[Bio] / Sprout / ERDBGenerator.pl Repository:
Log of /Sprout/ERDBGenerator.pl
Wed Jul 7 19:23:41 2010 UTC (9 years, 11 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.10: +2 -1 lines
Diff to previous 1.10 , to selected 1.6
General loader improvements.
Tue Sep 8 21:30:33 2009 UTC (10 years, 8 months ago) by parrello
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Diff to previous 1.9 , to selected 1.6
Changed to allow for storing the DBD metadata in the database. This is currently only activated for Sapling.
Tue Jun 30 19:53:01 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Thu May 28 18:06:58 2009 UTC (11 years ago) by parrello
Changes since 1.7: +11 -4 lines
Thu Apr 2 01:36:27 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.6: +14 -1 lines
Added memory tracing.
Mon Mar 2 22:15:04 2009 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Fixed a heading.
Mon Jan 19 21:46:21 2009 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.4: +61 -50 lines
ERDB 2.0 support
Thu Oct 9 17:23:54 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.3: +2 -1 lines
More loading bug fixes.
Thu Oct 2 16:32:42 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.2: +26 -12 lines
Wed Oct 1 03:07:08 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.1: +40 -20 lines
Tue Sep 30 15:23:55 2008 UTC (11 years, 8 months ago) by parrello
Diff to selected 1.6
New loader technology.
