Log of /Sprout/ERDBLoad.pm
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Wed Jan 23 00:56:31 2008 UTC (12 years ago) by parrello
Diff to previous 1.20 , to selected 1.16
Thu Dec 6 14:58:03 2007 UTC (12 years, 1 month ago) by parrello
Diff to previous 1.19 , to selected 1.16
Fri Nov 3 00:34:10 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.18: +42 -0 lines
Diff to previous 1.18 , to selected 1.16
Added a "FinishAndLoad" to finish building the load file and then load it into the database.
Mon Jul 10 09:06:46 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.17 , to selected 1.16
Mon Jul 10 09:05:17 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.16
Added tracing.
Revision 1.16 - (view) (download) (as text) (annotate) - [selected]
Sun Jul 9 21:16:12 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.15: +2 -5 lines
Fri Jul 7 00:24:50 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.14 , to selected 1.16
Wed Jun 21 03:12:51 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.13: +1 -2 lines
Diff to previous 1.13 , to selected 1.16
Fixed a comment.
Wed Apr 19 03:34:15 2006 UTC (13 years, 9 months ago) by parrello
Diff to previous 1.12 , to selected 1.16
Thu Feb 2 21:30:05 2006 UTC (13 years, 11 months ago) by parrello
Diff to previous 1.11 , to selected 1.16
Mon Jan 30 21:56:50 2006 UTC (14 years ago) by parrello
Diff to previous 1.10 , to selected 1.16
Mon Jan 30 21:52:04 2006 UTC (14 years ago) by parrello
Changes since 1.9: +57 -27 lines
Diff to previous 1.9 , to selected 1.16
Added the ability to load a table in a discard mode that throws away the data.
Thu Jan 19 09:28:33 2006 UTC (14 years ago) by parrello
Changes since 1.8: +19 -6 lines
Diff to previous 1.8 , to selected 1.16
Fixed to automatically truncate character fields that are too long.
Fri Jan 13 06:59:28 2006 UTC (14 years ago) by parrello
Changes since 1.7: +23 -14 lines
Diff to previous 1.7 , to selected 1.16
Thu Oct 13 14:53:03 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.6 , to selected 1.16
Thu Oct 13 14:49:36 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.5 , to selected 1.16
Added more tracing.
Fixed parameter list for sort pipe.
Wed Oct 12 02:58:20 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.4 , to selected 1.16
Fixed an error in the post-processing sort that was causing spurious duplicate keys.
Sun Sep 11 17:05:57 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.3: +30 -1 lines
Diff to previous 1.3 , to selected 1.16
Changed to do a sort -u when creating entity load files.
Fri Sep 9 14:52:21 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.2: +10 -115 lines
Diff to previous 1.2 , to selected 1.16
Changed the loader to create a load file and leave it rather than creating the file, loading the data, and then deleting it.
Sun Aug 14 23:32:08 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.1: +10 -3 lines
Diff to previous 1.1 , to selected 1.16
Wed Jul 27 20:00:56 2005 UTC (14 years, 6 months ago) by parrello
Diff to selected 1.16
