View of /Sprout/ERDBLoadGroup.pm
Revision 1.4 - (download) (as text) (annotate)
Thu Oct 9 17:23:54 2008 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2008_12_18, mgrast_rel_2008_1110_v2, rast_rel_2008_10_09, mgrast_rel_2008_1110, rast_rel_2008_10_29, rast_rel_2008_11_24
More loading bug fixes.
#!/usr/bin/perl -w
# Public License.
package ERDBLoadGroup;
    use strict;
    use Tracer;
    use ERDB;
    use Stats;
    use Time::HiRes qw(time);
    use ERDBGenerate;
=head1 ERDB Database Load Group Object
The process of loading an ERDB database can be a simple matter of creating some
sequential files from other sequential files, or it can be a complex web of
connected sub-processes involving multiple groups of tables being loaded in
parallel by multiple worker processes. The ERDB Database Load Group object
provides housekeeping functions to simplify the management of the more complex
load tasks.
When discussing an ERDB database load, there are two similar concepts we use to
break the load into pieces: I<sections> and I<groups>. A I<section> is a
partition of the data that can be processed in isolation from other sections. A
I<group> is a set of tables that should be loaded at the same time. An ERDB load
group is a request to generate load files for one or more sections of the data
targeting a single group of tables.
A certain amount of bookkeeping is required in order to handle parallelism. For
each table, a separate output file is generated for each section. If a section
does not complete successfully, then its load file is deleted and the section
must be loaded again. Because each section has its own load file, only the
particular sections that fail need to be reloaded.
Individual load groups should subclass this object, providing a virtual override
for the L</Generate> method.
The subclass name should consist of the group name followed by noise in capital
case. So, for example, the subclass name for a group named C<Feature> would be
C<FeatureSproutLoader> or C<FeatureAttributeLoader> or something similar. The
group name should only be letters, and only the first letter should be capitalized.
This allows the load script to be case-insensitive with regard to incoming group
names.
Any working or status files generated by a subclass should have a prefix of C<dt>-something.
This will insure they are deleted by the C<clear> option of [[ERDBGeneratorPl]].
The fields in this object are as follows.
=over 4
=item db
[[ErdbPm]] object for accessing the target database
=item directory
Directory into which the load files should be placed.
=item group
name of this load group
=item lastKey
ID of the last major object processed
=item loaders
hash mapping the names of the group's tables to [[ERDBGeneratePm]] objects
=item stats
statistics object that can be used to track the progress of the load
=item section
name of this data section
=item source
object used to access the data from which the load files are to be generated
=item tables
reference to a list of the names of the tables in this group
=item options
hash containing the options originally passed in to the constructor
=back
=cut
=head3 new
    my $edbl = ERDBLoadGroup->new($source, $db, $directory, $options, @tables);
Construct a new ERDBLoadGroup object. The following parameters are expected:
=over 4
=item source
The object to be used by the subclass to access the source data. If this parameter
is undefined, the source object will be retrieved from the database object as soon
as the client calls the L</source> method.
=item db
The [[ErdbPm]] object for the database being loaded.
=item options
Reference to a hash of options. At the current time, no options are needed
by this object, but they may be important to subclass objects.
=item tables
A list of the names for the tables in this load group.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $source, $db, $options, @tables) = @_;
    # Create a statistics object
    my $stats = Stats->new();
    # Compute the group name from the class name. It is the first word in
    # a name that is presumably capital case.
    my $group = ($class =~ /^([A-Z][a-z]+)/ ? $1 : $class);
    # Get the directory.
    my $directory = $db->LoadDirectory();
    Confess("Load directory \"$directory\" not found or invalid.") if ! -d $directory;
    # Create the ERDBLoadGroup object. Note that so far we don't have any loaders
    # defined and the section has not yet been assigned. The "ProcessSection"
    # method is used to assign the section, and the loaders are created the first
    # time it's called.
    my $retVal = {
                    db => $db,
                    directory => $directory,
                    group => $group,
                    stats => $stats,
                    source => $source,
                    lastKey => undef,
                    loaders => {},
                    tables => \@tables,
                    section => undef,
                    options => $options
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head2 Subclass Methods
=head3 Put
    $edbl->Put($table, %fields);
Place a table record in a load file. This method is the workhorse of the
file generation phase of a load.
=over 4
=item table
Name of the table being loaded.
=item fields
Hash of field names to field values for the fields in the table.
=back
=cut
sub Put {
    my ($self, $table, %fields) = @_;
    # Get the loader for this table.
    my $loader = $self->{loaders}->{$table};
    # Complain if it doesn't exist.
    Confess("Table $table not found in load group $self->{group}.") if ! defined $loader;
    # Put this record to the loader's output file.
    my $bytes = $loader->Put(%fields);
    # Count the record and the bytes of data. If no bytes were output, the record
    # was discarded.
    if (! $bytes) {
        $self->Add("$table-discards" => 1);
    } else {
        $self->Add("$table-records" => 1);
        $self->Add("$table-bytes" => $bytes);
=head3 PutE
    $edbl->PutE($table => $id, %fields);
Place an entity-based table record in a load file. The first field
specified after the table name is the ID.
=over 4
=item table
Name of the relevant table.
=item id
ID of the relevant entity.
=item fields
Hash mapping field names to values.
=back
=cut
sub PutE {
    my ($self, $table, $id, %fields) = @_;
    # Put the record.
    $self->Put($table, id => $id, %fields);
    # Record that we've done a putE.
    $self->Add(putE => 1);
=head3 PutR
    $edbl->PutR($table => $from, $to, %fields);
Place a relationship record in a load file. The first two fields
specified after the table name are the from-link and the to-link,
respectively.
=over 4
=item table
Name of the relevant relationship.
=item from
ID of the from-entity.
=item to
ID of the to-entity.
=item fields
Hash mapping field names to field values.
=back
=cut
sub PutR {
    my ($self, $table, $from, $to, %fields) = @_;
    # Put the record.
    $self->Put($table, 'from-link' => $from, 'to-link' => $to, %fields);
    # Record that we've done a PutR.
    $self->Add(putR => 1);
=head3 Add
    $edbl->Add($statName => $count);
Add the specified count to the named statistical counter. The statistical
counts are kept in an internal statistics object whose contents are
displayed when the group is finished.
=over 4
=item statName
Name of the statistic to increment.
=item count
Value by which to increment it.
=back
=cut
sub Add {
    my ($self, $statName, $count) = @_;
    # Update the statistic.
    $self->{stats}->Add($statName => $count);
=head3 AddWarning
    $edbl->AddWarning($errorType => $message);
Record a warning. Warnings indicate possible errors in the incoming data.
The first warning of a specified type is added as a message to the load
statistic. All warnings are also traced at level 3.
=over 4
=item errorType
Type of error indicated by the warning. This is used as the label when the
warning is counted in the statistics object.
=item message
Message describing the reason for the warning.
=back
=cut
sub AddWarning {
    my ($self, $errorType, $message) = @_;
    # Count the warning.
    my $count = $self->Add($errorType);
    # Is this the first one of this type?
    if ($count == 1) {
        # Yes, add it to the messages for the end.
        $self->{stats}->AddMessage($errorType);
    } else {
        # No, just trace it.
        Trace("Data warning: $message") if T(3);
=head3 Track
    $edbl->Track($statName => $key, $period);
Save the specified key as the one currently in progress. If an error
occurs, the key value will appear in the output log. The named statistic
will also be incremented, and if the count is an even multiple of the stated
period, a trace message will be output at level 3.
Most load groups have a primary object type that drives the main loop. When
something goes wrong, we want to know the ID of the offending object. When
things go right, we want to know how far we've progressed toward completion.
This method can be used to record each occurrence of a primary object, and
provide a log of the progress or our current position in times of stress.
=over 4
=item statName
Name of the statistic to be incremented. This should be a plural noun
describing the object whose kep is coming in.
=item key
Key value to be displayed if something goes wrong.
=item period (optional)
If specified, should be the number of objects to be counted between each
level-3 trace message.
=back
=cut
sub Track {
    my ($self, $statName, $key, $period) = @_;
    # Save the key.
    $self->{lastKey} = $key;
    # Count it.
    my $newValue = $self->{stats}->Add($statName => 1);
    # Do we need to output a progress message?
    if ($period && T(3) && ($newValue % $period == 0)) {
        # Yes.
        Trace("$newValue $statName processed for $self->{group} group.");
=head3 section
    my $sectionID = $edbl->section();
Return the ID of the current section.
=cut
sub section {
    my ($self) = @_;
    # Return the result.
    return $self->{section};
=head3 source
    my $sourceObject = $edbl->source();
Return the source object used to get the data needed for creating
the load files.
=cut
sub source {
    my ($self) = @_;
    # If we do not have a source object, retrieve it.
    if (! defined $self->{source}) {
        $self->{source} = $self->{db}->GetSourceObject();
    return $self->{source};
=head3 db
    my $erdbObject = $edbl->db();
Return the database object for the target database.
=cut
sub db {
    my ($self) = @_;
    return $self->{db};
=head2 Internal Methods
=head3 ProcessSection
    my $flag = $edbl->ProcessSection($section);
Generate the load file for a particular data section. This method calls
the virtual method L</Generate> to actually put the data into the load
files, and is responsible for assigning the section and finalizing the
load files if the load is successful.
=over 4
=item section
ID of the section to load.
=item RETURN
Returns TRUE if successful, FALSE if an error prevented loading the section.
=back
=cut
sub ProcessSection {
    my ($self, $section) = @_;
    # Declare the return variable. We'll set it to 1 if we succeed.
    # Save the section ID.
    $self->{section} = $section;
    # Get the database object.
    my $db = $self->db();
    # Start a timer and protect ourselves from errors.
    my $startTime = time();
    eval {
        # Get the list of tables for this group.
        my @tables = @{$self->{tables}};
        # Get the loader hash.
        my $loaderHash = $self->{loaders};
        # Initialize the loaders for the necessary tables.
        for my $table (@tables) {
            # Get this table's loader.
            my $loader = $loaderHash->{$table};
            # If it doesn't exist yet, create it.
            if (! defined $loader) {
                $loader = ERDBGenerate->new($db, $self->{directory}, $table, $self->{stats});
                # Save it for future use.
                $loaderHash->{$table} = $loader;
                # Count it.
                $self->Add(tables => 1);
            $loader->Start($section);
        # Generate the data to put in the newly-created load files.
        $self->Generate();
    # Did it work?
    if ($@) {
        # No, so emit an error message and abort all the loaders.
        $self->{stats}->AddMessage("Error loading section $section: $@");
        if (defined $self->{lastKey}) {
            $self->{stats}->AddMessage("Error occurred while processing \"$self->{lastKey}\".");
        $self->Add("section-errors" => 1);
        for my $loader (values %{$self->{loaders}}) {
            $loader->Abort();
    } else {
        # Yes! Finish all the loaders.
            $loader->Finish();
        # Update the load count and the timer.
        $self->Add("section-loads" => 1);
        $self->Add(duration => (time() - $startTime));
=head3 DisplayStats
    my $text = $edbl->DisplayStats();
Display the statistics for this load gorup.
=cut
sub DisplayStats {
    my ($self) = @_;
    return $self->{stats}->Show();
=head3 GetGroupHash
    my $groupHash = ERDBLoadGroup::GetGroupHash($erdb);
Return a hash that maps each load group in the specified database to its
constituent tables. This is useful when checking for problems with a load
or performing finishing tasks.
=over 4
=item erdb
[[ErdbPm]] database whose load information is desired.
=item RETURN
Returns a reference to a hash that maps each group name to a list of
table names.
=back
=cut
sub GetGroupHash {
    my ($erdb) = @_;
    # Initialize the return variable.
    my $retVal = {};
    # Loop through the list of load groups.
    for my $group ($erdb->LoadGroupList()) {
        # Stash the loader's tables in the output hash.
        $retVal->{$group} = [ GetTables($erdb, $group) ];
    return $retVal;
=head3 GetTables
    my @tables = ERDBLoadGroup::GetTables($group);
Return the list of tables belonging to the specified load group.
=over 4
=item erdb
Return the list of tables for the specified load group.
=item group
Name of relevant group.
=item RETURN
Returns a list of a tables loaded by the specified group.
=back
=cut
sub GetTables {
    my ($erdb, $group) = @_;
    # Create a loader for the specified group.
    my $loader = $erdb->Loader($group, undef, {});
    # Extract the list of tables.
    my @retVal = @{$loader->{tables}};
    return @retVal;
=head3 ComputeGroups
    my @groupList = ERDBLoadGroup::ComputeGroups($erdb, \@groups);
Compute the actual list of groups determined by the incoming group list.
=over 4
=item erdb
=item groups
Reference to a list of group names specified on the command line. A plus sign
(C<+>) has special meaning.
=item RETURN
Returns the actual list of groups to be processed by the calling command. The
names will have been normalized to capital case.
=back
=cut
sub ComputeGroups {
    my ($erdb, $groups) = @_;
    # Get the complete group list in standard order.
    my @allGroups = $erdb->LoadGroupList();
    # Create a hash for validation purposes. This will map each valid group
    # name to its position in the standard order.
    my %allGroupHash;
    for (my $i = 0; $i <= $#allGroups; $i++) {
        $allGroupHash{$allGroups[$i]} = $i;
    # This variable will be the index of the last-processed group in
    # the standard order. We start it before the first group in the list.
    my $lastI = -1;
    # The listed groups will be put in here.
    my @retVal;
    # Process the group list.
    for my $group (@$groups) {
        # Process this group.
        if ($group eq '+') {
            # Here we have a plus sign. Push in everything after the previous
            # group processed. Note that we'll be ending at the last position.
            # A second "+" after this one will generate no entries in the result
            # list.
            my $firstI = $lastI + 1;
            $lastI = $#allGroups;
            push @retVal, @allGroups[$firstI..$lastI];
        } elsif (exists $allGroupHash{$group}) {
            # Here we have a valid group name. Push it into the list.
            push @retVal, $group;
            # Remember its location in case there's a plus sign.
            $lastI = $allGroupHash{$group};
        } else {
            # This is an error.
            Confess("Invalid load group name $group.");
    # Normalize the group names and return them.
    @retVal = map { ucfirst $_ } @retVal;
    Trace("Final group list is " . join(" ", @retVal) . ".") if T(2);
    return @retVal;
=head3 KillFileName
    my $fileName = ERDBLoadGroup::KillFileName($erdb, $directory);
Compute the kill file name for the specified database in the specified
directory. When the [[ERDBGeneratorPl]] script sees the kill file, it will
terminate itself at the end of the current section.
=over 4
=item erdb
Database
=item directory (optional)
Load directory for the database.
=item RETURN
Returns the specified database's kill file name. If a directory is specified,
it is prefixed to the name with an intervening slash.
=back
=cut
sub KillFileName {
    my ($erdb, $directory) = @_;
    # Compute the kill file name. We start with the database name in
    # lower case, then prefix it with "kill_";
    my $dbName = lc ref $erdb;
    my $retVal = ERDBGenerate::CreateFileName("kill_$dbName", undef, 'control', $directory);
    return $retVal;
=head2 Virtual Methods
=head3 Generate
    $edbl->Generate();
Generate the data for this load group with respect to the current
section. This method must be overridden by the subclass and should call
the L</Put> method to put data into the tables.
=cut
sub Generate {
    Confess("Pure virtual method Generate called.");
1;
