Log of /Sprout/ERDBLoad.pm
Sat Sep 20 14:30:21 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.23: +49 -22 lines
Diff to previous 1.23 , to selected 1.1
Changed to skip the sort step if a file is pre-sorted, and to catch errors that occur while sorting.
Wed Sep 3 20:56:20 2008 UTC (11 years, 4 months ago) by parrello
Changes since 1.22: +28 -4 lines
Diff to previous 1.22 , to selected 1.1
Tue Aug 12 06:07:06 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.21: +0 -4 lines
Diff to previous 1.21 , to selected 1.1
Wed Jan 23 00:56:31 2008 UTC (12 years ago) by parrello
Diff to previous 1.20 , to selected 1.1
Thu Dec 6 14:58:03 2007 UTC (12 years, 1 month ago) by parrello
Diff to previous 1.19 , to selected 1.1
Fri Nov 3 00:34:10 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.18: +42 -0 lines
Diff to previous 1.18 , to selected 1.1
Added a "FinishAndLoad" to finish building the load file and then load it into the database.
Mon Jul 10 09:06:46 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.17 , to selected 1.1
Mon Jul 10 09:05:17 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.16 , to selected 1.1
Added tracing.
Sun Jul 9 21:16:12 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.15: +2 -5 lines
Diff to previous 1.15 , to selected 1.1
Fri Jul 7 00:24:50 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.14 , to selected 1.1
Wed Jun 21 03:12:51 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.13: +1 -2 lines
Diff to previous 1.13 , to selected 1.1
Fixed a comment.
Wed Apr 19 03:34:15 2006 UTC (13 years, 9 months ago) by parrello
Diff to previous 1.12 , to selected 1.1
Thu Feb 2 21:30:05 2006 UTC (13 years, 11 months ago) by parrello
Diff to previous 1.11 , to selected 1.1
Mon Jan 30 21:56:50 2006 UTC (14 years ago) by parrello
Diff to previous 1.10 , to selected 1.1
Mon Jan 30 21:52:04 2006 UTC (14 years ago) by parrello
Changes since 1.9: +57 -27 lines
Diff to previous 1.9 , to selected 1.1
Added the ability to load a table in a discard mode that throws away the data.
Thu Jan 19 09:28:33 2006 UTC (14 years ago) by parrello
Changes since 1.8: +19 -6 lines
Diff to previous 1.8 , to selected 1.1
Fixed to automatically truncate character fields that are too long.
Fri Jan 13 06:59:28 2006 UTC (14 years ago) by parrello
Changes since 1.7: +23 -14 lines
Diff to previous 1.7 , to selected 1.1
Thu Oct 13 14:53:03 2005 UTC (14 years, 3 months ago) by parrello
Diff to previous 1.6 , to selected 1.1
Thu Oct 13 14:49:36 2005 UTC (14 years, 3 months ago) by parrello
Added more tracing.
Fixed parameter list for sort pipe.
Wed Oct 12 02:58:20 2005 UTC (14 years, 3 months ago) by parrello
Fixed an error in the post-processing sort that was causing spurious duplicate keys.
Sun Sep 11 17:05:57 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.3: +30 -1 lines
Changed to do a sort -u when creating entity load files.
Fri Sep 9 14:52:21 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.2: +10 -115 lines
Changed the loader to create a load file and leave it rather than creating the file, loading the data, and then deleting it.
Sun Aug 14 23:32:08 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.1: +10 -3 lines
Wed Jul 27 20:00:56 2005 UTC (14 years, 6 months ago) by parrello
