59:25 2009 UTC (9 years, 9 months ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Diff to previous 1.13 , to selected 1.19
Fixed load time stat display.
Tue Sep 8 21:30:33 2009 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.12: +4 -1 lines
Diff to previous 1.12 , to selected 1.19
Changed to allow for storing the DBD metadata in the database. This is currently only activated for Sapling.
CVS Tags: rast_rel_2009_07_09
Changes since 1.11: +4 -4 lines
Diff to previous 1.11 , to selected 1.19
Thu May 28 18:06:58 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.10: +41 -152 lines
Diff to previous 1.10 , to selected 1.19
Mon May 4 18:49:49 2009 UTC (10 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.9: +9 -5 lines
Diff to previous 1.9 , to selected 1.19
Updated to use Bob's protocol for load options.
Mon Mar 23 19:34:35 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.8 , to selected 1.19
Fixed a comment.
Mon Mar 2 22:16:27 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.7: +12 -1 lines
Diff to previous 1.7 , to selected 1.19
Added a load-directory parameter.
Thu Feb 5 06:50:12 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.6: +7 -1 lines
Diff to previous 1.6 , to selected 1.19
Added an option to allow section files to overwrite assembled files.
Mon Jan 19 21:46:21 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +65 -18 lines
Diff to previous 1.5 , to selected 1.19
ERDB 2.0 support
Wed Oct 15 11:41:12 2008 UTC (10 years, 11 months ago) by parrello
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.19
No discernible change.
Thu Oct 9 17:23:54 2008 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_10_09
Changes since 1.3: +135 -25 lines
Diff to previous 1.3 , to selected 1.19
More loading bug fixes.
Thu Oct 2 16:32:42 2008 UTC (10 years, 11 months ago) by parrello
Changes since 1.2: +24 -17 lines
Diff to previous 1.2 , to selected 1.19
Wed Oct 1 03:07:08 2008 UTC (10 years, 11 months ago) by parrello
Changes since 1.1: +76 -11 lines
Diff to previous 1.1 , to selected 1.19
Tue Sep 30 15:23:55 2008 UTC (10 years, 11 months ago) by parrello
Diff to selected 1.19
New loader technology.
