View of /Sprout/ERDBLoad.pm
Revision 1.21 - (download) (as text) (annotate)
Wed Jan 23 00:56:31 2008 UTC (11 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_07_21, rast_rel_2008_04_23, mgrast_rel_2008_0806
#!/usr/bin/perl -w
package ERDBLoad;
    use strict;
    use Tracer;
    use PageBuilder;
    use ERDB;
    use Stats;
=head1 ERDB Table Load Utility Object
=head2 Introduction
This object is designed to assist with creating the load file for an ERDB
data relation. The user constructs the object by specifying an ERDB object
and a relation name. This create the load file for the relevant relation. The client
then passes in data lines which are written to a file, and calls
L</Finish> to close the file and get the statistics.
This module makes use of the internal ERDB method C<_IsPrimary>.
=cut
=head2 Public Methods
=head3 new
    my $erload = ERDBLoad->new($erdb, $relationName, $directory, $loadOnly, $ignore);
Begin loading an ERDB relation.
=over 4
=item erdb
ERDB object representing the target database.
=item relationName
Name of the relation being loaded.
=item directory
Name of the directory to use for the load files, WITHOUT a trailing slash.
=item loadOnly
TRUE if the data is to be loaded from an existing file, FALSE if a file is
to be created.
=item ignore
TRUE if the data is to be discarded. This is used to save time when only
a subset of the tables need to be loaded: the data for the ignored tables
is simply discarded.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $erdb, $relationName, $directory, $loadOnly, $ignore) = @_;
    # Validate the directory name.
    if (! -d $directory) {
        Confess("Load directory \"$directory\" not found.");
    # Determine the name for this relation's load file.
    my $fileName = "$directory/$relationName.dtx";
    # Declare the file handle variable.
    my $fileHandle;
    # Determine whether or not this is a primary relation.
    my $primary = ($erdb->_IsPrimary($relationName) ? 1 : 0);
    # Check to see if this is a load-only, ignore, or a generate-and-load.
    if ($ignore) {
        Trace("Relation $relationName will be ignored.") if T(2);
        $fileHandle = "";
    } elsif ($loadOnly) {
        Trace("Relation $relationName will be loaded from $fileName.") if T(2);
        $fileHandle = "";
    } else {
        # Determine the sort for this relation.
        my $fileString = "| " . $erdb->SortNeeded($relationName) . " >$fileName";
        Trace("Load file creation string is \"$fileString\".") if T(3);
        # Open the output file and remember its handle.
        $fileHandle = Open(undef, $fileString);
        Trace("Relation $relationName load file created with primary flag $primary.") if T(2);
    # Create the $erload object.
    my $retVal = {
                  dbh => $erdb,
                  fh => $fileHandle,
                  fileName => $fileName,
                  relName => $relationName,
                  fileSize => 0,
                  lineCount => 0,
                  stats => Stats->new(),
                  primary => $primary,
                  ignore => ($ignore ? 1 : 0)
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head3 Ignore
    my $flag = $erload->Ignore;
Return TRUE if we are ignoring this table, else FALSE.
=cut
#: Return Type $;
sub Ignore {
    my ($self) = @_;
    # Return the result.
    return $self->{ignore};
=head3 Put
    my  = $erload->Put($field1, $field2, ..., $fieldN);
Write a line of data to the load file. This may also cause the load file to be closed
and data read into the table.
=over 4
=item field1, field2, ..., fieldN
List of field values to be put into the data line. The field values must be in the
order determined shown in the documentation for the table. Internal tabs and
new-lines will automatically be escaped before the data line is formatted.
=back
=cut
#: Return Type ;
sub Put {
    # Get the ERDBLoad instance and the field list.
    my ($self, @rawFields) = @_;
    # Only proceed if we're not ignoring.
    if (! $self->{ignore}) {
        # Convert the hash-string fields to their digested value.
        $self->{dbh}->DigestFields($self->{relName}, \@rawFields);
        # Insure the field values are okay.
        my $truncates = $self->{dbh}->VerifyFields($self->{relName}, \@rawFields);
        # Run through the list of field values, escaping them.
        my @fields = map { Tracer::Escape($_) } @rawFields;
        # If this is a primary relation, append the new-record field.
        if ($self->{primary}) {
            push @fields, '0';
        # Form a data line from the fields.
        my $line = join("\t", @fields) . "\n";
        # Write the new record to the load file.
        my $fh = $self->{fh};
        print $fh $line;
        # Determine how long this will make the load file.
        my $lineLength = length $line;
        # Update the statistics.
        $self->{fileSize} += $lineLength;
        $self->{lineCount} ++;
        $self->Add("lineOut");
        if ($truncates > 0) {
            $self->Add("truncated", $truncates);
=head3 Add
    my  = $stats->Add($statName, $value);
Increment the specified statistic.
=over 4
=item statName
Name of the statistic to increment.
=item value (optional)
Value by which to increment it. If omitted, C<1> is assumed.
=back
=cut
#: Return Type ;
sub Add {
    my ($self, $statName, $value) = @_;
    # Fix the value.
    if (! defined $value) {
        $value = 1;
    # Increment the statistic.
    $self->{stats}->Add($statName, $value);
=head3 Finish
    my $stats = $erload->Finish();
Finish loading the table. This closes the load file.
=over 4
=item RETURN
Returns a statistics object describing what happened during the load and containing any
error messages.
=back
=cut
sub Finish {
    # Get this object instance.
    my ($self) = @_;
    if ($self->{fh}) {
        # Close the load file.
        close $self->{fh};
    # Return the statistics object.
    return $self->{stats};
=head3 FinishAndLoad
    my $stats = $erload->FinishAndLoad();
Finish the load and load the table, returning the statistics.
=cut
sub FinishAndLoad {
    my ($self) = @_;
    # Finish the load file.
    my $retVal = $self->Finish();
    # Load the table.
    my $newStats = $self->LoadTable();
    # Accumulate the stats.
    $retVal->Accumulate($newStats);
    return $retVal;
=head3 RelName
    my $name = $erload->RelName;
Name of the relation being loaded by this object.
=cut
sub RelName {
    # Get the object instance.
    my ($self) = @_;
    # Return the relation name.
    return $self->{relName};
=head3 LoadTable
    my $stats = $erload->LoadTable();
Load the database table from the load file and return a statistics object.
=cut
sub LoadTable {
    my ($self) = @_;
    # Get the database object, the file name, and the relation name.
    my $erdb = $self->{dbh};
    my $fileName = $self->{fileName};
    my $relName = $self->{relName};
    # Load the table. The third parameter indicates this is a drop and reload.
    my $retVal = $erdb->LoadTable($fileName, $relName, truncate => 1);
    return $retVal;
1;
