[Bio] / Sprout / ERDBExtras.pm Repository:
Log of /Sprout/ERDBExtras.pm
Sun Feb 22 03:28:31 2015 UTC (5 years, 1 month ago) by parrello
CVS Tags: HEAD
Removed Shrub stuff. Updated ERDB for compatibility with Shrub DBD.
Thu Jul 21 19:14:01 2011 UTC (8 years, 8 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +8 -1 lines
Add a bunch of modules to the SAS release for myRAST. Make use of FIG_Config optional
in places it isn't currently.
Mon Nov 1 15:12:09 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Updates for proteindata type.
Thu Oct 14 17:27:37 2010 UTC (9 years, 5 months ago) by parrello
Changes for expression vector support.
Fri Dec 11 21:21:26 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.3: +10 -1 lines
Server database recovery fix.
Wed Dec 2 00:40:54 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.2: +9 -0 lines
Added reconnection support.
Tue Jun 16 21:58:36 2009 UTC (10 years, 9 months ago) by parrello
Fixed diagram URL. Updated to use new key scheme for faster subsystem queries.
Thu May 28 18:06:58 2009 UTC (10 years, 10 months ago) by parrello
