[Bio] / Sprout / ERDB.pm Repository:
Log of /Sprout/ERDB.pm
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 23 20:43:42 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.104: +1 -1 lines
Diff to previous 1.104 , to selected 1.98
Fixed a comment.
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 22 20:33:30 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.103: +14 -2 lines
Diff to previous 1.103 , to selected 1.98
Added some new types for Sapling project
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 16 18:57:59 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.102: +0 -1 lines
Diff to previous 1.102 , to selected 1.98
Added trace messages.
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Changes since 1.101: +1 -2 lines
Diff to previous 1.101 , to selected 1.98
Changes for v24 database.
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 3 20:56:20 2008 UTC (11 years, 2 months ago) by parrello
Changes since 1.100: +8 -1 lines
Diff to previous 1.100 , to selected 1.98
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 12 06:07:06 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.99: +115 -12 lines
Diff to previous 1.99 , to selected 1.98
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 11 01:04:08 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806
Changes since 1.98: +7 -7 lines
Diff to previous 1.98
Changed so relationships appear before table definitions in the wiki output.
Revision 1.98 - (view) (download) (as text) (annotate) - [selected]
Mon Jul 7 19:05:55 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_07_21
Changes since 1.97: +66 -15 lines
Diff to previous 1.97
Added support for shapes and issue tags.
Wed May 7 23:08:19 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.96: +0 -1 lines
Diff to previous 1.96 , to selected 1.98
Tue Feb 5 04:52:24 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.95: +2 -1 lines
Diff to previous 1.95 , to selected 1.98
Added more statistics for the load.
Wed Jan 23 00:56:31 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.94: +276 -15 lines
Diff to previous 1.94 , to selected 1.98
Changes since 1.93: +84 -83 lines
Diff to previous 1.93 , to selected 1.98
Mon Jul 16 20:04:50 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.92: +3 -2 lines
Diff to previous 1.92 , to selected 1.98
Mon Jun 11 18:51:23 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.91: +3 -3 lines
Diff to previous 1.91 , to selected 1.98
Fixed some comments so they will be applicable to the new E-R model. Added more useful data to an error message.
Wed May 2 05:51:48 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.90: +68 -0 lines
Diff to previous 1.90 , to selected 1.98
Added a new method for multiple-row deletion.
Fri Apr 27 22:19:49 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.89: +85 -8 lines
Diff to previous 1.89 , to selected 1.98
Added a new method for mass field updates. Removed a dependency on FIG. Fixed a bug in the XML-PPO conversion.
Thu Apr 12 05:59:41 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.88: +221 -0 lines
Diff to previous 1.88 , to selected 1.98
Added CreatePPO method.
Tue Apr 10 05:54:18 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.87: +5 -5 lines
Diff to previous 1.87 , to selected 1.98
Sun Feb 18 21:28:19 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.86: +93 -13 lines
Diff to previous 1.86 , to selected 1.98
Added alternate indexes on relationships. Added support for database transactions.
Mon Feb 12 19:23:32 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.85: +13 -10 lines
Diff to previous 1.85 , to selected 1.98
Changed the comments to allow for a planned enhancement in index formation.
Fri Feb 9 22:59:53 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.84: +2 -0 lines
Diff to previous 1.84 , to selected 1.98
Added more tracing.
Wed Jan 24 10:22:22 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.83: +1 -0 lines
Diff to previous 1.83 , to selected 1.98
Added tracing.
Mon Jan 22 20:23:58 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.82: +24 -18 lines
Diff to previous 1.82 , to selected 1.98
Fixed some XHTML violations and formatting glitches in the documentation generator.
Tue Jan 9 01:49:57 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.81: +38 -13 lines
Diff to previous 1.81 , to selected 1.98
Added methods to make it easier to reload text search indexes.
Wed Dec 20 20:03:25 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.80: +4 -1 lines
Diff to previous 1.80 , to selected 1.98
Fixed a bug that caused an error attempting to load the text search index.
Thu Nov 30 23:04:01 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.79: +1 -1 lines
Diff to previous 1.79 , to selected 1.98
Fixed keyword searcher to make quoted strings required rather than optional.
Wed Nov 29 20:29:53 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.78: +55 -0 lines
Diff to previous 1.78 , to selected 1.98
Fixed a bug in the delete methods.
Tue Nov 28 01:02:42 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.77: +249 -34 lines
Diff to previous 1.77 , to selected 1.98
Added some methods to support the new attribute system.
Mon Nov 20 05:53:02 2006 UTC (13 years ago) by parrello
Changes since 1.76: +6 -5 lines
Diff to previous 1.76 , to selected 1.98
Fixed some comments.
Wed Nov 15 12:08:26 2006 UTC (13 years ago) by parrello
Changes since 1.75: +17 -5 lines
Diff to previous 1.75 , to selected 1.98
Modified the DeleteValue method to allow for deleting all values of a specified field.
Thu Nov 9 21:21:49 2006 UTC (13 years ago) by parrello
Changes since 1.74: +205 -27 lines
Diff to previous 1.74 , to selected 1.98
Added support for indexes on text fields. Changed the index names to make them shorter. Added the ability to list all the secondary fields (which in the attribute database lists all the attribute keys. Enabled underscore as an alternative to hyphen in field names.
Fri Nov 3 16:49:44 2006 UTC (13 years ago) by parrello
Changes since 1.73: +73 -2 lines
Diff to previous 1.73 , to selected 1.98
Fixed some comments. Added tracing. Created new method for finding secondary indexes in the XML.
Fri Nov 3 00:33:26 2006 UTC (13 years ago) by parrello
Changes since 1.72: +404 -552 lines
Diff to previous 1.72 , to selected 1.98
Removed the never-implemented data generation stuff. Added support for special field attributes. Added support for methods that manipulate the XML.
Mon Oct 16 07:44:41 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.71: +7 -2 lines
Diff to previous 1.71 , to selected 1.98
Added support for full text searches.
Sat Oct 14 18:08:12 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.70: +42 -1 lines
Diff to previous 1.70 , to selected 1.98
Made keyword cleaning a virtual method that can be overridden.
Fri Oct 13 21:45:11 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.69: +386 -185 lines
Diff to previous 1.69 , to selected 1.98
Fri Sep 29 15:06:17 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.68: +55 -0 lines
Diff to previous 1.68 , to selected 1.98
Added a method for finding all represented values of a field.
Tue Sep 19 00:12:21 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.67: +2 -1 lines
Diff to previous 1.67 , to selected 1.98
Fixed a comment.
Fri Jul 14 01:36:29 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.66: +11 -16 lines
Diff to previous 1.66 , to selected 1.98
Removed unique-key support from "SortNeeded" since it doesn't work anyway.
Thu Jul 13 04:53:54 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.65: +4 -0 lines
Diff to previous 1.65 , to selected 1.98
Fixed a bug in the table row counter.
Tue Jul 11 06:10:41 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.64: +0 -2 lines
Diff to previous 1.64 , to selected 1.98
Removed the flush_tables command from the load process.
Mon Jul 10 10:04:41 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.63: +1 -1 lines
Diff to previous 1.63 , to selected 1.98
Maybe this one will work.
Mon Jul 10 09:46:38 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.62 , to selected 1.98
The specification of the field separator got goofy.
Mon Jul 10 09:42:34 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.61: +4 -2 lines
Diff to previous 1.61 , to selected 1.98
Fixed a bug in the sort analyzer.
Mon Jul 10 09:05:17 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.60: +2 -0 lines
Diff to previous 1.60 , to selected 1.98
Added tracing.
Sun Jul 9 21:16:12 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.59: +93 -22 lines
Diff to previous 1.59 , to selected 1.98
Fri Jul 7 00:24:50 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.58: +1 -6 lines
Diff to previous 1.58 , to selected 1.98
Wed Jun 28 22:22:42 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.57: +2 -0 lines
Diff to previous 1.57 , to selected 1.98
Fixed to flush the tables after a MySQL table load.
Sun Jun 25 18:02:04 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.56 , to selected 1.98
Fixed a comment.
Sun Jun 25 02:36:35 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.55: +1 -1 lines
Diff to previous 1.55 , to selected 1.98
Fixed a comment.
Sat Jun 24 23:49:10 2006 UTC (13 years, 5 months ago) by parrello
Diff to previous 1.54 , to selected 1.98
Moved "Exists" method from the Sprout object.
Sat Jun 24 15:55:37 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.53: +1 -0 lines
Diff to previous 1.53 , to selected 1.98
Added more tracing to GetAll.
Fri Jun 23 23:04:55 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.52: +1 -1 lines
Diff to previous 1.52 , to selected 1.98
Fri Jun 23 23:03:40 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.51: +1 -1 lines
Diff to previous 1.51 , to selected 1.98
Fri Jun 23 22:53:08 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.50: +63 -0 lines
Diff to previous 1.50 , to selected 1.98
Added a method for inserting new values into secondary relations.
Wed Jun 21 03:38:36 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.49: +2 -3 lines
Diff to previous 1.49 , to selected 1.98
Fixed a bug in the ParseLine method.
Wed Jun 21 03:36:03 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.48: +1 -0 lines
Diff to previous 1.48 , to selected 1.98
Added some tracing.
Wed Jun 21 03:12:20 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.47: +92 -0 lines
Diff to previous 1.47 , to selected 1.98
Added some helper methods for data mining.
Sun Jun 18 05:14:56 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.46: +12 -2 lines
Diff to previous 1.46 , to selected 1.98
Upgraded "GetCount" so that it can count relationship records as well as entity records.
Thu Jun 8 19:42:06 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.45: +34 -1 lines
Diff to previous 1.45 , to selected 1.98
Added a method to compute a digested key.
Tue Jun 6 05:05:15 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.44: +484 -232 lines
Diff to previous 1.44 , to selected 1.98
Modified interface for Sprout compatability. Added a method to return a count of records in a table. Split ShowMetaData into a method that writes a full web page and another that returns the page contents.
Sat May 27 02:02:28 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.43: +6 -0 lines
Diff to previous 1.43 , to selected 1.98
Added support for shorter string keys.
Mon May 15 20:01:35 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.42: +2 -1 lines
Diff to previous 1.42 , to selected 1.98
Fixed a bug in the SortNeeded method.
Changes since 1.41: +93 -0 lines
Diff to previous 1.41 , to selected 1.98
Wed Mar 29 20:51:37 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.40: +3 -3 lines
Diff to previous 1.40 , to selected 1.98
Cleaned up some trace messages.
Wed Mar 29 20:03:05 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.39: +3 -0 lines
Diff to previous 1.39 , to selected 1.98
Added some trace messages.
Sun Mar 26 17:24:55 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.38: +119 -31 lines
Diff to previous 1.38 , to selected 1.98
Enhanced to enable objects to appear more than once in a single Get call.
Fri Mar 17 22:02:03 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.37: +91 -30 lines
Diff to previous 1.37 , to selected 1.98
Added a method for retrieving the field names that are useful when crossing a relationship.
Mon Jan 30 04:04:32 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.36: +3 -6 lines
Diff to previous 1.36 , to selected 1.98
Fixed the Delete method to account for the database-dependent syntax.
Mon Jan 30 03:46:34 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.35: +3 -3 lines
Diff to previous 1.35 , to selected 1.98
Fixed some bugs in the Delete method.
Sat Jan 28 09:57:43 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.34: +2 -4 lines
Diff to previous 1.34 , to selected 1.98
Sat Jan 28 09:54:12 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.33: +5 -0 lines
Diff to previous 1.33 , to selected 1.98
Sat Jan 28 09:36:47 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.32: +54 -53 lines
Diff to previous 1.32 , to selected 1.98
Bug fixes to the delete method.
Sat Jan 28 08:58:53 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.31: +167 -0 lines
Diff to previous 1.31 , to selected 1.98
Added a method for deleting objects.
Thu Jan 19 09:28:11 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.30: +56 -1 lines
Diff to previous 1.30 , to selected 1.98
Added a method to validate proposed field contents.
Wed Jan 11 19:39:03 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.29: +22 -13 lines
Diff to previous 1.29 , to selected 1.98
Changed to use the LIMIT feature to limit rows during queries.
Fri Jan 6 20:34:19 2006 UTC (13 years, 10 months ago) by parrello
Diff to previous 1.28 , to selected 1.98
Prettied a line of code.
Thu Oct 20 09:31:02 2005 UTC (14 years, 1 month ago) by parrello
Diff to previous 1.27 , to selected 1.98
Removed bogus "records" value from the statistics generated by a table load.
Tue Oct 18 06:52:35 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.26: +2 -3 lines
Diff to previous 1.26 , to selected 1.98
Enhanced tracing for debugging of database queries.
Tue Oct 18 06:47:46 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.25: +1 -0 lines
Diff to previous 1.25 , to selected 1.98
Enhanced tracing.
Thu Oct 13 01:16:47 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.24: +0 -4 lines
Diff to previous 1.24 , to selected 1.98
Turned off transactioning, which was causing problems.
Wed Oct 12 02:56:04 2005 UTC (14 years, 1 month ago) by parrello
Changes since 1.23: +9 -2 lines
Diff to previous 1.23 , to selected 1.98
Fixed the bug that was causing the spruious AutoCommit warning.
Changed to confess with an error if an error occurs creating an index.
Thu Sep 15 01:46:56 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.22: +13 -37 lines
Diff to previous 1.22 , to selected 1.98
Changed LoadTables and CreateTables to use the GetTableNames method.
Wed Sep 14 09:56:58 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.21: +6 -3 lines
Diff to previous 1.21 , to selected 1.98
Fixed misleading trace messages.
Tue Sep 13 18:32:02 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.20: +8 -8 lines
Diff to previous 1.20 , to selected 1.98
Tuned some trace messages.
Sun Sep 11 17:02:33 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.19: +30 -60 lines
Diff to previous 1.19 , to selected 1.98
Changed to load tables in a single pass.
Fri Sep 9 14:50:58 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.18: +9 -1 lines
Diff to previous 1.18 , to selected 1.98
Changes since 1.17: +89 -38 lines
Diff to previous 1.17 , to selected 1.98
Wed Jul 27 20:00:00 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.16: +10 -10 lines
Diff to previous 1.16 , to selected 1.98
Changed the trace level on some error messages.
Tue Jun 28 23:51:06 2005 UTC (14 years, 4 months ago) by olson
Diff to previous 1.15 , to selected 1.98
Need to vacuum outside the transaction.
Tue Jun 28 21:33:47 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.14: +1 -0 lines
Diff to previous 1.14 , to selected 1.98
Added a trace message that identifies the XML file used.
Mon Jun 27 15:41:24 2005 UTC (14 years, 4 months ago) by olson
Diff to previous 1.13 , to selected 1.98
Careful, "use packagename" is case sensitive on non-mac and non-windows.
Fri Jun 24 21:44:54 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.12 , to selected 1.98
Changed to analyze tables for performance data after loading.
Fri Jun 24 18:31:52 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.11: +8 -4 lines
Diff to previous 1.11 , to selected 1.98
Change to make the TO index unique for one-to-many relationships.
Thu Jun 23 21:24:49 2005 UTC (14 years, 5 months ago) by overbeek
Diff to previous 1.10 , to selected 1.98
finally
Wed Jun 22 21:29:28 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.9: +1498 -1489 lines
Diff to previous 1.9 , to selected 1.98
Replaced tabs with spaces for device-independent indenting.
Fixed some of the POD documentation.
Thu Jun 16 19:08:59 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.8: +26 -11 lines
Diff to previous 1.8 , to selected 1.98
Changed to detect and handle an improper number of fields during a table load.
Thu Jun 9 19:06:55 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.7: +228 -3 lines
Diff to previous 1.7 , to selected 1.98
Thu May 5 03:14:03 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.6: +88 -3 lines
Diff to previous 1.6 , to selected 1.98
Wed May 4 03:24:43 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.5: +202 -25 lines
Diff to previous 1.5 , to selected 1.98
Tue Apr 5 05:17:01 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.4: +10 -5 lines
Diff to previous 1.4 , to selected 1.98
Fri Feb 25 18:41:45 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.3: +21 -38 lines
Diff to previous 1.3 , to selected 1.98
no message
Wed Jan 26 22:26:09 2005 UTC (14 years, 9 months ago) by parrello
Diff to previous 1.2 , to selected 1.98
no message
Tue Jan 25 01:00:20 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.1: +19 -14 lines
Diff to previous 1.1 , to selected 1.98
no message
Sun Jan 23 16:12:29 2005 UTC (14 years, 10 months ago) by parrello
Diff to selected 1.98
no message
