Log of /Sprout/ERDBLoad.pm
Wed Jan 23 00:56:31 2008 UTC (12 years, 1 month ago) by parrello
Diff to previous 1.20
Thu Dec 6 14:58:03 2007 UTC (12 years, 2 months ago) by parrello
Diff to previous 1.19
Fri Nov 3 00:34:10 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.18: +42 -0 lines
Diff to previous 1.18
Added a "FinishAndLoad" to finish building the load file and then load it into the database.
Mon Jul 10 09:06:46 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.17
Mon Jul 10 09:05:17 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.16
Added tracing.
Sun Jul 9 21:16:12 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.15: +2 -5 lines
Fri Jul 7 00:24:50 2006 UTC (13 years, 7 months ago) by parrello
Wed Jun 21 03:12:51 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.13: +1 -2 lines
Fixed a comment.
Wed Apr 19 03:34:15 2006 UTC (13 years, 10 months ago) by parrello
Thu Feb 2 21:30:05 2006 UTC (14 years ago) by parrello
Mon Jan 30 21:56:50 2006 UTC (14 years ago) by parrello
Mon Jan 30 21:52:04 2006 UTC (14 years ago) by parrello
Changes since 1.9: +57 -27 lines
Added the ability to load a table in a discard mode that throws away the data.
Thu Jan 19 09:28:33 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.8: +19 -6 lines
Fixed to automatically truncate character fields that are too long.
Fri Jan 13 06:59:28 2006 UTC (14 years, 1 month ago) by parrello
Changes since 1.7: +23 -14 lines
Thu Oct 13 14:53:03 2005 UTC (14 years, 4 months ago) by parrello
Thu Oct 13 14:49:36 2005 UTC (14 years, 4 months ago) by parrello
Added more tracing.
Fixed parameter list for sort pipe.
Wed Oct 12 02:58:20 2005 UTC (14 years, 4 months ago) by parrello
Fixed an error in the post-processing sort that was causing spurious duplicate keys.
Sun Sep 11 17:05:57 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.3: +30 -1 lines
Changed to do a sort -u when creating entity load files.
Fri Sep 9 14:52:21 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.2: +10 -115 lines
Changed the loader to create a load file and leave it rather than creating the file, loading the data, and then deleting it.
Sun Aug 14 23:32:08 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.1: +10 -3 lines
Wed Jul 27 20:00:56 2005 UTC (14 years, 6 months ago) by parrello
