[Bio] / Sprout / ERDB.pm Repository:
Diff of /Sprout/ERDB.pm
revision 1.83, Mon Jan 22 20:23:58 2007 UTC revision 1.84, Wed Jan 24 10:22:22 2007 UTC
# Line 1845  Line 1845
1845          for my $dir ('from', 'to') {          for my $dir ('from', 'to') {
1846              if ($structure->{$dir} eq $originEntityName) {              if ($structure->{$dir} eq $originEntityName) {
1847                  # Delete all relationship instances on this side of the entity instance.                  # Delete all relationship instances on this side of the entity instance.
1848                    Trace("Disconnecting in $dir direction with ID \"$originEntityID\".");
1849                  $dbh->SQL("DELETE FROM $relationshipName WHERE ${dir}_link = ?", 0, $originEntityID);                  $dbh->SQL("DELETE FROM $relationshipName WHERE ${dir}_link = ?", 0, $originEntityID);
1850                  $found = 1;                  $found = 1;
1851              }              }
Legend:
Removed from v.1.83
changed lines
  Added in v.1.84
