[Bio] / Sprout / ERDB.pm Repository:
View of /Sprout/ERDB.pm
Revision 1.103 - (download) (as text) (annotate)
Tue Sep 16 18:57:59 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_0919, mgrast_rel_2008_0917
Changes since 1.102: +0 -1 lines
Added trace messages.
package ERDB;
    use strict;
    use Tracer;
    use DBrtns;
    use Data::Dumper;
    use XML::Simple;
    use DBQuery;
    use ERDBObject;
    use Stats;
    use Time::HiRes qw(gettimeofday);
    use Digest::MD5 qw(md5_base64);
    use CGI;
    use WikiTools;
=head1 Entity-Relationship Database Package
=head2 Introduction
The Entity-Relationship Database Package allows the client to create an easily-configurable
database of Entities connected by Relationships. Each entity is represented by one or more
relations in an underlying SQL database. Each relationship is represented by a single
relation that connects two entities.
Although this package is designed for general use, all examples are derived from the
Sprout database, which is the first database implemented using this package.
Each entity has at least one relation, the I<primary relation>, that has the same name as
the entity. The primary relation contains a field named C<id> that contains the unique
identifier of each entity instance. An entity may have additional relations that contain
fields which are optional or can occur more than once. For example, the B<FEATURE> entity
has a B<feature-type> attribute that occurs exactly once for each feature. This attribute
is implemented by a C<feature_type> column in the primary relation C<Feature>. In addition,
however, a feature may have zero or more aliases. These are implemented using a C<FeatureAlias>
relation that contains two fields-- the feature ID (C<id>) and the alias name (C<alias>).
The B<FEATURE> entity also contains an optional virulence number. This is implemented
as a separate relation C<FeatureVirulence> which contains an ID (C<id>) and a virulence number
(C<virulence>). If the virulence of a feature I<ABC> is known to be 6, there will be one row in
the C<FeatureVirulence> relation possessing the value I<ABC> as its ID and 6 as its virulence
number. If the virulence of I<ABC> is not known, there will not be any rows for it in
C<FeatureVirulence>.
Entities are connected by binary relationships implemented using single relations possessing the
same name as the relationship itself and that has an I<arity> of 1-to-1 (C<11>), 1-to-many (C<1M>),
or many-to-many (C<MM>). Each relationship's relation contains a C<from-link> field that contains the
ID of the source entity and a C<to-link> field that contains the ID of the target entity. The name
of the relationship is generally a verb phrase with the source entity as the subject and the
target entity as the object. So, for example, the B<ComesFrom> relationship connects the B<GENOME>
and B<SOURCE> entities, and indicates that a particular source organization participated in the
mapping of the genome. A source organization frequently participates in the mapping
of many genomes, and many source organizations can cooperate in the mapping of a single genome, so
this relationship has an arity of many-to-many (C<MM>). The relation that implements the B<ComesFrom>
relationship is called C<ComesFrom> and contains two fields-- C<from-link>, which contains a genome ID,
and C<to-link>, which contains a source ID.
A relationship may itself have attributes. These attributes, known as I<intersection data attributes>,
are implemented as additional fields in the relationship's relation. So, for example, the
B<IsMadeUpOf> relationship connects the B<Contig> entity to the B<Sequence> entity, and is used
to determine which sequences make up a contig. The relationship has as an attribute the
B<start-position>, which indicates where in the contig that the sequence begins. This attribute
is implemented as the C<start_position> field in the C<IsMadeUpOf> relation.
The database itself is described by an XML file. In addition to all the data required to define
the entities, relationships, and attributes, the schema provides space for notes describing
the data and what it means. These notes are used by L</ShowMetaData> to generate documentation
for the database.
Special support is provided for text searching. An entity field can be marked as <em>searchable</em>,
in which case it will be used to generate a text search index in which the user searches for words
in the field instead of a particular field value.
Finally, every entity and relationship object has a flag indicating if it is new or old. The object
is considered I<old> if it was loaded by the L</LoadTables> method. It is considered I<new> if it
was inserted by the L</InsertObject> method.
=head2 XML Database Description
=head3 Data Types
The ERDB system supports the following data types. Note that there are numerous string
types depending on the maximum length. Some database packages limit the total number of
characters you have in an index key; to insure the database works in all environments,
the type of string should be the shortest one possible that supports all the known values.
=over 4
=item char
single ASCII character
=item int
32-bit signed integer
=item counter
32-bit unsigned integer
=item date
64-bit unsigned integer, representing a PERL date/time value
=item text
long string; Text fields cannot be used in indexes or sorting and do not support the
normal syntax of filter clauses, but can be up to a billion character in length
=item float
double-precision floating-point number
=item boolean
single-bit numeric value; The value is stored as a 16-bit signed integer (for
compatability with certain database packages), but the only values supported are
0 and 1.
=item id-string
variable-length string, maximum 25 characters
=item key-string
variable-length string, maximum 40 characters
=item name-string
variable-length string, maximum 80 characters
=item medium-string
variable-length string, maximum 160 characters
=item string
variable-length string, maximum 255 characters
=item hash-string
variable-length string, maximum 22 characters
=back
The hash-string data type has a special meaning. The actual key passed into the loader will
be a string, but it will be digested into a 22-character MD5 code to save space. Although the
MD5 algorithm is not perfect, it is extremely unlikely two strings will have the same
digest. Therefore, it is presumed the keys will be unique. When the database is actually
in use, the hashed keys will be presented rather than the original values. For this reason,
they should not be used for entities where the key is meaningful.
=head3 Global Tags
The entire database definition must be inside a B<Database> tag. The display name of
the database is given by the text associated with the B<Title> tag. The display name
is only used in the automated documentation. It has no other effect. The entities and
relationships are listed inside the B<Entities> and B<Relationships> tags,
respectively. None of these tags have attributes.
    <Database>
        <Title>... display title here...</Title>
        <Entities>
            ... entity definitions here ...
        </Entities>
        <Relationships>
            ... relationship definitions here...
        </Relationships>
    </Database>
Entities, relationships, indexes, and fields all allow a text tag called B<Notes>.
The text inside the B<Notes> tag contains comments that will appear when the database
documentation is generated. Within a B<Notes> tag, you may use C<[i]> and C<[/i]> for
italics, C<[b]> and C<[/b]> for bold, and C<[p]> for a new paragraph.
=head3 Fields
Both entities and relationships have fields described by B<Field> tags. A B<Field>
tag can have B<Notes> associated with it. The complete set of B<Field> tags for an
object mus be inside B<Fields> tags.
    <Entity ... >
        <Fields>
            ... Field tags ...
        </Fields>
    </Entity>
The attributes for the B<Field> tag are as follows.
=over 4
=item name
Name of the field. The field name should contain only letters, digits, and hyphens (C<->),
and the first character should be a letter. Most underlying databases are case-insensitive
with the respect to field names, so a best practice is to use lower-case letters only. Finally,
the name C<search-relevance> has special meaning for full-text searches and should not be
used as a field name.
=item type
Data type of the field. The legal data types are given above.
=item relation
Name of the relation containing the field. This should only be specified for entity
fields. The ERDB system does not support optional fields or multi-occurring fields
in the primary relation of an entity. Instead, they are put into secondary relations.
So, for example, in the C<Genome> entity, the C<group-name> field indicates a special
grouping used to select a subset of the genomes. A given genome may not be in any
groups or may be in multiple groups. Therefore, C<group-name> specifies a relation
value. The relation name specified must be a valid table name. By convention, it is
usually the entity name followed by a qualifying word (e.g. C<GenomeGroup>). In an
entity, the fields without a relation attribute are said to belong to the
I<primary relation>. This relation has the same name as the entity itself.
=item searchable
If specified, then the field is a candidate for full-text searching. A single full-text
index will be created for each relation with at least one searchable field in it.
For best results, this option should only be used for string or text fields.
=item special
This attribute allows the subclass to assign special meaning for certain fields.
The interpretation is up to the subclass itself. Currently, only entity fields
can have this attribute.
=back
=head3 Indexes
An entity can have multiple alternate indexes associated with it. The fields in an
index must all be from the same relation. The alternate indexes assist in searching
on fields other than the entity ID. A relationship has at least two indexes-- a I<to-index> and a
I<from-index> that order the results when crossing the relationship. For
example, in the relationship C<HasContig> from C<Genome> to C<Contig>, the
from-index would order the contigs of a ganome, and the to-index would order
the genomes of a contig. In addition, it can have zero or more alternate
indexes. A relationship's index must specify only fields in
the relationship.
The alternate indexes for an entity or relationship must be listed inside the B<Indexes> tag.
The from-index of a relationship is specified using the B<FromIndex> tag; the to-index is
specified using the B<ToIndex> tag.
Each index can contain a B<Notes> tag. In addition, it will have an B<IndexFields>
tag containing the B<IndexField> tags. These specify, in order, the fields used in
the index. The attributes of an B<IndexField> tag are as follows.
=over 4
=item name
Name of the field.
=item order
Sort order of the field-- C<ascending> or C<descending>.
=back
The B<FromIndex>, and B<ToIndex> tags have no attributes. The B<Index> tag can
have a B<Unique> attribute. If specified, the index will be generated as a unique
index.
=head3 Object and Field Names
By convention entity and relationship names use capital casing (e.g. C<Genome> or
C<HasRegionsIn>. Most underlying databases, however, are aggressively case-insensitive
with respect to relation names, converting them internally to all-upper case or
all-lower case.
If syntax or parsing errors occur when you try to load or use an ERDB database, the
most likely reason is that one of your objects has an SQL reserved word as its name.
The list of SQL reserved words keeps increasing; however, most are unlikely to show
up as a noun or declarative verb phrase. The exceptions are C<Group>, C<User>,
C<Table>, C<Index>, C<Object>, C<Date>, C<Number>, C<Update>, C<Time>, C<Percent>,
C<Memo>, C<Order>, and C<Sum>. This problem can crop up in field names as well.
Every entity has a field called C<id> that acts as its primary key. Every relationship
has fields called C<from-link> and C<to-link> that contain copies of the relevant
entity IDs. These are essentially ERDB's reserved words, and should not be used
for user-defined field names.
=head3 Entities
An entity is described by the B<Entity> tag. The entity can contain B<Notes>, an
B<Indexes> tag containing one or more secondary indexes, and a B<Fields> tag
containing one or more fields. The attributes of the B<Entity> tag are as follows.
=over 4
=item name
Name of the entity. The entity name, by convention, uses capital casing (e.g. C<Genome>
or C<GroupBlock>) and should be a noun or noun phrase.
=item keyType
Data type of the primary key. The primary key is always named C<id>.
=back
=head3 Relationships
A relationship is described by the C<Relationship> tag. Within a relationship,
there can be a C<Notes> tag, a C<Fields> tag containing the intersection data
fields, a C<FromIndex> tag containing the from-index, a C<ToIndex> tag containing
the to-index, and an C<Indexes> tag containing the alternate indexes.
The C<Relationship> tag has the following attributes.
=over 4
=item name
Name of the relationship. The relationship name, by convention, uses capital casing
(e.g. C<ContainsRegionIn> or C<HasContig>), and should be a declarative verb
phrase, designed to fit between the from-entity and the to-entity (e.g.
Block C<ContainsRegionIn> Genome).
=item from
Name of the entity from which the relationship starts.
=item to
Name of the entity to which the relationship proceeds.
=item arity
Relationship type: C<1M> for one-to-many and C<MM> for many-to-many.
=back
=cut
# GLOBALS
# Table of information about our datatypes. "sqlType" is the corresponding SQL datatype string.
# "maxLen" is the maximum permissible length of the incoming string data used to populate a field
# of the specified type. "avgLen" is the average byte length for estimating
# record sizes. "sort" is the key modifier for the sort command, "notes" is a type description,
# and "indexMod", if non-zero, is the number of characters to use when the field is specified in an
# index
my %TypeTable = ( char =>    { sqlType => 'CHAR(1)',            maxLen => 1,            avgLen =>   1, sort => "",
                               indexMod =>   0, notes => "single ASCII character"},
                  int =>     { sqlType => 'INTEGER',            maxLen => 20,           avgLen =>   4, sort => "n",
                               indexMod =>   0, notes => "signed 32-bit integer"},
                  counter => { sqlType => 'INTEGER UNSIGNED',   maxLen => 20,           avgLen =>   4, sort => "n",
                               indexMod =>   0, notes => "unsigned 32-bit integer"},
                  string =>  { sqlType => 'VARCHAR(255)',       maxLen => 255,          avgLen => 100, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 255 characters"},
                  text =>    { sqlType => 'TEXT',               maxLen => 1000000000,   avgLen => 500, sort => "",
                               indexMod => 255, notes => "character string, nearly unlimited length, only first 255 characters are indexed"},
                  date =>    { sqlType => 'BIGINT',             maxLen => 80,           avgLen =>   8, sort => "n",
                               indexMod =>   0, notes => "signed, 64-bit integer"},
                  float =>   { sqlType => 'DOUBLE PRECISION',   maxLen => 40,           avgLen =>   8, sort => "g",
                               indexMod =>   0, notes => "64-bit double precision floating-point number"},
                  boolean => { sqlType => 'SMALLINT',           maxLen => 1,            avgLen =>   1, sort => "n",
                               indexMod =>   0, notes => "boolean value: 0 if false, 1 if true"},
                 'hash-string' =>
                             { sqlType => 'VARCHAR(22)',        maxLen => 22,           avgLen =>  22, sort => "",
                               indexMod =>   0, notes => "string stored in digested form, used for certain types of key fields"},
                 'id-string' =>
                             { sqlType => 'VARCHAR(25)',        maxLen => 25,           avgLen =>  25, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 25 characters"},
                 'key-string' =>
                             { sqlType => 'VARCHAR(40)',        maxLen => 40,           avgLen =>  10, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 40 characters"},
                 'name-string' =>
                             { sqlType => 'VARCHAR(80)',        maxLen => 80,           avgLen =>  40, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 80 characters"},
                 'medium-string' =>
                             { sqlType => 'VARCHAR(160)',       maxLen => 160,          avgLen =>  40, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 160 characters"},
                 'long-string' =>
                             { sqlType => 'VARCHAR(500)',       maxLen => 500,          avglen => 255, sort => "",
                               indexMod =>   0, notes => "character string, 0 to 500 characters"},
# Table translating arities into natural language.
my %ArityTable = ( '11' => 'one-to-one',
                   '1M' => 'one-to-many',
                   'MM' => 'many-to-many'
# Options for XML input and output.
my %XmlOptions = (GroupTags =>  { Relationships => 'Relationship',
                                  Entities => 'Entity',
                                  Fields => 'Field',
                                  Indexes => 'Index',
                                  IndexFields => 'IndexField',
                                  Issues => 'Issue',
                                  Shapes => 'Shape'
                  KeyAttr =>    { Relationship => 'name',
                                  Entity => 'name',
                                  Field => 'name',
                                  Shape => 'name'
                  SuppressEmpty => 1,
my %XmlInOpts  = (
                  ForceArray => [qw(Field Index IndexField Relationship Entity Shape)],
                  ForceContent => 1,
                  NormalizeSpace => 2,
my %XmlOutOpts = (
                  RootName => 'Database',
                  XMLDecl => 1,
=head2 Public Methods
=head3 new
    my $database = ERDB->new($dbh, $metaFileName);
Create a new ERDB object.
=over 4
=item dbh
DBKernel database object for the target database.
=item metaFileName
Name of the XML file containing the metadata.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $dbh, $metaFileName, %options) = @_;
    # Load the meta-data.
    my $metaData = _LoadMetaData($metaFileName);
    # Create the object.
    my $self = { _dbh => $dbh,
                 _metaData => $metaData
    # Bless and return it.
    bless $self, $class;
    return $self;
=head3 ShowMetaData
    $erdb->ShowMetaData($fileName);
This method outputs a description of the database. This description can be used to help users create
the data to be loaded into the relations.
=over 4
=item filename
The name of the output file.
=back
=cut
sub ShowMetaData {
    my ($self, $filename) = @_;
    # Get the metadata and the title string.
    my $metadata = $self->{_metaData};
    # Get the title string.
    my $title = $metadata->{Title};
    # Get the entity and relationship lists.
    my $entityList = $metadata->{Entities};
    my $relationshipList = $metadata->{Relationships};
    # Open the output file.
    open(HTMLOUT, ">$filename") || Confess("Could not open MetaData display file $filename: $!");
    Trace("Building MetaData table of contents.") if T(4);
    # Write the HTML heading stuff.
    print HTMLOUT "<html>\n<head>\n<title>$title</title>\n";
    print HTMLOUT "</head>\n<body>\n";
    # Write the documentation.
    print HTMLOUT $self->DisplayMetaData();
    # Close the document.
    print HTMLOUT "</body>\n</html>\n";
    # Close the file.
    close HTMLOUT;
=head3 DisplayMetaData
    my $html = $erdb->DisplayMetaData();
Return an HTML description of the database. This description can be used to help users create
the data to be loaded into the relations and form queries. The output is raw includable HTML
without any HEAD or BODY tags.
=over 4
=item filename
=back
=cut
sub DisplayMetaData {
    my ($self) = @_;
    my $retVal = "";
    # Here we do the table of contents. It starts as an unordered list of section names. Each
    # section contains an ordered list of entity or relationship subsections.
    $retVal .= "<ul>\n<li><a href=\"#EntitiesSection\">Entities</a>\n<ol>\n";
    # Loop through the Entities, displaying a list item for each.
    foreach my $key (sort keys %{$entityList}) {
        # Display this item.
        $retVal .= "<li><a href=\"#$key\">$key</a></li>\n";
    # Close off the entity section and start the relationship section.
    $retVal .= "</ol></li>\n<li><a href=\"#RelationshipsSection\">Relationships</a>\n<ol>\n";
    # Loop through the Relationships.
    foreach my $key (sort keys %{$relationshipList}) {
        my $relationshipTitle = _ComputeRelationshipSentence($key, $relationshipList->{$key});
        $retVal .= "<li><a href=\"#$key\">$relationshipTitle</a></li>\n";
    # Close off the relationship section and list the join table section.
    $retVal .= "</ol></li>\n<li><a href=\"#JoinTable\">Join Table</a></li>\n";
    # Close off the table of contents itself.
    $retVal .=  "</ul>\n";
    # Now we start with the actual data. Denote we're starting the entity section.
    $retVal .= "<a name=\"EntitiesSection\"></a><h2>Entities</h2>\n";
    # Loop through the entities.
    for my $key (sort keys %{$entityList}) {
        Trace("Building MetaData entry for $key entity.") if T(4);
        # Create the entity header. It contains a bookmark and the entity name.
        $retVal .= "<a name=\"$key\"></a><h3>$key</h3>\n";
        # Get the entity data.
        my $entityData = $entityList->{$key};
        # If there's descriptive text, display it.
        if (my $notes = $entityData->{Notes}) {
            $retVal .= "<p>" . HTMLNote($notes->{content}) . "</p>\n";
        # See if we need a list of the entity's relationships.
        my $relCount = keys %{$relationshipList};
        if ($relCount > 0) {
            # First, we set up the relationship subsection.
            $retVal .= "<h4>Relationships for <b>$key</b></h4>\n<ul>\n";
            # Loop through the relationships.
            for my $relationship (sort keys %{$relationshipList}) {
                # Get the relationship data.
                my $relationshipStructure = $relationshipList->{$relationship};
                # Only use the relationship if if has this entity in its FROM or TO fields.
                if ($relationshipStructure->{from} eq $key || $relationshipStructure->{to} eq $key) {
                    # Get the relationship sentence and append the arity.
                    my $relationshipDescription = _ComputeRelationshipSentence($relationship, $relationshipStructure);
                    # Display the relationship data.
                    $retVal .= "<li><a href=\"#$relationship\">$relationshipDescription</a></li>\n";
            # Close off the relationship list.
        # Get the entity's relations.
        my $relationList = $entityData->{Relations};
        # Create a header for the relation subsection.
        $retVal .= "<h4>Relations for <b>$key</b></h4>\n";
        # Loop through the relations, displaying them.
        for my $relation (sort keys %{$relationList}) {
            my $htmlString = _ShowRelationTable($relation, $relationList->{$relation});
            $retVal .= $htmlString;
    # Denote we're starting the relationship section.
    $retVal .= "<a name=\"RelationshipsSection\"></a><h2>Relationships</h2>\n";
    for my $key (sort keys %{$relationshipList}) {
        Trace("Building MetaData entry for $key relationship.") if T(4);
        # Get the relationship's structure.
        my $relationshipStructure = $relationshipList->{$key};
        # Create the relationship header.
        my $headerText = _ComputeRelationshipHeading($key, $relationshipStructure);
        $retVal .= "<h3><a name=\"$key\"></a>$headerText</h3>\n";
        # Get the entity names.
        my $fromEntity = $relationshipStructure->{from};
        my $toEntity = $relationshipStructure->{to};
        # Describe the relationship arity. Note there's a bit of trickiness involving recursive
        # many-to-many relationships. In a normal many-to-many we use two sentences to describe
        # the arity (one for each direction). This is a bad idea for a recursive relationship,
        # since both sentences will say the same thing.
        my $arity = $relationshipStructure->{arity};
        if ($arity eq "11") {
            $retVal .= "<p>Each <b>$fromEntity</b> relates to at most one <b>$toEntity</b>.\n";
        } else {
            $retVal .= "<p>Each <b>$fromEntity</b> relates to multiple <b>$toEntity</b>s.\n";
            if ($arity eq "MM" && $fromEntity ne $toEntity) {
                $retVal .= "Each <b>$toEntity</b> relates to multiple <b>$fromEntity</b>s.\n";
        $retVal .= "</p>\n";
        # If there are notes on this relationship, display them.
        if (my $notes = $relationshipStructure->{Notes}) {
        # Generate the relationship's relation table.
        my $htmlString = _ShowRelationTable($key, $relationshipStructure->{Relations}->{$key});
    Trace("Building MetaData join table.") if T(4);
    # Denote we're starting the join table.
    $retVal .= "<a name=\"JoinTable\"></a><h3>Join Table</h3>\n";
    # Create a table header.
    $retVal .= _OpenTable("Join Table", "Source", "Target", "Join Condition");
    # Loop through the joins.
    my $joinTable = $metadata->{Joins};
    my @joinKeys = keys %{$joinTable};
    for my $joinKey (sort @joinKeys) {
        # Separate out the source, the target, and the join clause.
        $joinKey =~ m!^([^/]+)/(.+)$!;
        my ($sourceRelation, $targetRelation) = ($1, $2);
        Trace("Join with key $joinKey is from $sourceRelation to $targetRelation.") if T(Joins => 4);
        my $source = $self->ComputeObjectSentence($sourceRelation);
        my $target = $self->ComputeObjectSentence($targetRelation);
        my $clause = $joinTable->{$joinKey};
        # Display them in a table row.
        $retVal .= "<tr><td>$source</td><td>$target</td><td>$clause</td></tr>\n";
    # Close the table.
    $retVal .= _CloseTable();
    Trace("Built MetaData HTML.") if T(3);
    # Return the HTML.
    return $retVal;
=head3 DumpMetaData
    $erdb->DumpMetaData();
Return a dump of the metadata structure.
=cut
sub DumpMetaData {
    my ($self) = @_;
    # Dump the meta-data.
    return Data::Dumper::Dumper($self->{_metaData});
=head3 GenerateWikiData
    my @wikiLines = $erdb->GenerateWikiData();
Build a description of the database for the wiki. The database will be
organized into a single page, with sections for each entity and relationship.
The return value is a list of text lines.
=cut
sub GenerateWikiData {
    my ($self) = @_;
    # We'll build the wiki text in here.
    my @retVal = ();
    # Get the metadata object.
    # Get the title string. This will become the page name.
    my $title = $metadata->{Title}->{content};
    my $shapeList = $metadata->{Shapes};
    # Start with the introductory text.
    push @retVal, WikiTools::Heading(2, "Introduction");
    if (my $notes = $metadata->{Notes}) {
        push @retVal, WikiNote($notes->{content});
    # Generate issue list.
    if (my $issues = $metadata->{Issues}) {
        push @retVal, WikiTools::Heading(3, 'Issues');
        push @retVal, WikiTools::List(map { $_->{content} } @{$issues});
    # Start the entity section.
    push @retVal, WikiTools::Heading(2, "Entities");
    # Loop through the entities. Note that unlike the situation with HTML, we
    # don't need to generate the table of contents manually, just the data
    # itself.
    for my $key (sort keys %$entityList) {
        # Create a header for this entity.
        push @retVal, "", WikiTools::Heading(3, $key);
        # Plant the notes here, if there are any.
        push @retVal, _ObjectNotes($entityData);
        # Now we list the entity's relationships (if any). First, we build a list
        # of the relationships relevant to this entity.
        my @rels = ();
        for my $rel (sort keys %$relationshipList) {
            my $relStructure = $relationshipList->{$rel};
            if ($relStructure->{from} eq $key || $relStructure->{to} eq $key) {
                # Get the relationship sentence.
                my $relSentence = _ComputeRelationshipSentence($rel, $relStructure);
                # Linkify it.
                my $linkedRel = WikiTools::LinkMarkup("#$rel", $rel);
                $relSentence =~ s/$rel/$linkedRel/;
                push @rels, $relSentence;
        # Add the relationships as a Wiki list.
        push @retVal, WikiTools::List(@rels);
            my $wikiString = _WikiRelationTable($relation, $relationList->{$relation});
            push @retVal, $wikiString;
    # Now the entities are documented. Next we do the relationships.
    push @retVal, WikiTools::Heading(2, "Relationships");
    for my $key (sort keys %$relationshipList) {
        my $relationshipData = $relationshipList->{$key};
        # Create the relationship heading.
        push @retVal, WikiTools::Heading(3, $key);
        my $arity = $relationshipData->{arity};
        my $fromEntity = $relationshipData->{from};
        my $toEntity = $relationshipData->{to};
        my @listElements = ();
        my $boldCode = WikiTools::BoldCode();
            push @listElements, "Each $boldCode$fromEntity$boldCode relates to at most one $boldCode$toEntity$boldCode.";
        } else {
            push @listElements, "Each $boldCode$fromEntity$boldCode relates to multiple $boldCode${toEntity}s$boldCode.";
                push @listElements, "Each $boldCode$toEntity$boldCode relates to multiple $boldCode${fromEntity}s$boldCode.";
        push @retVal, WikiTools::List(@listElements);
        push @retVal, _ObjectNotes($relationshipData);
        # Finally, the relationship table.
        my $wikiString = _WikiRelationTable($key, $relationshipData->{Relations}->{$key});
    # Now loop through the miscellaneous shapes.
    if ($shapeList) {
        push @retVal, WikiTools::Heading(2, "Miscellaneous");
        for my $shape (sort keys %$shapeList) {
            push @retVal, WikiTools::Heading(3, $shape);
            my $shapeData = $shapeList->{$shape};
            push @retVal, _ObjectNotes($shapeData);
    # All done. Return the lines.
    return @retVal;
=head3 CreatePPO
    ERDB::CreatePPO($erdbXMLFile, $ppoXMLFile);
Create a PPO XML file from an ERDB data definition XML file. At the
current time, the PPO XML file can be used to create a database with
similar functionality. Eventually, the PPO will be able to use the
created XML to access the live ERDB database.
=over 4
=item erdbXMLFile
Name of the XML data definition file for the ERDB database. This
file must exist.
=item ppoXMLFile
Output file for the PPO XML definition. If this file exists, it
will be overwritten.
=back
=cut
sub CreatePPO {
    my ($erdbXMLFile, $ppoXMLFile) = @_;
    # First, we want to slurp in the ERDB XML file in its raw form.
    my $xml = ReadMetaXML($erdbXMLFile);
    # Create a variable to hold all of the objects in the PPO project.
    my @objects = ();
    # Get the relationship hash.
    my $relationships = $xml->{Relationships};
    my $entities = $xml->{Entities};
    for my $entityName (keys %{$entities}) {
        # Get the entity's data structures.
        my $entityObject = $entities->{$entityName};
        # We put the object's fields in here, according to their type.
        my (@object_refs, @scalars, @indexes, @arrays);
        # Create the ID field for the entity. We get the key type from the
        # entity object and compute the corresponding SQL type.
        my $type = $TypeTable{$entityObject->{keyType}}->{sqlType};
        push @scalars, { label => 'id', type => $type };
        # Loop through the entity fields.
        for my $fieldName ( keys %{$entityObject->{Fields}} ) {
            # Get the field object.
            my $fieldObject = $entityObject->{Fields}->{$fieldName};
            # Convert it to a scalar tag.
            my $scalar = _CreatePPOField($fieldName, $fieldObject);
            # If we have a relation, this field is stored in an array.
            # otherwise, it is a scalar. The array tag has scalars
            # stored as an XML array. In ERDB, there is only ever one,
            # but PPO can have more.
            my $relation = $fieldObject->{relation};
            if ($relation) {
                push @arrays, { scalar => [$scalar] };
            } else {
                push @scalars, $scalar;
        # Loop through the relationships. If this entity is the to-entity
        # on a relationship of 1M arity, then it is implemented as a PPO
        # object reference.
        for my $relationshipName (keys %{$relationships}) {
            my $relationshipData = $relationships->{$relationshipName};
            # If we have a from for this entity and an arity of 1M, we
            # have an object reference.
            if ($relationshipData->{to} eq $entityName &&
                $relationshipData->{arity} eq '1M') {
                # Build the object reference tag.
                push @object_refs, { label => $relationshipName,
                                     type => $relationshipData->{from} };
        # Create the indexes.
        my $indexList = $entityObject->{Indexes};
        push @indexes, map { _CreatePPOIndex($_) } @{$indexList};
        # Build the object XML tree.
        my $object = { label => $entityName,
                       object_ref => \@object_refs,
                       scalar => \@scalars,
                       index => \@indexes,
                       array => \@arrays
        # Push the object onto the objects list.
        push @objects, $object;
    # Loop through the relationships, searching for MMs. The 1Ms were
    # already handled by the entity search above.
        # Get this relationship's object.
        my $relationshipObject = $relationships->{$relationshipName};
        # Only proceed if it's many-to-many.
        if ($relationshipObject->{arity} eq 'MM') {
            # Create the tag lists for the relationship object.
            my (@object_refs, @scalars, @indexes);
            # The relationship will be created as an object with object
            # references for its links to the participating entities.
            my %links = ( from_link => $relationshipObject->{from},
                          to_link => $relationshipObject->{to} );
            for my $link (keys %links) {
                # Create an object_ref tag for this piece of the
                # relationship (from or to).
                my $object_ref = { label => $link,
                                   type => $links{$link} };
                push @object_refs, $object_ref;
            # Loop through the intersection data fields, creating scalar tags.
            # There are no fancy array tags in a relationship.
            for my $fieldName (keys %{$relationshipObject->{Fields}}) {
                my $fieldObject = $relationshipObject->{Fields}->{$fieldName};
                push @scalars, _CreatePPOField($fieldName, $fieldObject);
            # Finally, the indexes: currently we cannot support the to-index and
            # from-index in PPO, so we just process the alternate indexes.
            my $indexList = $relationshipObject->{Indexes};
            # Wrap up all the stuff about this relationship.
            my $object = { label => $relationshipName,
                           index => \@indexes
            # Push it into the object list.
    # Compute a title.
    my $title;
    if ($erdbXMLFile =~ /(\/|^)([^\/]+)DBD\.xml/) {
        # Here we have a standard file name we can use for a title.
        $title = $2;
    } else {
        # Here the file name is non-standard, so we carve up the
        # database title.
        $title = $xml->{Title}->{content};
        $title =~ s/\s\.,//g;
    # Wrap up the XML as a project.
    my $ppoXML = { project => { label => $title,
                                object => \@objects }};
    # Write out the results.
    my $ppoString = XML::Simple::XMLout($ppoXML,
                                        AttrIndent => 1,
                                        KeepRoot => 1);
    Tracer::PutFile($ppoXMLFile, [ $ppoString ]);
=head3 FindIndexForEntity
    my $indexFound = ERDB::FindIndexForEntity($xml, $entityName, $attributeName);
This method locates the entry in an entity's index list that begins with the
specified attribute name. If the entity has no index list, one will be
created. This method works on raw XML, not a live ERDB object.
=over 4
=item xml
The raw XML structure defining the database.
=item entityName
The name of the relevant entity.
=item attributeName
The name of the attribute relevant to the search.
=item RETURN
The numerical index in the index list of the index entry for the specified entity and
attribute, or C<undef> if no such index exists.
=back
=cut
sub FindIndexForEntity {
    my ($xml, $entityName, $attributeName) = @_;
    my $retVal;
    # Get the named entity.
    my $entityData = $xml->{Entities}->{$entityName};
    if (! $entityData) {
        Confess("Entity $entityName not found in DBD structure.");
    } else {
        # Insure it has an index list.
        if (! exists $entityData->{Indexes}) {
            $entityData->{Indexes} = [];
        } else {
            # Search for the desired index.
            my $indexList = $entityData->{Indexes};
            my $n = scalar @{$indexList};
            Trace("Searching $n indexes in index list for $entityName.") if T(2);
            # We use an indexed FOR here because we're returning an
            # index number instead of an object. We do THAT so we can
            # delete the index from the list if needed.
            for (my $i = 0; $i < $n && !defined($retVal); $i++) {
                my $index = $indexList->[$i];
                my $fields = $index->{IndexFields};
                # Technically this IF should be safe (that is, we are guaranteed
                # the existence of a "$fields->[0]"), because when we load the XML
                # we have SuppressEmpty specified.
                if ($fields->[0]->{name} eq $attributeName) {
                    $retVal = $i;
    Trace("Index for $attributeName of $entityName found at position $retVal.") if defined($retVal) && T(3);
    Trace("Index for $attributeName not found in $entityName.") if !defined($retVal) && T(3);
    # Return the result.
    return $retVal;
=head3 CreateTables
    $erdb->CreateTables();
This method creates the tables for the database from the metadata structure loaded by the
constructor. It is expected this function will only be used on rare occasions, when the
user needs to start with an empty database. Otherwise, the L</LoadTables> method can be
used by itself with the truncate flag turned on.
=cut
sub CreateTables {
    my ($self) = @_;
    # Get the relation names.
    my @relNames = $self->GetTableNames();
    # Loop through the relations.
    for my $relationName (@relNames) {
        # Create a table for this relation.
        $self->CreateTable($relationName, 1);
        Trace("Relation $relationName created.") if T(2);
=head3 CreateTable
    $erdb->CreateTable($tableName, $indexFlag, $estimatedRows);
Create the table for a relation and optionally create its indexes.
=over 4
=item relationName
Name of the relation (which will also be the table name).
=item indexFlag
TRUE if the indexes for the relation should be created, else FALSE. If FALSE,
L</CreateIndexes> must be called later to bring the indexes into existence.
=item estimatedRows (optional)
If specified, the estimated maximum number of rows for the relation. This
information allows the creation of tables using storage engines that are
faster but require size estimates, such as MyISAM.
=back
=cut
sub CreateTable {
    my ($self, $relationName, $indexFlag, $estimatedRows) = @_;
    # Get the database handle.
    my $dbh = $self->{_dbh};
    # Get the relation data and determine whether or not the relation is primary.
    my $relationData = $self->_FindRelation($relationName);
    my $rootFlag = $self->_IsPrimary($relationName);
    # Create a list of the field data.
    my @fieldList;
    for my $fieldData (@{$relationData->{Fields}}) {
        # Assemble the field name and type.
        my $fieldName = _FixName($fieldData->{name});
        my $fieldString = "$fieldName $TypeTable{$fieldData->{type}}->{sqlType} NOT NULL ";
        # Push the result into the field list.
        push @fieldList, $fieldString;
    # Convert the field list into a comma-delimited string.
    my $fieldThing = join(', ', @fieldList);
    # Insure the table is not already there.
    $dbh->drop_table(tbl => $relationName);
    Trace("Table $relationName dropped.") if T(2);
    # If there are estimated rows, create an estimate so we can take advantage of
    # faster DB technologies.
    my $estimation = undef;
    if ($estimatedRows) {
        $estimation = [$self->EstimateRowSize($relationName), $estimatedRows];
        Trace("$estimation->[1] rows of $estimation->[0] bytes each.") if T(3);
    # Create the table.
    Trace("Creating table $relationName: $fieldThing") if T(2);
    $dbh->create_table(tbl => $relationName, flds => $fieldThing, estimates => $estimation);
    Trace("Relation $relationName created in database.") if T(2);
    # If we want to build the indexes, we do it here. Note that the full-text search
    # index will not be built until the table has been loaded.
    if ($indexFlag) {
        $self->CreateIndex($relationName);
=head3 VerifyFields
    my $count = $erdb->VerifyFields($relName, \@fieldList);
Run through the list of proposed field values, insuring that all the character fields are
below the maximum length. If any fields are too long, they will be truncated in place.
=over 4
=item relName
Name of the relation for which the specified fields are destined.
=item fieldList
Reference to a list, in order, of the fields to be put into the relation.
=item RETURN
Returns the number of fields truncated.
=back
=cut
sub VerifyFields {
    my ($self, $relName, $fieldList) = @_;
    # Initialize the return value.
    my $retVal = 0;
    # Get the relation definition.
    my $relData = $self->_FindRelation($relName);
    # Get the list of field descriptors.
    my $fieldTypes = $relData->{Fields};
    my $fieldCount = scalar @{$fieldTypes};
    # Loop through the two lists.
    for (my $i = 0; $i < $fieldCount; $i++) {
        # Get the type of the current field.
        my $fieldType = $fieldTypes->[$i]->{type};
        # If it's a character field, verify the length.
        if ($fieldType =~ /string/) {
            my $maxLen = $TypeTable{$fieldType}->{maxLen};
            my $oldString = $fieldList->[$i];
            if (length($oldString) > $maxLen) {
                # Here it's too big, so we truncate it.
                Trace("Truncating field $i ($fieldTypes->[$i]->{name}) in relation $relName to $maxLen characters from \"$oldString\".") if T(1);
                $fieldList->[$i] = substr $oldString, 0, $maxLen;
                $retVal++;
    # Return the truncation count.
    return $retVal;
=head3 DigestFields
    $erdb->DigestFields($relName, $fieldList);
Digest the strings in the field list that correspond to data type C<hash-string> in the
specified relation.
=over 4
=item relName
Name of the relation to which the fields belong.
=item fieldList
List of field contents to be loaded into the relation.
=back
=cut
#: Return Type ;
sub DigestFields {
        # If it's a hash string, digest it in place.
        if ($fieldType eq 'hash-string') {
            $fieldList->[$i] = $self->DigestKey($fieldList->[$i]);
=head3 DigestKey
    my $digested = $erdb->DigestKey($keyValue);
Return the digested value of a symbolic key. The digested value can then be plugged into a
key-based search into a table with key-type hash-string.
Currently the digesting process is independent of the database structure, but that may not
always be the case, so this is an instance method instead of a static method.
=over 4
=item keyValue
Key value to digest.
=item RETURN
Digested value of the key.
=back
=cut
sub DigestKey {
    my ($self, $keyValue) = @_;
    # Compute the digest.
    my $retVal = md5_base64($keyValue);
    return $retVal;
=head3 CreateIndex
    $erdb->CreateIndex($relationName);
Create the indexes for a relation. If a table is being loaded from a large source file (as
is the case in L</LoadTable>), it is sometimes best to create the indexes after the load.
If that is the case, then L</CreateTable> should be called with the index flag set to
FALSE, and this method used after the load to create the indexes for the table.
=cut
sub CreateIndex {
    my ($self, $relationName) = @_;
    # Get the relation's descriptor.
    # Now we need to create this relation's indexes. We do this by looping through its index table.
    my $indexHash = $relationData->{Indexes};
    for my $indexName (keys %{$indexHash}) {
        my $indexData = $indexHash->{$indexName};
        # Get the index's field list.
        my @rawFields = @{$indexData->{IndexFields}};
        # Get a hash of the relation's field types.
        my %types = map { $_->{name} => $_->{type} } @{$relationData->{Fields}};
        # We need to check for text fields so we can append a length limitation for them. To do
        # that, we need the relation's field list.
        my $relFields = $relationData->{Fields};
        for (my $i = 0; $i <= $#rawFields; $i++) {
            # Get the field type.
            my $field = $rawFields[$i];
            my $type = $types{$field};
            # Ask if it requires using prefix notation for the index.
            my $mod = $TypeTable{$type}->{indexMod};
            Trace("Field $field ($i) in $relationName has type $type and indexMod $mod.") if T(3);
            if ($mod) {
                # Append the prefix length to the field name,
                $rawFields[$i] .= "($mod)";
        my @fieldList = _FixNames(@rawFields);
        my $flds = join(', ', @fieldList);
        # Get the index's uniqueness flag.
        my $unique = (exists $indexData->{Unique} ? 'unique' : undef);
        # Create the index.
        my $rv = $dbh->create_index(idx => $indexName, tbl => $relationName,
                                    flds => $flds, kind => $unique);
        if ($rv) {
            Trace("Index created: $indexName for $relationName ($flds)") if T(1);
        } else {
            Confess("Error creating index $indexName for $relationName using ($flds): " . $dbh->error_message());
=head3 GetSecondaryFields
    my %fieldTuples = $erdb->GetSecondaryFields($entityName);
This method will return a list of the name and type of each of the secondary
fields for a specified entity. Secondary fields are stored in two-column tables
in addition to the primary entity table. This enables the field to have no value
or to have multiple values.
=over 4
=item entityName
Name of the entity whose secondary fields are desired.
=item RETURN
Returns a hash mapping the field names to their field types.
=back
=cut
sub GetSecondaryFields {
    my ($self, $entityName) = @_;
    my %retVal = ();
    # Look for the entity.
    my $table = $self->GetFieldTable($entityName);
    # Loop through the fields, pulling out the secondaries.
    for my $field (sort keys %{$table}) {
        if ($table->{$field}->{relation} ne $entityName) {
            # Here we have a secondary field.
            $retVal{$field} = $table->{$field}->{type};
    return %retVal;
=head3 GetFieldRelationName
    my $name = $erdb->GetFieldRelationName($objectName, $fieldName);
Return the name of the relation containing a specified field.
=over 4
=item objectName
Name of the entity or relationship containing the field.
=item fieldName
Name of the relevant field in that entity or relationship.
=item RETURN
Returns the name of the database relation containing the field, or C<undef> if
the field does not exist.
=back
=cut
sub GetFieldRelationName {
    my ($self, $objectName, $fieldName) = @_;
    my $retVal;
    # Get the object field table.
    my $table = $self->GetFieldTable($objectName);
    # Only proceed if the field exists.
    if (exists $table->{$fieldName}) {
        # Determine the name of the relation that contains this field.
        $retVal = $table->{$fieldName}->{relation};
    return $retVal;
=head3 DeleteValue
    my $numDeleted = $erdb->DeleteValue($entityName, $id, $fieldName, $fieldValue);
Delete secondary field values from the database. This method can be used to delete all
values of a specified field for a particular entity instance, or only a single value.
Secondary fields are stored in two-column relations separate from an entity's primary
table, and as a result a secondary field can legitimately have no value or multiple
values. Therefore, it makes sense to talk about deleting secondary fields where it
would not make sense for primary fields.
=over 4
=item entityName
Name of the entity from which the fields are to be deleted.
=item id
ID of the entity instance to be processed. If the instance is not found, this
method will have no effect. If C<undef> is specified, all values for all of
the entity instances will be deleted.
=item fieldName
Name of the field whose values are to be deleted.
=item fieldValue (optional)
Value to be deleted. If not specified, then all values of the specified field
will be deleted for the entity instance. If specified, then only the values which
match this parameter will be deleted.
=item RETURN
Returns the number of rows deleted.
=back
=cut
sub DeleteValue {
    my ($self, $entityName, $id, $fieldName, $fieldValue) = @_;
    # Declare the return value.
    my $retVal = 0;
    # We need to set up an SQL command to do the deletion. First, we
    # find the name of the field's relation.
    my $field = $table->{$fieldName};
    my $relation = $field->{relation};
    # Make sure this is a secondary field.
    if ($relation eq $entityName) {
        Confess("Cannot delete values of $fieldName for $entityName.");
    } else {
        # Set up the SQL command to delete all values.
        my $sql = "DELETE FROM $relation";
        # Build the filter.
        my @filters = ();
        my @parms = ();
        # Check for a filter by ID.
        if (defined $id) {
            push @filters, "id = ?";
            push @parms, $id;
        # Check for a filter by value.
        if (defined $fieldValue) {
            push @filters, "$fieldName = ?";
            push @parms, $fieldValue;
        # Append the filters to the command.
        if (@filters) {
            $sql .= " WHERE " . join(" AND ", @filters);
        # Execute the command.
        $retVal = $dbh->SQL($sql, 0, @parms);
    return $retVal;
=head3 LoadTables
    my $stats = $erdb->LoadTables($directoryName, $rebuild);
This method will load the database tables from a directory. The tables must already have been created
in the database. (This can be done by calling L</CreateTables>.) The caller passes in a directory name;
all of the relations to be loaded must have a file in the directory with the same name as the relation
(optionally with a suffix of C<.dtx>). Each file must be a tab-delimited table of field values. Each
line of the file will be loaded as a row of the target relation table. The field values should be in
the same order as the fields in the relation tables generated by L</ShowMetaData>. The old data is
erased before the new data is loaded in.
A certain amount of translation automatically takes place. Ctrl-M characters are deleted, and
tab and new-line characters inside a field are escaped as C<\t> and C<\n>, respectively. Dates must
be entered as a Unix timestamp, that is, as an integer number of seconds since the base epoch.
=over 4
=item directoryName
Name of the directory containing the relation files to be loaded.
=item rebuild
TRUE if the tables should be dropped and rebuilt, else FALSE. This is, unfortunately, the
only way to erase existing data in the tables, since the TRUNCATE command is not supported
by all of the DB engines we use.
=item RETURN
Returns a statistical object describing the number of records read and a list of the error messages.
=back
=cut
sub LoadTables {
    my ($self, $directoryName, $rebuild) = @_;
    # Start the timer.
    my $startTime = gettimeofday;
    # Clean any trailing slash from the directory name.
    $directoryName =~ s!/\\$!!;
    my $retVal = Stats->new();
        # Try to load this relation.
        my $result = $self->_LoadRelation($directoryName, $relationName, $rebuild);
        # Accumulate the statistics.
        $retVal->Accumulate($result);
    # Add the duration of the load to the statistical object.
    $retVal->Add('duration', gettimeofday - $startTime);
    # Return the accumulated statistics.
    return $retVal;
=head3 GetTableNames
    my @names = $erdb->GetTableNames;
Return a list of the relations required to implement this database.
=cut
sub GetTableNames {
    my ($self) = @_;
    # Get the relation list from the metadata.
    my $relationTable = $self->{_metaData}->{RelationTable};
    # Return the relation names.
    return keys %{$relationTable};
=head3 GetEntityTypes
    my @names = $erdb->GetEntityTypes;
Return a list of the entity type names.
=cut
sub GetEntityTypes {
    # Get the database object.
    my ($self) = @_;
    # Get the entity list from the metadata object.
    my $entityList = $self->{_metaData}->{Entities};
    # Return the list of entity names in alphabetical order.
    return sort keys %{$entityList};
=head3 GetConnectingRelationships
    my @list = $erdb->GetConnectingRelationships($entityName);
Return a list of the relationships connected to the specified entity.
=over 4
=item entityName
Entity whose connected relationships are desired.
=item RETURN
Returns a list of the relationships that originate from the entity.
If the entity is on the from end, it will return the relationship
name. If the entity is on the to end it will return the converse of
the relationship name.
=back
=cut
sub GetConnectingRelationships {
    my @retVal;
    # Get the relationship list.
    my $relationships = $self->{_metaData}->{Relationships};
    # Find the entity.
    my $entity = $self->{_metaData}->{Entities}->{$entityName};
    # Only proceed if the entity exists.
    if (! defined $entity) {
        Trace("Entity $entityName not found.") if T(3);
    } else {
        my @rels = keys %$relationships;
        Trace(scalar(@rels) . " relationships found in connection search.") if T(3);
        for my $relationshipName (@rels) {
            my $relationship = $relationships->{$relationshipName};
            if ($relationship->{from} eq $entityName) {
                # Here we have a forward relationship.
                push @retVal, $relationshipName;
            } elsif ($relationship->{to} eq $entityName) {
                # Here we have a backward relationship. In this case, the
                # converse relationship name is preferred if it exists.
                my $converse = $relationship->{converse} || $relationshipName;
                push @retVal, $converse;
    return @retVal;
=head3 GetDataTypes
    my %types = ERDB::GetDataTypes();
Return a table of ERDB data types. The table returned is a hash of hashes.
The keys of the big hash are the datatypes. Each smaller hash has several
values used to manage the data. The most interesting is the SQL type (key
C<sqlType>) and the descriptive node (key C<notes>).
Note that changing the values in the smaller hashes will seriously break
things, so this data should be treated as read-only.
=cut
sub GetDataTypes {
    return %TypeTable;
=head3 IsEntity
    my $flag = $erdb->IsEntity($entityName);
Return TRUE if the parameter is an entity name, else FALSE.
=over 4
=item entityName
Object name to be tested.
=item RETURN
Returns TRUE if the specified string is an entity name, else FALSE.
=back
=cut
sub IsEntity {
    # Test to see if it's an entity.
    return exists $self->{_metaData}->{Entities}->{$entityName};
=head3 Get
    my $query = $erdb->Get(\@objectNames, $filterClause, \@params);
This method returns a query object for entities of a specified type using a specified filter.
The filter is a standard WHERE/ORDER BY clause with question marks as parameter markers and each
field name represented in the form B<I<objectName>(I<fieldName>)>. For example, the
following call requests all B<Genome> objects for the genus specified in the variable
$genus.
    $query = $erdb->Get(['Genome'], "Genome(genus) = ?", [$genus]);
The WHERE clause contains a single question mark, so there is a single additional
parameter representing the parameter value. It would also be possible to code
    $query = $erdb->Get(['Genome'], "Genome(genus) = \'$genus\'");
however, this version of the call would generate a syntax error if there were any quote
characters inside the variable C<$genus>.
The use of the strange parenthesized notation for field names enables us to distinguish
hyphens contained within field names from minus signs that participate in the computation
of the WHERE clause. All of the methods that manipulate fields will use this same notation.
It is possible to specify multiple entity and relationship names in order to retrieve more than
one object's data at the same time, which allows highly complex joined queries. For example,
    $query = $erdb->Get(['Genome', 'ComesFrom', 'Source'], "Genome(genus) = ?", [$genus]);
If multiple names are specified, then the query processor will automatically determine a
join path between the entities and relationships. The algorithm used is very simplistic.
In particular, if a relationship is recursive, the path is determined by the order in which
the entity and the relationship appear. For example, consider a recursive relationship
B<IsParentOf> which relates B<People> objects to other B<People> objects. If the join path is
coded as C<['People', 'IsParentOf']>, then the people returned will be parents. If, however,
the join path is C<['IsParentOf', 'People']>, then the people returned will be children.
If an entity or relationship is mentioned twice, the name for the second occurrence will
be suffixed with C<2>, the third occurrence will be suffixed with C<3>, and so forth. So,
for example, if we have C<['Feature', 'HasContig', 'Contig', 'HasContig']>, then the
B<to-link> field of the first B<HasContig> is specified as C<HasContig(to-link)>, while
the B<to-link> field of the second B<HasContig> is specified as C<HasContig2(to-link)>.
=over 4
=item objectNames
List containing the names of the entity and relationship objects to be retrieved.
=item filterClause
WHERE clause (without the WHERE) to be used to filter and sort the query. The WHERE clause can
be parameterized with parameter markers (C<?>). Each field used in the WHERE clause must be
specified in the standard form B<I<objectName>(I<fieldName>)>. Any parameters specified
in the filter clause should be added to the parameter list as additional parameters. The
fields in a filter clause can come from primary entity relations, relationship relations,
or secondary entity relations; however, all of the entities and relationships involved must
be included in the list of object names.
The filter clause can also specify a sort order. To do this, simply follow the filter string
with an ORDER BY clause. For example, the following filter string gets all genomes for a
particular genus and sorts them by species name.
    "Genome(genus) = ? ORDER BY Genome(species)"
Note that the case is important. Only an uppercase "ORDER BY" with a single space will
be processed. The idea is to make it less likely to find the verb by accident.
The rules for field references in a sort order are the same as those for field references in the
filter clause in general; however, odd things may happen if a sort field is from a secondary
relation.
Finally, you can limit the number of rows returned by adding a LIMIT clause. The LIMIT must
be the last thing in the filter clause, and it contains only the word "LIMIT" followed by
a positive number. So, for example
    "Genome(genus) = ? ORDER BY Genome(species) LIMIT 10"
will only return the first ten genomes for the specified genus. The ORDER BY clause is not
required. For example, to just get the first 10 genomes in the B<Genome> table, you could
use
    "LIMIT 10"
=item params
Reference to a list of parameter values to be substituted into the filter clause.
=item RETURN
Returns a B<DBQuery> that can be used to iterate through all of the results.
=back
=cut
sub Get {
    my ($self, $objectNames, $filterClause, $params) = @_;
    # Process the SQL stuff.
    my ($suffix, $mappedNameListRef, $mappedNameHashRef) =
        $self->_SetupSQL($objectNames, $filterClause);
    # Create the query.
    my $command = "SELECT " . join(".*, ", @{$mappedNameListRef}) .
        ".* $suffix";
    my $sth = $self->_GetStatementHandle($command, $params);
    # Now we create the relation map, which enables DBQuery to determine the order, name
    # and mapped name for each object in the query.
    my @relationMap = ();
    for my $mappedName (@{$mappedNameListRef}) {
        push @relationMap, [$mappedName, $mappedNameHashRef->{$mappedName}];
    # Return the statement object.
    my $retVal = DBQuery::_new($self, $sth, \@relationMap);
    return $retVal;
=head3 Search
    my $query = $erdb->Search($searchExpression, $idx, \@objectNames, $filterClause, \@params);
Perform a full text search with filtering. The search will be against a specified object
in the object name list. That object will get an extra field containing the search
relevance. Note that except for the search expression, the parameters of this method are
the same as those for L</Get> and follow the same rules.
=over 4
=item searchExpression
Boolean search expression for the text fields of the target object. The default mode for
a Boolean search expression is OR, but we want the default to be AND, so we will
add a C<+> operator to each word with no other operator before it.
=item idx
Index in the I<$objectNames> list of the table to be searched in full-text mode.
=item objectNames
=item filterClause
=item params
=item RETURN
Returns a query object for the specified search.
=back
=cut
sub Search {
    my ($self, $searchExpression, $idx, $objectNames, $filterClause, $params) = @_;
    my $retVal;
    # Create a safety copy of the parameter list. Note we have to be careful to insure
    # a parameter list exists before we copy it.
    my @myParams = ();
    if (defined $params) {
        @myParams = @{$params};
    # Get the first object's structure so we have access to the searchable fields.
    my $object1Name = $objectNames->[$idx];
    my $object1Structure = $self->_GetStructure($object1Name);
    # Get the field list.
    if (! exists $object1Structure->{searchFields}) {
        Confess("No searchable index for $object1Name.");
    } else {
        my @fields = @{$object1Structure->{searchFields}};
        # Clean the search expression.
        my $actualKeywords = $self->CleanKeywords($searchExpression);
        # Prefix a "+" to each uncontrolled word. This converts the default
        # search mode from OR to AND.
        $actualKeywords =~ s/(^|\s)(\w|")/$1\+$2/g;
        Trace("Actual keywords for search are\n$actualKeywords") if T(3);
        # We need two match expressions, one for the filter clause and one in the
        # query itself. Both will use a parameter mark, so we need to push the
        # search expression onto the front of the parameter list twice.
        unshift @myParams, $actualKeywords, $actualKeywords;
        # Build the match expression.
        my @matchFilterFields = map { "$object1Name." . _FixName($_) } @fields;
        my $matchClause = "MATCH (" . join(", ", @matchFilterFields) . ") AGAINST (? IN BOOLEAN MODE)";
            $self->_SetupSQL($objectNames, $filterClause, $matchClause);
        # Create the query. Note that the match clause is inserted at the front of
        # the select fields.
        my $command = "SELECT $matchClause, " . join(".*, ", @{$mappedNameListRef}) .
            ".* $suffix";
        my $sth = $self->_GetStatementHandle($command, \@myParams);
        my @relationMap = _RelationMap($mappedNameHashRef, $mappedNameListRef);
        $retVal = DBQuery::_new($self, $sth, \@relationMap, $object1Name);
    return $retVal;
=head3 GetFlat
    my @list = $erdb->GetFlat(\@objectNames, $filterClause, \@parameterList, $field);
This is a variation of L</GetAll> that asks for only a single field per record and
returns a single flattened list.
=over 4
=item objectNames
=item filterClause
WHERE/ORDER BY clause (without the WHERE) to be used to filter and sort the query. The WHERE clause can
be parameterized with parameter markers (C<?>). Each field used must be specified in the standard form
B<I<objectName>(I<fieldName>)>. Any parameters specified in the filter clause should be added to the
parameter list as additional parameters. The fields in a filter clause can come from primary
entity relations, relationship relations, or secondary entity relations; however, all of the
entities and relationships involved must be included in the list of object names.
=item parameterList
List of the parameters to be substituted in for the parameters marks in the filter clause.
=item field
Name of the field to be used to get the elements of the list returned.
=item RETURN
Returns a list of values.
=back
=cut
#: Return Type @;
sub GetFlat {
    my ($self, $objectNames, $filterClause, $parameterList, $field) = @_;
    # Construct the query.
    my $query = $self->Get($objectNames, $filterClause, $parameterList);
    # Create the result list.
    my @retVal = ();
    # Loop through the records, adding the field values found to the result list.
    while (my $row = $query->Fetch()) {
        push @retVal, $row->Value($field);
    # Return the list created.
    return @retVal;
=head3 SpecialFields
    my %specials = $erdb->SpecialFields($entityName);
Return a hash mapping special fields in the specified entity to the value of their
C<special> attribute. This enables the subclass to get access to the special field
attributes without needed to plumb the internal ERDB data structures.
=over 4
=item entityName
Name of the entity whose special fields are desired.
=item RETURN
Returns a hash. The keys of the hash are the special field names, and the values
are the values from each special field's C<special> attribute.
=back
=cut
sub SpecialFields {
    my %retVal = ();
    # Find the entity's data structure.
    my $entityData = $self->{_metaData}->{Entities}->{$entityName};
    # Loop through its fields, adding each special field to the return hash.
    my $fieldHash = $entityData->{Fields};
    for my $fieldName (keys %{$fieldHash}) {
        my $fieldData = $fieldHash->{$fieldName};
        if (exists $fieldData->{special}) {
            $retVal{$fieldName} = $fieldData->{special};
    return %retVal;
=head3 Delete
    my $stats = $erdb->Delete($entityName, $objectID, %options);
Delete an entity instance from the database. The instance is deleted along with all entity and
relationship instances dependent on it. The definition of I<dependence> is recursive.
An object is always dependent on itself. An object is dependent if it is a 1-to-many or many-to-many
relationship connected to a dependent entity or if it is the "to" entity connected to a 1-to-many
dependent relationship.
=over 4
=item entityName
Name of the entity type for the instance being deleted.
=item objectID
ID of the entity instance to be deleted. If the ID contains a wild card character (C<%>),
then it is presumed to by a LIKE pattern.
=item options
A hash detailing the options for this delete operation.
=item RETURN
Returns a statistics object indicating how many records of each particular table were
deleted.
=back
The permissible options for this method are as follows.
=over 4
=item testMode
If TRUE, then the delete statements will be traced, but no changes will be made to the database.
=item keepRoot
If TRUE, then the entity instances will not be deleted, only the dependent records.
=back
=cut
#: Return Type $%;
sub Delete {
    my ($self, $entityName, $objectID, %options) = @_;
    # Get the DBKernel object.
    my $db = $self->{_dbh};
    # We're going to generate all the paths branching out from the starting entity. One of
    # the things we have to be careful about is preventing loops. We'll use a hash to
    # determine if we've hit a loop.
    my %alreadyFound = ();
    # These next lists will serve as our result stack. We start by pushing object lists onto
    # the stack, and then popping them off to do the deletes. This means the deletes will
    # start with the longer paths before getting to the shorter ones. That, in turn, makes
    # sure we don't delete records that might be needed to forge relationships back to the
    # original item. We have two lists-- one for TO-relationships, and one for
    # FROM-relationships and entities.
    my @fromPathList = ();
    my @toPathList = ();
    # This final list is used to remember what work still needs to be done. We push paths
    # onto the list, then pop them off to extend the paths. We prime it with the starting
    # point. Note that we will work hard to insure that the last item on a path in the
    # to-do list is always an entity.
    my @todoList = ([$entityName]);
    while (@todoList) {
        # Get the current path.
        my $current = pop @todoList;
        # Copy it into a list.
        my @stackedPath = @{$current};
        # Pull off the last item on the path. It will always be an entity.
        my $myEntityName = pop @stackedPath;
        # Add it to the alreadyFound list.
        $alreadyFound{$myEntityName} = 1;
        # Figure out if we need to delete this entity.
        if ($myEntityName ne $entityName || ! $options{keepRoot}) {
            my $entityData = $self->_GetStructure($myEntityName);
            # Loop through the entity's relations. A DELETE command will be needed for each of them.
            my $relations = $entityData->{Relations};
            for my $relation (keys %{$relations}) {
                my @augmentedList = (@stackedPath, $relation);
                push @fromPathList, \@augmentedList;
        # Now we need to look for relationships connected to this entity.
        my $relationshipList = $self->{_metaData}->{Relationships};
        for my $relationshipName (keys %{$relationshipList}) {
            my $relationship = $relationshipList->{$relationshipName};
            # Check the FROM field. We're only interested if it's us.
            if ($relationship->{from} eq $myEntityName) {
                # Add the path to this relationship.
                my @augmentedList = (@stackedPath, $myEntityName, $relationshipName);
                # Check the arity. If it's MM we're done. If it's 1M
                # and the target hasn't been seen yet, we want to
                # stack the entity for future processing.
                if ($relationship->{arity} eq '1M') {
                    my $toEntity = $relationship->{to};
                    if (! exists $alreadyFound{$toEntity}) {
                        # Here we have a new entity that's dependent on
                        # the current entity, so we need to stack it.
                        my @stackList = (@augmentedList, $toEntity);
                        push @fromPathList, \@stackList;
                    } else {
                        Trace("$toEntity ignored because it occurred previously.") if T(4);
            # Now check the TO field. In this case only the relationship needs
            # deletion.
            if ($relationship->{to} eq $myEntityName) {
                push @toPathList, \@augmentedList;
    # Create the first qualifier for the WHERE clause. This selects the
    # keys of the primary entity records to be deleted. When we're deleting
    # from a dependent table, we construct a join path from the first qualifier
    # to the table containing the dependent records to delete.
    my $qualifier = ($objectID =~ /%/ ? "LIKE ?" : "= ?");
    # We need to make two passes. The first is through the to-list, and
    # the second through the from-list. The from-list is second because
    # the to-list may need to pass through some of the entities the
    # from-list would delete.
    my %stackList = ( from_link => \@fromPathList, to_link => \@toPathList );
    # Now it's time to do the deletes. We do it in two passes.
    for my $keyName ('to_link', 'from_link') {
        # Get the list for this key.
        my @pathList = @{$stackList{$keyName}};
        Trace(scalar(@pathList) . " entries in path list for $keyName.") if T(3);
        # Loop through this list.
        while (my $path = pop @pathList) {
            # Get the table whose rows are to be deleted.
            my @pathTables = @{$path};
            # Start the DELETE statement. We need to call DBKernel because the
            # syntax of a DELETE-USING varies among DBMSs.
            my $target = $pathTables[$#pathTables];
            my $stmt = $db->SetUsing(@pathTables);
            # Now start the WHERE. The first thing is the ID field from the starting table. That
            # starting table will either be the entity relation or one of the entity's
            # sub-relations.
            $stmt .= " WHERE $pathTables[0].id $qualifier";
            # Now we run through the remaining entities in the path, connecting them up.
            for (my $i = 1; $i <= $#pathTables; $i += 2) {
                # Connect the current relationship to the preceding entity.
                my ($entity, $rel) = @pathTables[$i-1,$i];
                # The style of connection depends on the direction of the relationship.
                $stmt .= " AND $entity.id = $rel.$keyName";
                if ($i + 1 <= $#pathTables) {
                    # Here there's a next entity, so connect that to the relationship's
                    # to-link.
                    my $entity2 = $pathTables[$i+1];
                    $stmt .= " AND $rel.to_link = $entity2.id";
            # Now we have our desired DELETE statement.
            if ($options{testMode}) {
                # Here the user wants to trace without executing.
                Trace($stmt) if T(0);
            } else {
                # Here we can delete. Note that the SQL method dies with a confession
                # if an error occurs, so we just go ahead and do it.
                Trace("Executing delete from $target using '$objectID'.") if T(3);
                my $rv = $db->SQL($stmt, 0, $objectID);
                # Accumulate the statistics for this delete. The only rows deleted
                # are from the target table, so we use its name to record the
                # statistic.
                $retVal->Add($target, $rv);
    return $retVal;
=head3 Disconnect
    $erdb->Disconnect($relationshipName, $originEntityName, $originEntityID);
Disconnect an entity instance from all the objects to which it is related. This
will delete each relationship instance that connects to the specified entity.
=over 4
=item relationshipName
Name of the relationship whose instances are to be deleted.
=item originEntityName
Name of the entity that is to be disconnected.
=item originEntityID
ID of the entity that is to be disconnected.
=back
=cut
sub Disconnect {
    my ($self, $relationshipName, $originEntityName, $originEntityID) = @_;
    # Get the relationship descriptor.
    my $structure = $self->_GetStructure($relationshipName);
    # Insure we have a relationship.
    if (! exists $structure->{from}) {
        Confess("$relationshipName is not a relationship in the database.");
    } else {
        # We'll set this value to 1 if we find our entity.
        my $found = 0;
        # Loop through the ends of the relationship.
        for my $dir ('from', 'to') {
            if ($structure->{$dir} eq $originEntityName) {
                $found = 1;
                # Here we want to delete all relationship instances on this side of the
                # entity instance.
                Trace("Disconnecting in $dir direction with ID \"$originEntityID\".");
                # We do this delete in batches to keep it from dragging down the
                # server.
                my $limitClause = ($FIG_Config::delete_limit ? "LIMIT $FIG_Config::delete_limit" : "");
                my $done = 0;
                while (! $done) {
                    # Do the delete.
                    my $rows = $dbh->SQL("DELETE FROM $relationshipName WHERE ${dir}_link = ? $limitClause", 0, $originEntityID);
                    # See if we're done. We're done if no rows were found or the delete is unlimited.
                    $done = ($rows == 0 || ! $limitClause);
        # Insure we found the entity on at least one end.
        if (! $found) {
            Confess("Entity \"$originEntityName\" does not use $relationshipName.");
=head3 DeleteRow
    $erdb->DeleteRow($relationshipName, $fromLink, $toLink, \%values);
Delete a row from a relationship. In most cases, only the from-link and to-link are
needed; however, for relationships with intersection data values can be specified
for the other fields using a hash.
=over 4
Name of the relationship from which the row is to be deleted.
=item fromLink
ID of the entity instance in the From direction.
=item toLink
ID of the entity instance in the To direction.
=item values
Reference to a hash of other values to be used for filtering the delete.
=back
=cut
sub DeleteRow {
    my ($self, $relationshipName, $fromLink, $toLink, $values) = @_;
    # Create a hash of all the filter information.
    my %filter = ('from-link' => $fromLink, 'to-link' => $toLink);
    if (defined $values) {
        for my $key (keys %{$values}) {
            $filter{$key} = $values->{$key};
    # Build an SQL statement out of the hash.
    my @filters = ();
    my @parms = ();
    for my $key (keys %filter) {
        push @filters, _FixName($key) . " = ?";
        push @parms, $filter{$key};
    Trace("Parms for delete row are " . join(", ", map { "\"$_\"" } @parms) . ".") if T(SQL => 4);
    my $command = "DELETE FROM $relationshipName WHERE " .
    # Execute it.
    $dbh->SQL($command, undef, @parms);
=head3 DeleteLike
    my $deleteCount = $erdb->DeleteLike($relName, $filter, \@parms);
Delete all the relationship rows that satisfy a particular filter condition. Unlike a normal
filter, only fields from the relationship itself can be used.
=over 4
=item relName
Name of the relationship whose records are to be deleted.
=item filter
A filter clause (L</Get>-style) for the delete query.
=item parms
Reference to a list of parameters for the filter clause.
=item RETURN
Returns a count of the number of rows deleted.
=back
=cut
sub DeleteLike {
    my ($self, $objectName, $filter, $parms) = @_;
    my $retVal;
    # Insure the parms argument is an array reference if the caller left it off.
    if (! defined($parms)) {
        $parms = [];
    # Insure we have a relationship. The main reason for this is if we delete an entity
    # instance we have to yank out a bunch of other stuff with it.
    if ($self->IsEntity($objectName)) {
        Confess("Cannot use DeleteLike on $objectName, because it is not a relationship.");
    } else {
        # Create the SQL command suffix to get the desierd records.
        my ($suffix) = $self->_SetupSQL([$objectName], $filter);
        # Convert it to a DELETE command.
        my $command = "DELETE $suffix";
        my $result = $dbh->SQL($command, 0, @{$parms});
        # Check the results. Note we convert the "0D0" result to a real zero.
        # A failure causes an abnormal termination, so the caller isn't going to
        # worry about it.
        if (! defined $result) {
            Confess("Error deleting from $objectName: " . $dbh->errstr());
        } elsif ($result == 0) {
            $retVal = 0;
        } else {
            $retVal = $result;
    # Return the result count.
    return $retVal;
=head3 SortNeeded
    my $parms = $erdb->SortNeeded($relationName);
Return the pipe command for the sort that should be applied to the specified
relation when creating the load file.
For example, if the load file should be sorted ascending by the first
field, this method would return
    sort -k1 -t"\t"
If the first field is numeric, the method would return
    sort -k1n -t"\t"
Unfortunately, due to a bug in the C<sort> command, we cannot eliminate duplicate
keys using a sort.
=over 4
=item relationName
Name of the relation to be examined.
=item
Returns the sort command to use for sorting the relation, suitable for piping.
=back
=cut
#: Return Type $;
sub SortNeeded {
    # Declare a descriptor to hold the names of the key fields.
    my @keyNames = ();
    # Get the relation structure.
    # Find out if the relation is a primary entity relation,
    # a relationship relation, or a secondary entity relation.
    my $entityTable = $self->{_metaData}->{Entities};
    my $relationshipTable = $self->{_metaData}->{Relationships};
    if (exists $entityTable->{$relationName}) {
        # Here we have a primary entity relation.
        push @keyNames, "id";
    } elsif (exists $relationshipTable->{$relationName}) {
        # Here we have a relationship. We sort using the FROM index.
        my $relationshipData = $relationshipTable->{$relationName};
        my $index = $relationData->{Indexes}->{idxFrom};
        push @keyNames, @{$index->{IndexFields}};
    } else {
        # Here we have a secondary entity relation, so we have a sort on the ID field.
    # Now we parse the key names into sort parameters. First, we prime the return
    # string.
    my $retVal = "sort -S 1G -T\"$FIG_Config::temp\" -t\"\t\" ";
    # Get the relation's field list.
    my @fields = @{$relationData->{Fields}};
    # Loop through the keys.
    for my $keyData (@keyNames) {
        # Get the key and the ordering.
        my ($keyName, $ordering);
        if ($keyData =~ /^([^ ]+) DESC/) {
            ($keyName, $ordering) = ($1, "descending");
        } else {
            ($keyName, $ordering) = ($keyData, "ascending");
        # Find the key's position and type.
        my $fieldSpec;
        for (my $i = 0; $i <= $#fields && ! $fieldSpec; $i++) {
            my $thisField = $fields[$i];
            if ($thisField->{name} eq $keyName) {
                # Get the sort modifier for this field type. The modifier
                # decides whether we're using a character, numeric, or
                # floating-point sort.
                my $modifier = $TypeTable{$thisField->{type}}->{sort};
                # If the index is descending for this field, denote we want
                # to reverse the sort order on this field.
                if ($ordering eq 'descending') {
                    $modifier .= "r";
                # Store the position and modifier into the field spec, which
                # will stop the inner loop. Note that the field number is
                # 1-based in the sort command, so we have to increment the
                # index.
                my $realI = $i + 1;
                $fieldSpec = "$realI,$realI$modifier";
        # Add this field to the sort command.
        $retVal .= " -k$fieldSpec";
    return $retVal;
=head3 GetList
    my @dbObjects = $erdb->GetList(\@objectNames, $filterClause, \@params);
Return a list of object descriptors for the specified objects as determined by the
specified filter clause.
This method is essentially the same as L</Get> except it returns a list of objects rather
than a query object that can be used to get the results one record at a time.
=over 4
=item objectNames
=item filterClause
relation.
=item params
=item RETURN
Returns a list of B<ERDBObject>s that satisfy the query conditions.
=back
=cut
#: Return Type @%
sub GetList {
    my @retVal = ();
    # Perform the query.
    my $query = $self->Get($objectNames, $filterClause, $params);
    # Loop through the results.
    while (my $object = $query->Fetch) {
        push @retVal, $object;
    return @retVal;
=head3 GetCount
    my $count = $erdb->GetCount(\@objectNames, $filter, \@params);
Return the number of rows found by a specified query. This method would
normally be used to count the records in a single table. For example, in a
genetics database
    my $count = $erdb->GetCount(['Genome'], 'Genome(genus-species) LIKE ?', ['homo %']);
would return the number of genomes for the genus I<homo>. It is conceivable, however,
to use it to return records based on a join. For example,
    my $count = $erdb->GetCount(['HasFeature', 'Genome'], 'Genome(genus-species) LIKE ?',
                                ['homo %']);
would return the number of features for genomes in the genus I<homo>. Note that
only the rows from the first table are counted. If the above command were
    my $count = $erdb->GetCount(['Genome', 'Feature'], 'Genome(genus-species) LIKE ?',
                                ['homo %']);
it would return the number of genomes, not the number of genome/feature pairs.
=over 4
=item objectNames
Reference to a list of the objects (entities and relationships) included in the
query.
=item filter
A filter clause for restricting the query. The rules are the same as for the L</Get>
method.
=item params
Reference to a list of the parameter values to be substituted for the parameter marks
in the filter.
=item RETURN
Returns a count of the number of records in the first table that would satisfy
the query.
=back
=cut
sub GetCount {
    # Get the parameters.
    my ($self, $objectNames, $filter, $params) = @_;
    # Insure the params argument is an array reference if the caller left it off.
    if (! defined($params)) {
        $params = [];
    my $retVal;
    # Find out if we're counting an entity or a relationship.
    my $countedField;
    if ($self->IsEntity($objectNames->[0])) {
        $countedField = "id";
    } else {
        # For a relationship we count the to-link because it's usually more
        # numerous. Note we're automatically converting to the SQL form
        # of the field name (to_link vs. to-link).
        $countedField = "to_link";
    # Create the SQL command suffix to get the desired records.
    my ($suffix, $mappedNameListRef, $mappedNameHashRef) = $self->_SetupSQL($objectNames,
        $filter);
    # Prefix it with text telling it we want a record count.
    my $firstObject = $mappedNameListRef->[0];
    my $command = "SELECT COUNT($firstObject.$countedField) $suffix";
    # Prepare and execute the command.
    # Get the count value.
    ($retVal) = $sth->fetchrow_array();
    # Check for a problem.
    if (! defined($retVal)) {
        if ($sth->err) {
            # Here we had an SQL error.
            Confess("Error retrieving row count: " . $sth->errstr());
        } else {
            # Here we have no result.
            Confess("No result attempting to retrieve row count.");
    return $retVal;
=head3 ComputeObjectSentence
    my $sentence = $erdb->ComputeObjectSentence($objectName);
Check an object name, and if it is a relationship convert it to a relationship sentence.
=over 4
=item objectName
Name of the entity or relationship.
=item RETURN
Returns a string containing the entity name or a relationship sentence.
=back
=cut
sub ComputeObjectSentence {
    my ($self, $objectName) = @_;
    # Set the default return value.
    my $retVal = $objectName;
    # Look for the object as a relationship.
    my $relTable = $self->{_metaData}->{Relationships};
    if (exists $relTable->{$objectName}) {
        $retVal = _ComputeRelationshipSentence($objectName, $relTable->{$objectName});
    return $retVal;
=head3 DumpRelations
    $erdb->DumpRelations($outputDirectory);
Write the contents of all the relations to tab-delimited files in the specified directory.
Each file will have the same name as the relation dumped, with an extension of DTX.
=over 4
=item outputDirectory
Name of the directory into which the relation files should be dumped.
=back
=cut
sub DumpRelations {
    my ($self, $outputDirectory) = @_;
    # Now we need to run through all the relations. First, we loop through the entities.
    my $metaData = $self->{_metaData};
    my $entities = $metaData->{Entities};
        my $entityStructure = $entities->{$entityName};
        my $relationList = $entityStructure->{Relations};
        # Loop through the relations, dumping them.
        for my $relationName (keys %{$relationList}) {
            my $relation = $relationList->{$relationName};
            $self->_DumpRelation($outputDirectory, $relationName, $relation);
    # Next, we loop through the relationships.
    my $relationships = $metaData->{Relationships};
        my $relationshipStructure = $relationships->{$relationshipName};
        # Dump this relationship's relation.
        $self->_DumpRelation($outputDirectory, $relationshipName, $relationshipStructure->{Relations}->{$relationshipName});
=head3 InsertValue
    $erdb->InsertValue($entityID, $fieldName, $value);
This method will insert a new value into the database. The value must be one
associated with a secondary relation, since primary values cannot be inserted:
they occur exactly once. Secondary values, on the other hand, can be missing
or multiply-occurring.
=over 4
=item entityID
ID of the object that is to receive the new value.
=item fieldName
Field name for the new value-- this includes the entity name, since
field names are of the format I<objectName>C<(>I<fieldName>C<)>.
=item value
New value to be put in the field.
=back
=cut
sub InsertValue {
    my ($self, $entityID, $fieldName, $value) = @_;
    # Parse the entity name and the real field name.
    if ($fieldName =~ /^([^(]+)\(([^)]+)\)/) {
        my $entityName = $1;
        my $fieldTitle = $2;
        # Get its descriptor.
        if (!$self->IsEntity($entityName)) {
            Confess("$entityName is not a valid entity.");
        } else {
            # Find the relation containing this field.
            if (! exists $fieldHash->{$fieldTitle}) {
                Confess("$fieldTitle not found in $entityName.");
            } else {
                my $relation = $fieldHash->{$fieldTitle}->{relation};
                    Confess("Cannot do InsertValue on primary field $fieldTitle of $entityName.");
                } else {
                    # Now we can create an INSERT statement.
                    my $fixedName = _FixName($fieldTitle);
                    my $statement = "INSERT INTO $relation (id, $fixedName) VALUES(?, ?)";
                    $dbh->SQL($statement, 0, $entityID, $value);
    } else {
        Confess("$fieldName is not a valid field name.");
=head3 InsertObject
    $erdb->InsertObject($objectType, \%fieldHash);
Insert an object into the database. The object is defined by a type name and then a hash
of field names to values. Field values in the primary relation are represented by scalars.
(Note that for relationships, the primary relation is the B<only> relation.)
Field values for the other relations comprising the entity are always list references. For
example, the following line inserts an inactive PEG feature named C<fig|188.1.peg.1> with aliases
C<ZP_00210270.1> and C<gi|46206278>.
    $erdb->InsertObject('Feature', { id => 'fig|188.1.peg.1', active => 0, feature-type => 'peg', alias => ['ZP_00210270.1', 'gi|46206278']});
The next statement inserts a C<HasProperty> relationship between feature C<fig|158879.1.peg.1> and
property C<4> with an evidence URL of C<http://seedu.uchicago.edu/query.cgi?article_id=142>.
    $erdb->InsertObject('HasProperty', { 'from-link' => 'fig|158879.1.peg.1', 'to-link' => 4, evidence => 'http://seedu.uchicago.edu/query.cgi?article_id=142'});
=over 4
=item newObjectType
Type name of the object to insert.
=item fieldHash
Hash of field names to values.
=back
=cut
sub InsertObject {
    my ($self, $newObjectType, $fieldHash) = @_;
    # Denote that so far we appear successful.
    my $retVal = 1;
    # Get the relation list.
    my $relationTable = $self->_GetRelationTable($newObjectType);
    # Loop through the relations. We'll build insert statements for each one. If a relation is
    # secondary, we may end up generating multiple insert statements. If an error occurs, we
    # stop the loop.
    my @relationList = keys %{$relationTable};
    for (my $i = 0; $retVal && $i <= $#relationList; $i++) {
        my $relationName = $relationList[$i];
        my $relationDefinition = $relationTable->{$relationName};
        # Get the relation's fields. For each field we will collect a value in the corresponding
        # position of the @valueList array. If one of the fields is missing, we will add it to the
        # @missing list.
        my @fieldList = @{$relationDefinition->{Fields}};
        my @fieldNameList = ();
        my @valueList = ();
        my @missing = ();
        my $recordCount = 1;
        for my $fieldDescriptor (@fieldList) {
            # Get the field name and save it. Note we need to fix it up so the hyphens
            # are converted to underscores.
            my $fieldName = $fieldDescriptor->{name};
            push @fieldNameList, _FixName($fieldName);
            # Look for the named field in the incoming structure. Note that we are looking
            # for the real field name, not the fixed-up one!
            if (exists $fieldHash->{$fieldName}) {
                # Here we found the field. Stash it in the value list.
                my $value = $fieldHash->{$fieldName};
                push @valueList, $value;
                # If the value is a list, we may need to increment the record count.
                if (ref $value eq "ARRAY") {
                    my $thisCount = @{$value};
                    if ($recordCount == 1) {
                        # Here we have our first list, so we save its count.
                        $recordCount = $thisCount;
                    } elsif ($recordCount != $thisCount) {
                        # Here we have a second list, so its length has to match the
                        # previous lists.
                        Trace("Field $value in new $newObjectType object has an invalid list length $thisCount. Expected $recordCount.") if T(0);
                        $retVal = 0;
            } else {
                # Here the field is not present. Flag it as missing.
                push @missing, $fieldName;
        # Only proceed if there are no missing fields.
        if (@missing > 0) {
            Trace("Relation $relationName for $newObjectType skipped due to missing fields: " .
                join(' ', @missing)) if T(1);
        } else {
            # Build the INSERT statement.
            my $statement = "INSERT INTO $relationName (" . join (', ', @fieldNameList) .
                ") VALUES (";
            # Create a marker list of the proper size and put it in the statement.
            my @markers = ();
            while (@markers < @fieldNameList) { push @markers, '?'; }
            $statement .= join(', ', @markers) . ")";
            # We have the insert statement, so prepare it.
            my $sth = $dbh->prepare_command($statement);
            Trace("Insert statement prepared: $statement") if T(3);
            # Now we loop through the values. If a value is scalar, we use it unmodified. If it's
            # a list, we use the current element. The values are stored in the @parameterList array.
            my $done = 0;
            for (my $i = 0; $i < $recordCount; $i++) {
                # Clear the parameter list array.
                my @parameterList = ();
                # Loop through the values.
                for my $value (@valueList) {
                    # Check to see if this is a scalar value.
                        # Here we have a list value. Pull the current entry.
                        push @parameterList, $value->[$i];
                    } else {
                        # Here we have a scalar value. Use it unmodified.
                        push @parameterList, $value;
                # Execute the INSERT statement with the specified parameter list.
                $retVal = $sth->execute(@parameterList);
                if (!$retVal) {
                    my $errorString = $sth->errstr();
                    Confess("Error inserting into $relationName: $errorString");
                } else {
                    Trace("Insert successful using $parameterList[0].") if T(3);
    # Return a 1 for backward compatability.
    return 1;
=head3 UpdateEntity
    $erdb->UpdateEntity($entityName, $id, \%fields);
Update the values of an entity. This is an unprotected update, so it should only be
done if the database resides on a database server.
=over 4
=item entityName
Name of the entity to update. (This is the entity type.)
=item id
ID of the entity to update. If no entity exists with this ID, an error will be thrown.
=item fields
Reference to a hash mapping field names to their new values. All of the fields named
must be in the entity's primary relation, and they cannot any of them be the ID field.
=back
=cut
sub UpdateEntity {
    my ($self, $entityName, $id, $fields) = @_;
    # Get a list of the field names being updated.
    my @fieldList = keys %{$fields};
    # Verify that the fields exist.
    my $checker = $self->GetFieldTable($entityName);
    for my $field (@fieldList) {
        if ($field eq 'id') {
            Confess("Cannot update the ID field for entity $entityName.");
        } elsif ($checker->{$field}->{relation} ne $entityName) {
            Confess("Cannot find $field in primary relation of $entityName.");
    # Build the SQL statement.
    my @sets = ();
    my @valueList = ();
        push @sets, _FixName($field) . " = ?";
        push @valueList, $fields->{$field};
    my $command = "UPDATE $entityName SET " . join(", ", @sets) . " WHERE id = ?";
    # Add the ID to the list of binding values.
    push @valueList, $id;
    # Call SQL to do the work.
    my $rows = $self->{_dbh}->SQL($command, 0, @valueList);
    # Check for errors.
    if ($rows == 0) {
        Confess("Entity $id of type $entityName not found.");
=head3 LoadTable
    my $results = $erdb->LoadTable($fileName, $relationName, %options);
Load data from a tab-delimited file into a specified table, optionally re-creating the table
first.
=over 4
=item fileName
Name of the file from which the table data should be loaded.
=item relationName
Name of the relation to be loaded. This is the same as the table name.
=item options
A hash of load options.
=item RETURN
Returns a statistical object containing a list of the error messages.
=back
The permissible options are as follows.
=over 4
=item truncate
If TRUE, then the table will be erased before loading.
=item mode
Mode in which the load should operate, either C<low_priority> or C<concurrent>.
This option is only applicable to a MySQL database.
=item partial
If TRUE, then it is assumed that this is a partial load, and the table will not
be analyzed and compacted at the end.
=back
=cut
sub LoadTable {
    my ($self, $fileName, $relationName, %options) = @_;
    # Create the statistical return object.
    my $retVal = _GetLoadStats();
    # Trace the fact of the load.
    Trace("Loading table $relationName from $fileName") if T(2);
    # Get the input file size.
    my $fileSize = -s $fileName;
    # Get the relation data.
    my $relation = $self->_FindRelation($relationName);
    # Check the truncation flag.
    if ($options{truncate}) {
        Trace("Creating table $relationName") if T(2);
        # Compute the row count estimate. We take the size of the load file,
        # divide it by the estimated row size, and then multiply by 2 to
        # leave extra room. We postulate a minimum row count of 1000 to
        # prevent problems with incoming empty load files.
        my $rowSize = $self->EstimateRowSize($relationName);
        my $estimate = $fileSize * 8 / $rowSize;
        if ($estimate < 1000) {
            $estimate = 1000;
        # Re-create the table without its index.
        $self->CreateTable($relationName, 0, $estimate);
        # If this is a pre-index DBMS, create the index here.
        if ($dbh->{_preIndex}) {
            eval {
            if ($@) {
                $retVal->AddMessage($@);
    # Load the table.
    my $rv;
    eval {
        $rv = $dbh->load_table(file => $fileName, tbl => $relationName, style => $options{mode});
    if (!defined $rv) {
        $retVal->AddMessage($@) if ($@);
        $retVal->AddMessage("Table load failed for $relationName using $fileName: " . $dbh->error_message);
        Trace("Table load failed for $relationName.") if T(1);
    } else {
        # Here we successfully loaded the table.
        $retVal->Add("tables");
        my $size = -s $fileName;
        Trace("$size bytes loaded into $relationName.") if T(2);
        $retVal->Add("bytes", $size);
        # If we're rebuilding, we need to create the table indexes.
            # Indexes are created here for PostGres. For PostGres, indexes are
            # best built at the end. For MySQL, the reverse is true.
            if (! $dbh->{_preIndex}) {
                eval {
                if ($@) {
            # The full-text index (if any) is always built last, even for MySQL.
            # First we need to see if this table has a full-text index. Only
            # primary relations are allowed that privilege.
            Trace("Checking for full-text index on $relationName.") if T(2);
            if ($self->_IsPrimary($relationName)) {
                $self->CreateSearchIndex($relationName);
    # Analyze the table to improve performance.
    if (! $options{partial}) {
        Trace("Analyzing and compacting $relationName.") if T(3);
        $self->Analyze($relationName);
    Trace("$relationName load completed.") if T(3);
    # Return the statistics.
    return $retVal;
=head3 Analyze
    $erdb->Analyze($tableName);
Analyze and compact a table in the database. This is useful after a load
to improve the performance of the indexes.
=over 4
=item tableName
Name of the table to be analyzed and compacted.
=back
=cut
sub Analyze {
    my ($self, $tableName) = @_;
    # Analyze the table.
    $self->{_dbh}->vacuum_it($tableName);
=head3 TruncateTable
    $erdb->TruncateTable($table);
Delete all rows from a table quickly. This uses the built-in SQL
C<TRUNCATE> statement, which effectively drops and re-creates a table
with all its settings intact.
=over 4
=item table
Name of the table to be cleared.
=back
=cut
sub TruncateTable {
    my ($self, $table) = @_;
    # Execute a truncation comment.
    $dbh->SQL("TRUNCATE TABLE $table");
=head3 CreateSearchIndex
    $erdb->CreateSearchIndex($objectName);
Check for a full-text search index on the specified entity or relationship object, and
if one is required, rebuild it.
=over 4
=item objectName
Name of the entity or relationship to be indexed.
=back
=cut
sub CreateSearchIndex {
    # Get the relation's entity/relationship structure.
    my $structure = $self->_GetStructure($objectName);
    Trace("Checking for search fields in $objectName.") if T(3);
    # Check for a searchable fields list.
    if (exists $structure->{searchFields}) {
        # Here we know that we need to create a full-text search index.
        # Get an SQL-formatted field name list.
        my $fields = join(", ", _FixNames(@{$structure->{searchFields}}));
        # Create the index. If it already exists, it will be dropped.
        $dbh->create_index(tbl => $objectName, idx => "search_idx",
                           flds => $fields, kind => 'fulltext');
        Trace("Index created for $fields in $objectName.") if T(2);
=head3 DropRelation
    $erdb->DropRelation($relationName);
Physically drop a relation from the database.
=over 4
=item relationName
Name of the relation to drop. If it does not exist, this method will have
no effect.
=back
=cut
sub DropRelation {
    # Drop the relation. The method used here has no effect if the relation
    # does not exist.
    Trace("Invoking DB Kernel to drop $relationName.") if T(3);
=head3 MatchSqlPattern
    my $matched = ERDB::MatchSqlPattern($value, $pattern);
Determine whether or not a specified value matches an SQL pattern. An SQL
pattern has two wild card characters: C<%> that matches multiple characters,
and C<_> that matches a single character. These can be escaped using a
backslash (C<\>). We pull this off by converting the SQL pattern to a
PERL regular expression. As per SQL rules, the match is case-insensitive.
=over 4
=item value
Value to be matched against the pattern. Note that an undefined or empty
value will not match anything.
=item pattern
SQL pattern against which to match the value. An undefined or empty pattern will
match everything.
=item RETURN
Returns TRUE if the value and pattern match, else FALSE.
=back
=cut
sub MatchSqlPattern {
    my ($value, $pattern) = @_;
    my $retVal;
    # Insure we have a pattern.
    if (! defined($pattern) || $pattern eq "") {
        $retVal = 1;
    } else {
        # Break the pattern into pieces around the wildcard characters. Because we
        # use parentheses in the split function's delimiter expression, we'll get
        # list elements for the delimiters as well as the rest of the string.
        my @pieces = split /([_%]|\\[_%])/, $pattern;
        # Check some fast special cases.
        if ($pattern eq '%') {
            # A null pattern matches everything.
            $retVal = 1;
        } elsif (@pieces == 1) {
            # No wildcards, so we have a literal comparison. Note we're case-insensitive.
            $retVal = (lc($value) eq lc($pattern));
        } elsif (@pieces == 2 && $pieces[1] eq '%') {
            # A wildcard at the end, so we have a substring match. This is also case-insensitive.
            $retVal = (lc(substr($value, 0, length($pieces[0]))) eq lc($pieces[0]));
        } else {
            # Okay, we have to do it the hard way. Convert each piece to a PERL pattern.
            my $realPattern = "";
            for my $piece (@pieces) {
                # Determine the type of piece.
                if ($piece eq "") {
                    # Empty pieces are ignored.
                } elsif ($piece eq "%") {
                    # Here we have a multi-character wildcard. Note that it can match
                    # zero or more characters.
                    $realPattern .= ".*"
                } elsif ($piece eq "_") {
                    # Here we have a single-character wildcard.
                    $realPattern .= ".";
                } elsif ($piece eq "\\%" || $piece eq "\\_") {
                    # This is an escape sequence (which is a rare thing, actually).
                    $realPattern .= substr($piece, 1, 1);
                } else {
                    # Here we have raw text.
                    $realPattern .= quotemeta($piece);
            # Do the match.
            $retVal = ($value =~ /^$realPattern$/i ? 1 : 0);
    # Return the result.
    return $retVal;
=head3 GetEntity
    my $entityObject = $erdb->GetEntity($entityType, $ID);
Return an object describing the entity instance with a specified ID.
=over 4
=item entityType
Entity type name.
=item ID
ID of the desired entity.
=item RETURN
Returns a B<ERDBObject> representing the desired entity instance, or an undefined value if no
instance is found with the specified key.
=back
=cut
sub GetEntity {
    my ($self, $entityType, $ID) = @_;
    # Create a query.
    my $query = $self->Get([$entityType], "$entityType(id) = ?", [$ID]);
    # Get the first (and only) object.
    my $retVal = $query->Fetch();
    if (T(3)) {
        if ($retVal) {
            Trace("Entity $entityType \"$ID\" found.");
        } else {
            Trace("Entity $entityType \"$ID\" not found.");
    return $retVal;
=head3 GetChoices
    my @values = $erdb->GetChoices($entityName, $fieldName);
Return a list of all the values for the specified field that are represented in the
specified entity.
Note that if the field is not indexed, then this will be a very slow operation.
=over 4
=item entityName
Name of an entity in the database.
=item fieldName
Name of a field belonging to the entity. This is a raw field name without
the standard parenthesized notation used in most calls.
=item RETURN
Returns a list of the distinct values for the specified field in the database.
=back
=cut
sub GetChoices {
    my ($self, $entityName, $fieldName) = @_;
    my @retVal;
    # Get the entity data structure.
    my $entityData = $self->_GetStructure($entityName);
    # Get the field.
    if (! exists $fieldHash->{$fieldName}) {
        Confess("$fieldName not found in $entityName.");
    } else {
        # Get the name of the relation containing the field.
        my $relation = $fieldHash->{$fieldName}->{relation};
        # Fix up the field name.
        my $realName = _FixName($fieldName);
        # Get the database handle.
        my $dbh = $self->{_dbh};
        # Query the database.
        my $results = $dbh->SQL("SELECT DISTINCT $realName FROM $relation");
        # Clean the results. They are stored as a list of lists, and we just want the one list.
        @retVal = sort map { $_->[0] } @{$results};
    return @retVal;
=head3 GetEntityValues
    my @values = $erdb->GetEntityValues($entityType, $ID, \@fields);
Return a list of values from a specified entity instance. If the entity instance
does not exist, an empty list is returned.
=over 4
=item entityType
Entity type name.
=item ID
=item fields
List of field names, each of the form I<objectName>C<(>I<fieldName>C<)>.
=item RETURN
Returns a flattened list of the values of the specified fields for the specified entity.
=back
=cut
sub GetEntityValues {
    my ($self, $entityType, $ID, $fields) = @_;
    # Get the specified entity.
    my $entity = $self->GetEntity($entityType, $ID);
    # Declare the return list.
    my @retVal = ();
    # If we found the entity, push the values into the return list.
    if ($entity) {
        push @retVal, $entity->Values($fields);
    return @retVal;
=head3 GetAll
    my @list = $erdb->GetAll(\@objectNames, $filterClause, \@parameters, \@fields, $count);
Return a list of values taken from the objects returned by a query. The first three
parameters correspond to the parameters of the L</Get> method. The final parameter is
a list of the fields desired from each record found by the query. The field name
syntax is the standard syntax used for fields in the B<ERDB> system--
B<I<objectName>(I<fieldName>)>-- where I<objectName> is the name of the relevant entity
or relationship and I<fieldName> is the name of the field.
The list returned will be a list of lists. Each element of the list will contain
the values returned for the fields specified in the fourth parameter. If one of the
fields specified returns multiple values, they are flattened in with the rest. For
example, the following call will return a list of the features in a particular
spreadsheet cell, and each feature will be represented by a list containing the
feature ID followed by all of its essentiality determinations.
    @query = $erdb->Get(['ContainsFeature', 'Feature'], "ContainsFeature(from-link) = ?", [$ssCellID], ['Feature(id)', 'Feature(essential)']);
=over 4
=item objectNames
=item filterClause
=item parameterList
=item fields
List of the fields to be returned in each element of the list returned.
=item count
Maximum number of records to return. If omitted or 0, all available records will be returned.
=item RETURN
Returns a list of list references. Each element of the return list contains the values for the
fields specified in the B<fields> parameter.
=back
=cut
#: Return Type @@;
sub GetAll {
    my ($self, $objectNames, $filterClause, $parameterList, $fields, $count) = @_;
    # Translate the parameters from a list reference to a list. If the parameter
    # list is a scalar we convert it into a singleton list.
    my @parmList = ();
    if (ref $parameterList eq "ARRAY") {
        Trace("GetAll parm list is an array.") if T(4);
        @parmList = @{$parameterList};
    } else {
        Trace("GetAll parm list is a scalar: $parameterList.") if T(4);
        push @parmList, $parameterList;
    # Insure the counter has a value.
    if (!defined $count) {
        $count = 0;
    # Add the row limit to the filter clause.
    if ($count > 0) {
        $filterClause .= " LIMIT $count";
    # Create the query.
    my $query = $self->Get($objectNames, $filterClause, \@parmList);
    # Set up a counter of the number of records read.
    my $fetched = 0;
    # Loop through the records returned, extracting the fields. Note that if the
    # counter is non-zero, we stop when the number of records read hits the count.
    my @retVal = ();
    while (($count == 0 || $fetched < $count) && (my $row = $query->Fetch())) {
        my @rowData = $row->Values($fields);
        push @retVal, \@rowData;
        $fetched++;
    # Return the resulting list.
    return @retVal;
=head3 Exists
    my $found = $sprout->Exists($entityName, $entityID);
Return TRUE if an entity exists, else FALSE.
=over 4
=item entityName
Name of the entity type (e.g. C<Feature>) relevant to the existence check.
=item entityID
ID of the entity instance whose existence is to be checked.
=item RETURN
Returns TRUE if the entity instance exists, else FALSE.
=back
=cut
#: Return Type $;
sub Exists {
    my ($self, $entityName, $entityID) = @_;
    # Check for the entity instance.
    Trace("Checking existence of $entityName with ID=$entityID.") if T(4);
    my $testInstance = $self->GetEntity($entityName, $entityID);
    # Return an existence indicator.
    my $retVal = ($testInstance ? 1 : 0);
    return $retVal;
=head3 EstimateRowSize
    my $rowSize = $erdb->EstimateRowSize($relName);
Estimate the row size of the specified relation. The estimated row size is computed by adding
up the average length for each data type.
=over 4
=item relName
Name of the relation whose estimated row size is desired.
=item RETURN
Returns an estimate of the row size for the specified relation.
=back
=cut
#: Return Type $;
sub EstimateRowSize {
    my ($self, $relName) = @_;
    my $retVal = 0;
    # Find the relation descriptor.
    my $relation = $self->_FindRelation($relName);
    # Get the list of fields.
    for my $fieldData (@{$relation->{Fields}}) {
        # Get the field type and add its length.
        my $fieldLen = $TypeTable{$fieldData->{type}}->{avgLen};
        $retVal += $fieldLen;
    return $retVal;
=head3 GetFieldTable
    my $fieldHash = $self->GetFieldTable($objectnName);
Get the field structure for a specified entity or relationship.
=over 4
=item objectName
Name of the desired entity or relationship.
=item RETURN
The table containing the field descriptors for the specified object.
=back
=cut
sub GetFieldTable {
    # Get the descriptor from the metadata.
    my $objectData = $self->_GetStructure($objectName);
    # Return the object's field table.
    return $objectData->{Fields};
=head3 SplitKeywords
    my @keywords = ERDB::SplitKeywords($keywordString);
This method returns a list of the positive keywords in the specified
keyword string. All of the operators will have been stripped off,
and if the keyword is preceded by a minus operator (C<->), it will
not be in the list returned. The idea here is to get a list of the
keywords the user wants to see. The list will be processed to remove
duplicates.
It is possible to create a string that confuses this method. For example
    frog toad -frog
would return both C<frog> and C<toad>. If this is a problem we can deal
with it later.
=over 4
=item keywordString
The keyword string to be parsed.
=item RETURN
Returns a list of the words in the keyword string the user wants to
see.
=back
=cut
sub SplitKeywords {
    my ($keywordString) = @_;
    # Make a safety copy of the string. (This helps during debugging.)
    my $workString = $keywordString;
    # Convert operators we don't care about to spaces.
    $workString =~ tr/+"()<>/ /;
    # Split the rest of the string along space boundaries. Note that we
    # eliminate any words that are zero length or begin with a minus sign.
    my @wordList = grep { $_ && substr($_, 0, 1) ne "-" } split /\s+/, $workString;
    # Use a hash to remove duplicates.
    my %words = map { $_ => 1 } @wordList;
    return sort keys %words;
=head3 ValidateFieldName
    my $okFlag = ERDB::ValidateFieldName($fieldName);
Return TRUE if the specified field name is valid, else FALSE. Valid field names must
be hyphenated words subject to certain restrictions.
=over 4
=item fieldName
Field name to be validated.
=item RETURN
Returns TRUE if the field name is valid, else FALSE.
=back
=cut
sub ValidateFieldName {
    my ($fieldName) = @_;
    # Declare the return variable. The field name is valid until we hear
    # differently.
    my $retVal = 1;
    # Compute the maximum name length.
    my $maxLen = $TypeTable{'name-string'}->{maxLen};
    # Look for bad stuff in the name.
    if ($fieldName =~ /--/) {
        # Here we have a doubled minus sign.
        Trace("Field name $fieldName has a doubled hyphen.") if T(1);
        $retVal = 0;
    } elsif ($fieldName !~ /^[A-Za-z]/) {
        # Here the field name is missing the initial letter.
        Trace("Field name $fieldName does not begin with a letter.") if T(1);
        $retVal = 0;
    } elsif (length($fieldName) > $maxLen) {
        # Here the field name is too long.
        Trace("Maximum field name length is $maxLen. Field name must be truncated to " . substr($fieldName,0, $maxLen) . ".");
    } else {
        # Strip out the minus signs. Everything remaining must be a letter,
        # underscore, or digit.
        my $strippedName = $fieldName;
        $strippedName =~ s/-//g;
        if ($strippedName !~ /^(\w|\d)+$/) {
            Trace("Field name $fieldName contains illegal characters.") if T(1);
            $retVal = 0;
    return $retVal;
=head3 ReadMetaXML
    my $rawMetaData = ERDB::ReadDBD($fileName);
This method reads a raw database definition XML file and returns it.
Normally, the metadata used by the ERDB system has been processed and
modified to make it easier to load and retrieve the data; however,
this method can be used to get the data in its raw form.
=over 4
=item fileName
Name of the XML file to read.
=item RETURN
Returns a hash reference containing the raw XML data from the specified file.
=back
=cut
sub ReadMetaXML {
    my ($fileName) = @_;
    # Read the XML.
    my $retVal = XML::Simple::XMLin($fileName, %XmlOptions, %XmlInOpts);
    Trace("XML metadata loaded from file $fileName.") if T(1);
    return $retVal;
=head3 GetEntityFieldHash
    my $fieldHashRef = ERDB::GetEntityFieldHash($structure, $entityName);
Get the field hash of the named entity in the specified raw XML structure.
The field hash may not exist, in which case we need to create it.
=over 4
=item structure
Raw XML structure defininng the database. This is not the run-time XML used by
an ERDB object, since that has all sorts of optimizations built-in.
=item entityName
Name of the entity whose field structure is desired.
=item RETURN
Returns the field hash used to define the entity's fields.
=back
=cut
sub GetEntityFieldHash {
    my ($structure, $entityName) = @_;
    # Get the entity structure.
    my $entityData = $structure->{Entities}->{$entityName};
    # Look for a field structure.
    my $retVal = $entityData->{Fields};
    # If it doesn't exist, create it.
        $entityData->{Fields} = {};
    return $retVal;
=head3 WriteMetaXML
    ERDB::WriteMetaXML($structure, $fileName);
Write the metadata XML to a file. This method is the reverse of L</ReadMetaXML>, and is
used to update the database definition. It must be used with care, however, since it
will only work on a raw structure, not on the processed structure created by an ERDB
constructor.
=over 4
=item structure
XML structure to be written to the file.
=item fileName
Name of the output file to which the updated XML should be stored.
=back
=cut
sub WriteMetaXML {
    my ($structure, $fileName) = @_;
    # Compute the output.
    my $fileString = XML::Simple::XMLout($structure, %XmlOptions, %XmlOutOpts);
    # Write it to the file.
    my $xmlOut = Open(undef, ">$fileName");
    print $xmlOut $fileString;
=head3 HTMLNote
Convert a note or comment to HTML by replacing some bulletin-board codes with HTML. The codes
supported are C<[b]> for B<bold>, C<[i]> for I<italics>, and C<[p]> for a new paragraph.
Except for C<[p]>, all the codes are closed by slash-codes. So, for
example, C<[b]Feature[/b]> displays the string C<Feature> in boldface.
    my $realHtml = ERDB::HTMLNote($dataString);
=over 4
=item dataString
String to convert to HTML.
=item RETURN
An HTML string derived from the input string.
=back
=cut
sub HTMLNote {
    # Get the parameter.
    my ($dataString) = @_;
    # HTML-escape the text.
    my $retVal = CGI::escapeHTML($dataString);
    # Substitute the bulletin board codes.
    $retVal =~ s!\[(/?[bi])\]!<$1>!g;
    $retVal =~ s!\[p\]!</p><p>!g;
    $retVal =~ s!\[link\s+([^\]]+)\]!<a href="$1">!g;
    $retVal =~ s!\[/link\]!</a>!g;
    return $retVal;
=head3 WikiNote
Convert a note or comment to Wiki text by replacing some bulletin-board codes with HTML. The codes
    my $wikiText = ERDB::WikiNote($dataString);
=over 4
=item dataString
String to convert to Wiki text.
=item RETURN
An Wiki text string derived from the input string.
=back
=cut
sub WikiNote {
    my $italic = WikiTools::ItalicCode();
    $retVal =~ s/\[\/?i\]/$italic/g;
    my $bold = WikiTools::BoldCode();
    $retVal =~ s/\[\/?b\]/$bold/g;
    # Paragraph breaks are the same no matter which Wiki you're using.
    $retVal =~ s!\[p\]!\n\n!g;
    # Now we do the links, which are complicated by the need to know two
    # things: the target URL and the text.
    while ($retVal =~ /\[link\s+([^\]]+)\]([^\[]+)\[\/link\]/g) {
        # Replace the matched string with the Wiki markup for links. Note that
        # $-[0] is the starting position of the match for the entire expression,
        # and $+[0] is past the ending position.
        substr $retVal, $-[0], $+[0] - $-[0], WikiTools::LinkMarkup($1, $2);
    return $retVal;
=head3 BeginTran
    $erdb->BeginTran();
Start a database transaction.
=cut
sub BeginTran {
    my ($self) = @_;
    $self->{_dbh}->begin_tran();
=head3 CommitTran
    $erdb->CommitTran();
Commit an active database transaction.
=cut
sub CommitTran {
    my ($self) = @_;
    $self->{_dbh}->commit_tran();
=head3 RollbackTran
    $erdb->RollbackTran();
Roll back an active database transaction.
=cut
sub RollbackTran {
    my ($self) = @_;
    $self->{_dbh}->roll_tran();
=head3 UpdateField
    my $count = $erdb->UpdateField($objectNames, $fieldName, $oldValue, $newValue, $filter, $parms);
Update all occurrences of a specific field value to a new value. The number of rows changed will be
returned.
=over 4
=item fieldName
Name of the field in standard I<objectName>C<(>I<fieldName>C<)> format.
=item oldValue
Value to be modified. All occurrences of this value in the named field will be replaced by the
new value.
=item newValue
New value to be substituted for the old value when it's found.
=item filter
A standard ERDB filter clause (see L</Get>). The filter will be applied before any substitutions take place.
=item parms
Reference to a list of parameter values in the filter.
=item RETURN
Returns the number of rows modified.
=back
=cut
sub UpdateField {
    my ($self, $fieldName, $oldValue, $newValue, $filter, $parms) = @_;
    # Get the object and field names from the field name parameter.
    $fieldName =~ /^([^(]+)\(([^)]+)\)/;
    my $objectName = $1;
    my $realFieldName = _FixName($2);
    # Add the old value to the filter. Note we allow the possibility that no
    # filter was specified.
    my $realFilter = "$fieldName = ?";
    if ($filter) {
        $realFilter .= " AND $filter";
    # Format the query filter.
        $self->_SetupSQL([$objectName], $realFilter);
    # Create the query. Since there is only one object name, the mapped-name data is not
    # necessary. Neither is the FROM clause.
    $suffix =~ s/^FROM.+WHERE\s+//;
    # Create the update statement.
    my $command = "UPDATE $objectName SET $realFieldName = ? WHERE $suffix";
    # Add the old and new values to the parameter list. Note we allow the possibility that
    # there are no user-supplied parameters.
    my @params = ($newValue, $oldValue);
    if (defined $parms) {
        push @params, @{$parms};
    # Execute the update.
    my $retVal = $dbh->SQL($command, 0, @params);
    # Make the funky zero a real zero.
    if ($retVal == 0) {
        $retVal = 0;
    return $retVal;
=head2 Data Mining Methods
=head3 GetUsefulCrossValues
    my @attrNames = $sprout->GetUsefulCrossValues($sourceEntity, $relationship);
Return a list of the useful attributes that would be returned by a B<Cross> call
from an entity of the source entity type through the specified relationship. This
means it will return the fields of the target entity type and the intersection data
fields in the relationship. Only primary table fields are returned. In other words,
the field names returned will be for fields where there is always one and only one
value.
=over 4
=item sourceEntity
Name of the entity from which the relationship crossing will start.
=item relationship
Name of the relationship being crossed.
=item RETURN
Returns a list of field names in Sprout field format (I<objectName>C<(>I<fieldName>C<)>.
=back
=cut
#: Return Type @;
sub GetUsefulCrossValues {
    my ($self, $sourceEntity, $relationship) = @_;
    my @retVal = ();
    # Determine the target entity for the relationship. This is whichever entity is not
    # the source entity. So, if the source entity is the FROM, we'll get the name of
    # the TO, and vice versa.
    my $relStructure = $self->_GetStructure($relationship);
    my $targetEntityType = ($relStructure->{from} eq $sourceEntity ? "to" : "from");
    my $targetEntity = $relStructure->{$targetEntityType};
    # Get the field table for the entity.
    my $entityFields = $self->GetFieldTable($targetEntity);
    # The field table is a hash. The hash key is the field name. The hash value is a structure.
    # For the entity fields, the key aspect of the target structure is that the {relation} value
    # must match the entity name.
    my @fieldList = map { "$targetEntity($_)" } grep { $entityFields->{$_}->{relation} eq $targetEntity }
                        keys %{$entityFields};
    # Push the fields found onto the return variable.
    push @retVal, sort @fieldList;
    # Get the field table for the relationship.
    my $relationshipFields = $self->GetFieldTable($relationship);
    # Here we have a different rule. We want all the fields other than "from-link" and "to-link".
    # This may end up being an empty set.
    my @fieldList2 = map { "$relationship($_)" } grep { $_ ne "from-link" && $_ ne "to-link" }
                        keys %{$relationshipFields};
    # Push these onto the return list.
    push @retVal, sort @fieldList2;
    return @retVal;
=head3 FindColumn
    my $colIndex = ERDB::FindColumn($headerLine, $columnIdentifier);
Return the location a desired column in a data mining header line. The data
mining header line is a tab-separated list of column names. The column
identifier is either the numerical index of a column or the actual column
name.
=over 4
=item headerLine
The header line from a data mining command, which consists of a tab-separated
=item columnIdentifier
Either the ordinal number of the desired column (1-based), or the name of the
desired column.
=item RETURN
Returns the array index (0-based) of the desired column.
=back
=cut
sub FindColumn {
    my ($headerLine, $columnIdentifier) = @_;
    my $retVal;
    # Split the header line into column names.
    my @headers = ParseColumns($headerLine);
    # Determine whether we have a number or a name.
    if ($columnIdentifier =~ /^\d+$/) {
        # Here we have a number. Subtract 1 and validate the result.
        $retVal = $columnIdentifier - 1;
        if ($retVal < 0 || $retVal > $#headers) {
            Confess("Invalid column identifer \"$columnIdentifier\": value out of range.");
    } else {
        # Here we have a name. We need to find it in the list.
        for (my $i = 0; $i <= $#headers && ! defined($retVal); $i++) {
            if ($headers[$i] eq $columnIdentifier) {
                $retVal = $i;
            Confess("Invalid column identifier \"$columnIdentifier\": value not found.");
    return $retVal;
=head3 ParseColumns
    my @columns = ERDB::ParseColumns($line);
Convert the specified data line to a list of columns.
=over 4
=item line
A data mining input, consisting of a tab-separated list of columns terminated by a
new-line.
=item RETURN
Returns a list consisting of the column values.
=back
=cut
sub ParseColumns {
    my ($line) = @_;
    # Chop off the line-end.
    chomp $line;
    # Split it into a list.
    my @retVal = split(/\t/, $line);
    return @retVal;
=head2 Virtual Methods
=head3 _CreatePPOIndex
    my $index = ERDB::_CreatePPOIndex($indexObject);
Convert the XML for an ERDB index to the XML structure for a PPO
index.
=over 4
=item indexObject
ERDB XML structure for an index.
=item RETURN
PPO XML structure for the same index.
=back
=cut
sub _CreatePPOIndex {
    my ($indexObject) = @_;
    # The incoming index contains a list of the index fields in the IndexFields
    # member. We loop through it to create the index tags.
    my @fields = map { { label => _FixName($_->{name}) } } @{$indexObject->{IndexFields}};
    # Wrap the fields in attribute tags.
    my $retVal = { attribute => \@fields };
    return $retVal;
=head3 _CreatePPOField
    my $fieldXML = ERDB::_CreatePPOField($fieldName, $fieldObject);
Convert the ERDB XML structure for a field to a PPO scalar XML structure.
=over 4
=item fieldName
Name of the scalar field.
=item fieldObject
ERDB XML structure describing the field.
=item RETURN
Returns a PPO XML structure for the same field.
=back
=cut
sub _CreatePPOField {
    my ($fieldName, $fieldObject) = @_;
    # Get the field type.
    my $type = $TypeTable{$fieldObject->{type}}->{sqlType};
    $fieldName = _FixName($fieldName);
    # Build the scalar tag.
    my $retVal = { label => $fieldName, type => $type };
    return $retVal;
=head3 CleanKeywords
    my $cleanedString = $erdb->CleanKeywords($searchExpression);
Clean up a search expression or keyword list. This is a virtual method that may
be overridden by the subclass. The base-class method removes extra spaces
and converts everything to lower case.
=over 4
=item searchExpression
Search expression or keyword list to clean. Note that a search expression may
contain boolean operators which need to be preserved. This includes leading
minus signs.
=item RETURN
Cleaned expression or keyword list.
=back
=cut
sub CleanKeywords {
    my ($self, $searchExpression) = @_;
    # Lower-case the expression and copy it into the return variable. Note that we insure we
    # don't accidentally end up with an undefined value.
    my $retVal = lc($searchExpression || "");
    # Remove extra spaces.
    $retVal =~ s/\s+/ /g;
    $retVal =~ s/(^\s+)|(\s+$)//g;
    return $retVal;
=head3 GetSourceObject
    my $source = $erdb->GetSourceObject($entityName);
Return the object to be used in loading special attributes of the specified entity. The
algorithm for loading special attributes is stored in the C<DataGen> elements of the
XML
=head2 Internal Utility Methods
=head3 _RelationMap
    my @relationMap = _RelationMap($mappedNameHashRef, $mappedNameListRef);
Create the relation map for an SQL query. The relation map is used by B<ERDBObject>
to determine how to interpret the results of the query.
=over 4
=item mappedNameHashRef
Reference to a hash that maps modified object names to real object names.
=item mappedNameListRef
Reference to a list of modified object names in the order they appear in the
SELECT list.
=item RETURN
Returns a list of 2-tuples. Each tuple consists of an object name as used in the
query followed by the actual name of that object. This enables the B<ERDBObject> to
determine the order of the tables in the query and which object name belongs to each
mapped object name. Most of the time these two values are the same; however, if a
relation occurs twice in the query, the relation name in the field list and WHERE
clause will use a mapped name (generally the actual relation name with a numeric
suffix) that does not match the actual relation name.
=back
=cut
sub _RelationMap {
    my ($mappedNameHashRef, $mappedNameListRef) = @_;
    my @retVal = ();
    # Build the map.
    for my $mappedName (@{$mappedNameListRef}) {
        push @retVal, [$mappedName, $mappedNameHashRef->{$mappedName}];
    # Return it.
    return @retVal;
=head3 _SetupSQL
Process a list of object names and a filter clause so that they can be used to
build an SQL statement. This method takes in a reference to a list of object names
and a filter clause. It will return a corrected filter clause, a list of mapped
names and the mapped name hash.
This is an instance method.
=over 4
=item objectNames
Reference to a list of the object names to be included in the query.
=item filterClause
A string containing the WHERE clause for the query (without the C<WHERE>) and also
optionally the C<ORDER BY> and C<LIMIT> clauses.
=item matchClause
An optional full-text search clause. If specified, it will be inserted at the
front of the WHERE clause. It should already be SQL-formatted; that is, the
field names should be in the form I<table>C<.>I<fieldName>.
=item RETURN
Returns a three-element list. The first element is the SQL statement suffix, beginning
with the FROM clause. The second element is a reference to a list of the names to be
used in retrieving the fields. The third element is a hash mapping the names to the
objects they represent.
=back
=cut
sub _SetupSQL {
    my ($self, $objectNames, $filterClause, $matchClause) = @_;
    # Adjust the list of object names to account for multiple occurrences of the
    # same object. We start with a hash table keyed on object name that will
    # return the object suffix. The first time an object is encountered it will
    # not be found in the hash. The next time the hash will map the object name
    # to 2, then 3, and so forth.
    my %objectHash = ();
    # This list will contain the object names as they are to appear in the
    # FROM list.
    my @fromList = ();
    # This list contains the suffixed object name for each object. It is exactly
    # parallel to the list in the $objectNames parameter.
    my @mappedNameList = ();
    # Finally, this hash translates from a mapped name to its original object name.
    my %mappedNameHash = ();
    # Now we create the lists. Note that for every single name we push something into
    # @fromList and @mappedNameList. This insures that those two arrays are exactly
    # parallel to $objectNames.
    for my $objectName (@{$objectNames}) {
        # Get the next suffix for this object.
        my $suffix = $objectHash{$objectName};
        if (! $suffix) {
            # Here we are seeing the object for the first time. The object name
            # is used as is.
            push @mappedNameList, $objectName;
            push @fromList, $objectName;
            $mappedNameHash{$objectName} = $objectName;
            # Denote the next suffix will be 2.
            $objectHash{$objectName} = 2;
        } else {
            # Here we've seen the object before. We construct a new name using
            # the suffix from the hash and update the hash.
            my $mappedName = "$objectName$suffix";
            $objectHash{$objectName} = $suffix + 1;
            # The FROM list has the object name followed by the mapped name. This
            # tells SQL it's still the same table, but we're using a different name
            # for it to avoid confusion.
            push @fromList, "$objectName $mappedName";
            # The mapped-name list contains the real mapped name.
            push @mappedNameList, $mappedName;
            # Finally, enable us to get back from the mapped name to the object name.
            $mappedNameHash{$mappedName} = $objectName;
    # Begin the SELECT suffix. It starts with
    # FROM name1, name2, ... nameN
    my $suffix = "FROM " . join(', ', @fromList);
    # Now for the WHERE. First, we need a place for the filter string.
    my $filterString = "";
    # We will also keep a list of conditions to add to the WHERE clause in order to link
    # entities and relationships as well as primary relations to secondary ones.
    my @joinWhere = ();
    # Check for a filter clause.
    if ($filterClause) {
        # Here we have one, so we convert its field names and add it to the query. First,
        # We create a copy of the filter string we can work with.
        $filterString = $filterClause;
        # Next, we sort the object names by length. This helps protect us from finding
        # object names inside other object names when we're doing our search and replace.
        my @sortedNames = sort { length($b) - length($a) } @mappedNameList;
        # The final preparatory step is to create a hash table of relation names. The
        # table begins with the relation names already in the SELECT command. We may
        # need to add relations later if there is filtering on a field in a secondary
        # relation. The secondary relations are the ones that contain multiply-
        # occurring or optional fields.
        my %fromNames = map { $_ => 1 } @sortedNames;
        # We are ready to begin. We loop through the object names, replacing each
        # object name's field references by the corresponding SQL field reference.
        # Along the way, if we find a secondary relation, we will need to add it
        # to the FROM clause.
        for my $mappedName (@sortedNames) {
            # Get the length of the object name plus 2. This is the value we add to the
            # size of the field name to determine the size of the field reference as a
            # whole.
            my $nameLength = 2 + length $mappedName;
            # Get the real object name for this mapped name.
            my $objectName = $mappedNameHash{$mappedName};
            Trace("Processing $mappedName for object $objectName.") if T(4);
            # Get the object's field list.
            my $fieldList = $self->GetFieldTable($objectName);
            # Find the field references for this object.
            while ($filterString =~ m/$mappedName\(([^)]*)\)/g) {
                # At this point, $1 contains the field name, and the current position
                # is set immediately after the final parenthesis. We pull out the name of
                # the field and the position and length of the field reference as a whole.
                my $fieldName = $1;
                my $len = $nameLength + length $fieldName;
                my $pos = pos($filterString) - $len;
                # Insure the field exists.
                if (!exists $fieldList->{$fieldName}) {
                    Confess("Field $fieldName not found for object $objectName.");
                } else {
                    Trace("Processing $fieldName at position $pos.") if T(4);
                    # Get the field's relation.
                    my $relationName = $fieldList->{$fieldName}->{relation};
                    # Now we have a secondary relation. We need to insure it matches the
                    # mapped name of the primary relation. First we peel off the suffix
                    # from the mapped name.
                    my $mappingSuffix = substr $mappedName, length($objectName);
                    # Put the mapping suffix onto the relation name to get the
                    # mapped relation name.
                    my $mappedRelationName = "$relationName$mappingSuffix";
                    # Insure the relation is in the FROM clause.
                    if (!exists $fromNames{$mappedRelationName}) {
                        # Add the relation to the FROM clause.
                        if ($mappedRelationName eq $relationName) {
                            # The name is un-mapped, so we add it without
                            # any frills.
                            $suffix .= ", $relationName";
                            push @joinWhere, "$objectName.id = $relationName.id";
                        } else {
                            # Here we have a mapping situation.
                            $suffix .= ", $relationName $mappedRelationName";
                            push @joinWhere, "$mappedRelationName.id = $mappedName.id";
                        # Denote we have this relation available for future fields.
                        $fromNames{$mappedRelationName} = 1;
                    # Form an SQL field reference from the relation name and the field name.
                    my $sqlReference = "$mappedRelationName." . _FixName($fieldName);
                    # Put it into the filter string in place of the old value.
                    substr($filterString, $pos, $len) = $sqlReference;
                    # Reposition the search.
                    pos $filterString = $pos + length $sqlReference;
    # The next step is to join the objects together. We only need to do this if there
    # is more than one object in the object list. We start with the first object and
    # run through the objects after it. Note also that we make a safety copy of the
    # list before running through it, because we shift off the first object before
    # processing the rest.
    my @mappedObjectList = @mappedNameList;
    my $lastMappedObject = shift @mappedObjectList;
    # Get the join table.
    my $joinTable = $self->{_metaData}->{Joins};
    # Loop through the object list.
    for my $thisMappedObject (@mappedObjectList) {
        # Look for a join using the real object names.
        my $lastObject = $mappedNameHash{$lastMappedObject};
        my $thisObject = $mappedNameHash{$thisMappedObject};
        my $joinKey = "$lastObject/$thisObject";
        if (!exists $joinTable->{$joinKey}) {
            # Here there's no join, so we throw an error.
            Confess("No join exists to connect from $lastMappedObject to $thisMappedObject.");
        } else {
            # Get the join clause.
            my $unMappedJoin = $joinTable->{$joinKey};
            # Fix the names.
            $unMappedJoin =~ s/$lastObject/$lastMappedObject/;
            $unMappedJoin =~ s/$thisObject/$thisMappedObject/;
            push @joinWhere, $unMappedJoin;
            # Save this object as the last object for the next iteration.
            $lastMappedObject = $thisMappedObject;
    # Now we need to handle the whole ORDER BY / LIMIT thing. The important part
    # here is we want the filter clause to be empty if there's no WHERE filter.
    # We'll put the ORDER BY / LIMIT clauses in the following variable.
    my $orderClause = "";
    # This is only necessary if we have a filter string in which the ORDER BY
    # and LIMIT clauses can live.
    if ($filterString) {
        # Locate the ORDER BY or LIMIT verbs (if any). We use a non-greedy
        # operator so that we find the first occurrence of either verb.
        if ($filterString =~ m/^(.*?)\s*(ORDER BY|LIMIT)/g) {
            # Here we have an ORDER BY or LIMIT verb. Split it off of the filter string.
            my $pos = pos $filterString;
            $orderClause = $2 . substr($filterString, $pos);
            $filterString = $1;
    # All the things that are supposed to be in the WHERE clause of the
    # SELECT command need to be put into @joinWhere so we can string them
    # together. We begin with the match clause. This is important,
    # because the match clause's parameter mark must precede any parameter
    # marks in the filter string.
    if ($matchClause) {
        push @joinWhere, $matchClause;
    # Add the filter string. We put it in parentheses to avoid operator
    # precedence problems with the match clause or the joins.
        Trace("Filter string is \"$filterString\".") if T(4);
        push @joinWhere, "($filterString)";
    # String it all together into a big filter clause.
    if (@joinWhere) {
        $suffix .= " WHERE " . join(' AND ', @joinWhere);
    # Add the sort or limit clause (if any).
    if ($orderClause) {
        $suffix .= " $orderClause";
    # Return the suffix, the mapped name list, and the mapped name hash.
    return ($suffix, \@mappedNameList, \%mappedNameHash);
=head3 _GetStatementHandle
This method will prepare and execute an SQL query, returning the statement handle.
The main reason for doing this here is so that everybody who does SQL queries gets
the benefit of tracing.
=over 4
=item command
Command to prepare and execute.
=item params
Reference to a list of the values to be substituted in for the parameter marks.
=item RETURN
Returns a prepared and executed statement handle from which the caller can extract
results.
=back
=cut
sub _GetStatementHandle {
    my ($self, $command, $params) = @_;
    Confess("Invalid parameter list.") if (! defined($params) || ref($params) ne 'ARRAY');
    # Trace the query.
    Trace("SQL query: $command") if T(SQL => 3);
    Trace("PARMS: '" . (join "', '", @{$params}) . "'") if (T(SQL => 4) && (@{$params} > 0));
    # Prepare the command.
    my $sth = $dbh->prepare_command($command);
    # Execute it with the parameters bound in.
    $sth->execute(@{$params}) || Confess("SELECT error:  " . $sth->errstr());
    # Return the statement handle.
    return $sth;
=head3 _GetLoadStats
Return a blank statistics object for use by the load methods.
This is a static method.
=cut
sub _GetLoadStats{
    return Stats->new();
=head3 _DumpRelation
Dump the specified relation to the specified output file in tab-delimited format.
=over 4
Directory to contain the output file.
=item relationName
Name of the relation to dump.
=item relation
Structure describing the relation to be dumped.
=back
=cut
sub _DumpRelation {
    my ($self, $outputDirectory, $relationName, $relation) = @_;
    # Open the output file.
    my $fileName = "$outputDirectory/$relationName.dtx";
    open(DTXOUT, ">$fileName") || Confess("Could not open dump file $fileName: $!");
    # Create a query for the specified relation.
    my $query = $dbh->prepare_command("SELECT * FROM $relationName");
    # Execute the query.
    $query->execute() || Confess("SELECT error dumping $relationName.");
    while (my @row = $query->fetchrow) {
        # Escape any tabs or new-lines in the row text.
        for my $field (@row) {
            $field =~ s/\n/\\n/g;
            $field =~ s/\t/\\t/g;
        # Tab-join the row and write it to the output file.
        my $rowText = join("\t", @row);
        print DTXOUT "$rowText\n";
    # Close the output file.
    close DTXOUT;
=head3 _GetStructure
Get the data structure for a specified entity or relationship.
=over 4
=item objectName
=item RETURN
The descriptor for the specified object.
=back
=cut
sub _GetStructure {
    # Get the metadata structure.
    my $metadata = $self->{_metaData};
    # Declare the variable to receive the descriptor.
    my $retVal;
    if (exists $metadata->{Entities}->{$objectName}) {
        $retVal = $metadata->{Entities}->{$objectName};
    } elsif (exists $metadata->{Relationships}->{$objectName}) {
        $retVal = $metadata->{Relationships}->{$objectName};
    } else {
        Confess("Object $objectName not found in database.");
    # Return the descriptor.
    return $retVal;
=head3 _GetRelationTable
Get the list of relations for a specified entity or relationship.
=over 4
=item objectName
=item RETURN
A table containing the relations for the specified object.
=back
=cut
sub _GetRelationTable {
    # Return the object's relation list.
    return $objectData->{Relations};
=head3 _ValidateFieldNames
Determine whether or not the field names are valid. A description of the problems with the names
will be written to the standard error output. If there is an error, this method will abort. This is
a static method.
=over 4
=item metadata
Metadata structure loaded from the XML data definition.
=back
=cut
sub _ValidateFieldNames {
    # Get the object.
    my ($metadata) = @_;
    # Declare the return value. We assume success.
    my $retVal = 1;
    # Loop through the sections of the database definition.
    for my $section ('Entities', 'Relationships') {
        # Loop through the objects in this section.
        for my $object (values %{$metadata->{$section}}) {
            # Loop through the object's fields.
            for my $fieldName (keys %{$object->{Fields}}) {
                # If this field name is invalid, set the return value to zero
                # so we know we encountered an error.
                if (! ValidateFieldName($fieldName)) {
                    $retVal = 0;
    # If an error was found, fail.
    if ($retVal  == 0) {
        Confess("Errors found in field names.");
=head3 _LoadRelation
Load a relation from the data in a tab-delimited disk file. The load will only take place if a disk
file with the same name as the relation exists in the specified directory.
=over 4
=item dbh
DBKernel object for accessing the database.
=item directoryName
Name of the directory containing the tab-delimited data files.
=item relationName
Name of the relation to load.
=item rebuild
TRUE if the table should be dropped and re-created before loading.
=item RETURN
Returns a statistical object describing the number of records read and a list of error messages.
=back
=cut
sub _LoadRelation {
    my ($self, $directoryName, $relationName, $rebuild) = @_;
    # Create the file name.
    my $fileName = "$directoryName/$relationName";
    # If the file doesn't exist, try adding the .dtx suffix.
    if (! -e $fileName) {
        $fileName .= ".dtx";
            $fileName = "";
    # Create the return object.
    # If a file exists to load the table, its name will be in $fileName. Otherwise, $fileName will
    # be a null string.
    if ($fileName ne "") {
        # Load the relation from the file.
        $retVal = $self->LoadTable($fileName, $relationName, truncate => $rebuild);
    } elsif ($rebuild) {
        # Here we are rebuilding, but no file exists, so we just re-create the table.
        $self->CreateTable($relationName, 1);
    # Return the statistics from the load.
    return $retVal;
=head3 _LoadMetaData
    my $metadata = ERDB::_LoadMetaData($filename);
This method loads the data describing this database from an XML file into a metadata structure.
The resulting structure is a set of nested hash tables containing all the information needed to
load or use the database. The schema for the XML file is F<ERDatabase.xml>.
=over 4
=item filename
Name of the file containing the database definition.
=item RETURN
Returns a structure describing the database.
=back
=cut
sub _LoadMetaData {
    my ($filename) = @_;
    Trace("Reading DBD from $filename.") if T(2);
    # Slurp the XML file into a variable. Extensive use of options is used to insure we
    # get the exact structure we want.
    my $metadata = ReadMetaXML($filename);
    # Before we go any farther, we need to validate the field and object names. If an error is found,
    # the method below will fail.
    _ValidateFieldNames($metadata);
    # Next we need to create a hash table for finding relations. The entities and relationships are
    # implemented as one or more database relations.
    my %masterRelationTable = ();
    # Loop through the entities.
    my $entityList = $metadata->{Entities};
    for my $entityName (keys %{$entityList}) {
        my $entityStructure = $entityList->{$entityName};
        # The first step is to create all the entity's default values. For C<Field> elements,
        # the relation name must be added where it is not specified. For relationships,
        # the B<from-link> and B<to-link> fields must be inserted, and for entities an B<id>
        # field must be added to each relation. Finally, each field will have a C<PrettySort> attribute
        # added that can be used to pull the implicit fields to the top when displaying the field
        # documentation. The PrettySort values are 1-based and indicate in which pass through a
        # relation's data the field should be displayed-- 1 for the first pass, 2 for the second,
        # and so on.
        # Fix up this entity.
        _FixupFields($entityStructure, $entityName, 2, 3);
        # Add the ID field.
        _AddField($entityStructure, 'id', { type => $entityStructure->{keyType},
                                            relation => $entityName,
                                            Notes => { content => "Unique identifier for this \[b\]$entityName\[/b\]." },
                                            PrettySort => 1});
        # The current field list enables us to quickly find the relation containing a particular field.
        # We also need a list that tells us the fields in each relation. We do this by creating a
        # Relations structure in the entity structure and collating the fields into it based on their
        # C<relation> property. There is one tricky bit, which is that every relation has to have the
        # C<id> field in it. Note also that the field list is put into a C<Fields> member of the
        # relation's structure so that it looks more like the entity and relationship structures.
        # First we need to create the relations list.
        my $relationTable = { };
        # Loop through the fields. We use a list of field names to prevent a problem with
        # the hash table cursor losing its place during the loop.
        my $fieldList = $entityStructure->{Fields};
        my @fieldNames = keys %{$fieldList};
        for my $fieldName (@fieldNames) {
            my $fieldData = $fieldList->{$fieldName};
            # Get the current field's relation name.
            my $relationName = $fieldData->{relation};
            # Insure the relation exists.
            if (!exists $relationTable->{$relationName}) {
                $relationTable->{$relationName} = { Fields => { } };
            # Add the field to the relation's field structure.
            $relationTable->{$relationName}->{Fields}->{$fieldName} = $fieldData;
        # Now that we've organized all our fields by relation name we need to do some serious
        # housekeeping. We must add the C<id> field to every relation and convert each relation
        # to a list of fields. First, we need the ID field itself.
        my $idField = $fieldList->{id};
        for my $relationName (keys %{$relationTable}) {
            my $relation = $relationTable->{$relationName};
            # Get the relation's field list.
            my $relationFieldList = $relation->{Fields};
            # Add the ID field to it. If the field's already there, it will not make any
            # difference.
            $relationFieldList->{id} = $idField;
            # Convert the field set from a hash into a list using the pretty-sort number.
            $relation->{Fields} = _ReOrderRelationTable($relationFieldList);
            # Add the relation to the master table.
            $masterRelationTable{$relationName} = $relation;
        # The indexes come next. The primary relation will have a unique-keyed index based on the ID field.
        # The other relations must have at least one index that begins with the ID field. In addition, the
        # metadata may require alternate indexes. We do those alternate indexes first. To begin, we need to
        # get the entity's field list and index list.
        my $indexList = $entityStructure->{Indexes};
        # Loop through the indexes.
        for my $indexData (@{$indexList}) {
            # We need to find this index's fields. All of them should belong to the same relation.
            # The ID field is an exception, since it's in all relations.
            my $relationName = '0';
            for my $fieldDescriptor (@{$indexData->{IndexFields}}) {
                # Get this field's name.
                # Only proceed if it is NOT the ID field.
                if ($fieldName ne 'id') {
                    # Find the relation containing the current index field.
                    my $thisName = $fieldList->{$fieldName}->{relation};
                    if ($relationName eq '0') {
                        # Here we're looking at the first field, so we save its relation name.
                        $relationName = $thisName;
                    } elsif ($relationName ne $thisName) {
                        # Here we have a field mismatch.
                        Confess("Mixed index: field $fieldName does not belong to relation $relationName.");
            # Now $relationName is the name of the relation that contains this index. Add the index structure
            # to the relation.
            push @{$relationTable->{$relationName}->{Indexes}}, $indexData;
        # Now each index has been put in a relation. We need to add the primary index for the primary
        # relation.
        push @{$relationTable->{$entityName}->{Indexes}},
            { IndexFields => [ {name => 'id', order => 'ascending'} ], Unique => 'true',
              Notes => { content => "Primary index for $entityName." }
        # The next step is to insure that each relation has at least one index that begins with the ID field.
        # After that, we convert each relation's index list to an index table. We first need to loop through
        # the relations.
            # Get the relation's index list.
            my $indexList = $relation->{Indexes};
            # Insure this relation has an ID index.
            my $found = 0;
            for my $index (@{$indexList}) {
                if ($index->{IndexFields}->[0]->{name} eq "id") {
                    $found = 1;
            if ($found == 0) {
                push @{$indexList}, { IndexFields => [ {name => 'id', order => 'ascending'} ] };
            # Attach all the indexes to the relation.
            _ProcessIndexes($indexList, $relation);
        # Finally, we add the relation structure to the entity.
        $entityStructure->{Relations} = $relationTable;
    # Loop through the relationships. Relationships actually turn out to be much simpler than entities.
    # For one thing, there is only a single constituent relation.
    my $relationshipList = $metadata->{Relationships};
    for my $relationshipName (keys %{$relationshipList}) {
        my $relationshipStructure = $relationshipList->{$relationshipName};
        # Fix up this relationship.
        _FixupFields($relationshipStructure, $relationshipName, 2, 3);
        # Format a description for the FROM field.
        my $fromEntity = $relationshipStructure->{from};
        my $fromComment = "[b]id[/b] of the source [b][link #$fromEntity]$fromEntity\[/link][/b].";
        # Get the FROM entity's key type.
        my $fromType = $entityList->{$fromEntity}->{keyType};
        # Add the FROM field.
        _AddField($relationshipStructure, 'from-link', { type => $fromType,
                                                    relation => $relationshipName,
                                                    Notes => { content => $fromComment },
                                                    PrettySort => 1});
        # Format a description for the TO field.
        my $toEntity = $relationshipStructure->{to};
        my $toComment = "[b]id[/b] of the target [b][link #$toEntity]$toEntity\[/link][/b].";
        # Get the TO entity's key type.
        my $toType = $entityList->{$toEntity}->{keyType};
        # Add the TO field.
        _AddField($relationshipStructure, 'to-link', { type=> $toType,
                                                  Notes => { content => $toComment },
                                                  PrettySort => 1});
        # Create an index-free relation from the fields.
        my $thisRelation = { Fields => _ReOrderRelationTable($relationshipStructure->{Fields}),
                             Indexes => { } };
        $relationshipStructure->{Relations} = { $relationshipName => $thisRelation };
        # Add the alternate indexes (if any). This MUST be done before the FROM and
        # TO indexes, because it erases the relation's index list.
        if (exists $relationshipStructure->{Indexes}) {
            _ProcessIndexes($relationshipStructure->{Indexes}, $thisRelation);
        # Create the FROM and TO indexes.
        _CreateRelationshipIndex("From", $relationshipName, $relationshipStructure);
        _CreateRelationshipIndex("To", $relationshipName, $relationshipStructure);
        $masterRelationTable{$relationshipName} = $thisRelation;
    # Now store the master relation table in the metadata structure.
    $metadata->{RelationTable} = \%masterRelationTable;
    # Our final task is to create the join table. The join table is a hash that describes all
    # the join clauses for traveling through the relationships. The join clause is an equality
    # condition that can be put into a WHERE clause in order to join two objects. Two relationships
    # can be joined if they share an entity in common; and an entity can be joined to a relationship
    # if the entity is at either end of the relationship.
    my %joinTable = ();
        # Build three lists of the relationships connected to this entity. One will be
        # for relationships from the entity, one for relationships to the entity, and
        # one for recursive relationships.
        my @fromList = ();
        my @toList = ();
        my @bothList = ();
        Trace("Join table build for $entityName.") if T(metadata => 4);
            my $relationship = $relationshipList->{$relationshipName};
            # Determine if this relationship has our entity in one of its link fields.
            my $fromEntity = $relationship->{from};
            my $toEntity = $relationship->{to};
            Trace("Join check for relationship $relationshipName from $fromEntity to $toEntity.") if T(Joins => 4);
            if ($fromEntity eq $entityName) {
                if ($toEntity eq $entityName) {
                    # Here the relationship is recursive.
                    push @bothList, $relationshipName;
                    Trace("Relationship $relationshipName put in both-list.") if T(metadata => 4);
                } else {
                    # Here the relationship comes from the entity.
                    push @fromList, $relationshipName;
                    Trace("Relationship $relationshipName put in from-list.") if T(metadata => 4);
            } elsif ($toEntity eq $entityName) {
                # Here the relationship goes to the entity.
                push @toList, $relationshipName;
                Trace("Relationship $relationshipName put in to-list.") if T(metadata => 4);
        # Create the nonrecursive joins. Note that we build two hashes for running
        # through the nonrecursive relationships since we'll have an outer loop
        # and an inner loop, and we can't do two "each" iterations on the same
        # hash table at the same time.
        my %directRelationships = ( from => \@fromList, to => \@toList );
        my %otherRelationships = ( from => \@fromList, to => \@toList );
        for my $linkType (keys %directRelationships) {
            my $relationships = $directRelationships{$linkType};
            # Loop through all the relationships.
            for my $relationshipName (@{$relationships}) {
                # Create joins between the entity and this relationship.
                my $linkField = "$relationshipName.${linkType}_link";
                my $joinClause = "$entityName.id = $linkField";
                Trace("Entity join clause is $joinClause for $entityName and $relationshipName.") if T(metadata => 4);
                $joinTable{"$entityName/$relationshipName"} = $joinClause;
                $joinTable{"$relationshipName/$entityName"} = $joinClause;
                # Create joins between this relationship and the other relationships.
                for my $otherType (keys %otherRelationships) {
                    my $otherships = $otherRelationships{$otherType};
                    for my $otherName (@{$otherships}) {
                        # Get the key for this join.
                        my $joinKey = "$otherName/$relationshipName";
                        # Check for a duplicate or a self-join.
                        if (exists $joinTable{$joinKey}) {
                            # Here we have a duplicate, which means that the join
                            # path is ambiguous. We delete the join from the join
                            # table to prevent it from being used.
                            delete $joinTable{$joinKey};
                            Trace("Deleting ambiguous join $joinKey.") if T(4);
                        } elsif ($otherName ne $relationshipName) {
                            # Here we have a valid join. Note that joins between a
                            # relationship and itself are prohibited.
                            my $relJoinClause = "$otherName.${otherType}_link = $linkField";
                            $joinTable{$joinKey} = $relJoinClause;
                            Trace("Relationship join clause is $relJoinClause for $joinKey.") if T(metadata => 4);
                # Create joins between this relationship and the recursive relationships.
                # We don't need to check for ambiguous joins here, because a recursive
                # relationship can only be ambiguous with another recursive relationship,
                # and the incoming relationship from the outer loop is never recursive.
                for my $otherName (@bothList) {
                    Trace("Setting up relationship joins to recursive relationship $otherName with $relationshipName.") if T(metadata => 4);
                    # Join from the left.
                    $joinTable{"$relationshipName/$otherName"} =
                        "$linkField = $otherName.from_link";
                    # Join from the right.
                    $joinTable{"$otherName/$relationshipName"} =
                        "$otherName.to_link = $linkField";
        # Create entity joins for the recursive relationships. Unlike the non-recursive
        # joins, the direction makes a difference with the recursive joins. This can give
        # rise to situations where we can't create the path we want; however, it is always
        # possible to get the same effect using multiple queries.
        for my $relationshipName (@bothList) {
            Trace("Setting up entity joins to recursive relationship $relationshipName with $entityName.") if T(metadata => 4);
            # Join to the entity from each direction.
                "$entityName.id = $relationshipName.from_link";
                "$relationshipName.to_link = $entityName.id";
    # Add the join table to the structure.
    $metadata->{Joins} = \%joinTable;
    # Return the slurped and fixed-up structure.
    return $metadata;
=head3 _CreateRelationshipIndex
Create an index for a relationship's relation.
=over 4
=item indexKey
Type of index: either C<"From"> or C<"To">.
=item relationshipName
Name of the relationship.
=item relationshipStructure
Structure describing the relationship that the index will sort.
=back
=cut
sub _CreateRelationshipIndex {
    # Get the parameters.
    my ($indexKey, $relationshipName, $relationshipStructure) = @_;
    # Get the target relation.
    my $relationStructure = $relationshipStructure->{Relations}->{$relationshipName};
    # Create a descriptor for the link field that goes at the beginning of this index.
    my $firstField = { name => lcfirst $indexKey . '-link', order => 'ascending' };
    # Get the target index descriptor.
    my $newIndex = $relationshipStructure->{$indexKey . "Index"};
    # Add the first field to the index's field list. Due to the craziness of PERL, if the
    # index descriptor does not exist, it will be created automatically so we can add
    # the field to it.
    unshift @{$newIndex->{IndexFields}}, $firstField;
    # If this is a one-to-many relationship, the "To" index is unique.
    if ($relationshipStructure->{arity} eq "1M" && $indexKey eq "To") {
        $newIndex->{Unique} = 'true';
    # Add the index to the relation.
    _AddIndex("idx$indexKey", $relationStructure, $newIndex);
=head3 _ProcessIndexes
    ERDB::_ProcessIndexes($indexList, $relation);
Build the data structures for the specified indexes in the specified relation.
=over 4
=item indexList
Reference to a list of indexes. Each index is a hash reference containing an optional
C<Notes> value that describes the index and an C<IndexFields> value that is a reference
to a list of index field structures. An index field structure, in turn, is a reference
to a hash that contains a C<name> attribute for the field name and an C<order>
attribute that specifies either C<ascending> or C<descending>. In this sense the
index list encapsulates the XML C<Indexes> structure in the database definition.
=item relation
The structure that describes the current relation. The new index descriptors will
be stored in the structure's C<Indexes> member. Any previous data in the structure
will be lost.
=back
=cut
sub _ProcessIndexes {
    my ($indexList, $relation) = @_;
    # Now we need to convert the relation's index list to an index table. We begin by creating
    # an empty table in the relation structure.
    $relation->{Indexes} = { };
    my $count = 0;
        # Add this index to the index table.
        _AddIndex("idx$count", $relation, $index);
        # Increment the counter so that the next index has a different name.
        $count++;
=head3 _AddIndex
Add an index to a relation structure.
=over 4
=item indexName
Name to give to the new index.
=item relationStructure
Relation structure to which the new index should be added.
=item newIndex
New index to add.
=back
=cut
sub _AddIndex {
    my ($indexName, $relationStructure, $newIndex) = @_;
    # We want to re-do the index's field list. Instead of an object for each field,
    # we want a string consisting of the field name optionally followed by the token DESC.
    my @fieldList = ( );
    for my $field (@{$newIndex->{IndexFields}}) {
        # Create a string containing the field name.
        my $fieldString = $field->{name};
        # Add the ordering token if needed.
        if ($field->{order} eq "descending") {
            $fieldString .= " DESC";
        # Push the result onto the field list.
        push @fieldList, $fieldString;
    # Store the field list just created as the new index field list.
    $newIndex->{IndexFields} = \@fieldList;
    # Add the index to the relation's index list.
    $relationStructure->{Indexes}->{$indexName} = $newIndex;
=head3 _FixupFields
This method fixes the field list for an entity or relationship. It will add the caller-specified
relation name to fields that do not have a name and set the C<PrettySort> value as specified.
=over 4
=item structure
Entity or relationship structure to be fixed up.
=item defaultRelationName
Default relation name to be added to the fields.
=item prettySortValue
C<PrettySort> value for the relation's normal fields.
=item textPrettySortValue
C<PrettySort> value for the relation's text fields. This value can be set to one greater than the
normal pretty sort value so that text fields go at the end of each relation.
=back
=cut
sub _FixupFields {
    my ($structure, $defaultRelationName, $prettySortValue, $textPrettySortValue) = @_;
    # Insure the structure has a field list.
    if (!exists $structure->{Fields}) {
        # Here it doesn't, so we create a new one.
        $structure->{Fields} = { };
    } else {
        # Here we have a field list. We need to track the searchable fields, so we
        # create a list for stashing them.
        my @textFields = ();
        my $fieldStructures = $structure->{Fields};
        for my $fieldName (keys %{$fieldStructures}) {
            Trace("Processing field $fieldName of $defaultRelationName.") if T(4);
            my $fieldData = $fieldStructures->{$fieldName};
            my $type = $fieldData->{type};
            # Plug in a relation name if it is needed.
            Tracer::MergeOptions($fieldData, { relation => $defaultRelationName });
            # Check for searchability.
            if ($fieldData->{searchable}) {
                # Only allow this for a primary relation.
                if ($fieldData->{relation} ne $defaultRelationName) {
                    Confess("Field $fieldName of $defaultRelationName is in secondary relations and cannot be searchable.");
                } else {
                    push @textFields, $fieldName;
            # Add the PrettySortValue.
            $fieldData->{PrettySort} = (($type eq "text") ? $textPrettySortValue : $prettySortValue);
        # If there are searchable fields, remember the fact.
        if (@textFields) {
            $structure->{searchFields} = \@textFields;
=head3 _FixName
Fix the incoming field name so that it is a legal SQL column name.
=over 4
=item fieldName
Field name to fix.
=item RETURN
Returns the fixed-up field name.
=back
=cut
sub _FixName {
    # Replace its minus signs with underscores.
    $fieldName =~ s/-/_/g;
    return $fieldName;
=head3 _FixNames
Fix all the field names in a list.
=over 4
=item field1, field2, field3, ... fieldn
List of field names to fix.
=item RETURN
Returns a list of fixed-up versions of the incoming field names.
=back
=cut
sub _FixNames {
    # Create the result list.
    my @result = ( );
    # Loop through the incoming parameters.
    for my $field (@_) {
        push @result, _FixName($field);
    return @result;
=head3 _AddField
Add a field to a field list.
=over 4
=item structure
Structure (usually an entity or relationship) that is to contain the field.
=item fieldName
Name of the new field.
=item fieldData
Structure containing the data to put in the field.
=back
=cut
sub _AddField {
    my ($structure, $fieldName, $fieldData) = @_;
    # Create the field structure by copying the incoming data.
    my $fieldStructure = {%{$fieldData}};
    # Get a reference to the field list itself.
    my $fieldList = $structure->{Fields};
    # Add the field to the field list.
    $fieldList->{$fieldName} = $fieldStructure;
=head3 _ReOrderRelationTable
This method will take a relation table and re-sort it according to the implicit ordering of the
C<PrettySort> property. Instead of a hash based on field names, it will return a list of fields.
This requires creating a new hash that contains the field name in the C<name> property but doesn't
have the C<PrettySort> property, and then inserting that new hash into the field list.
=over 4
=item relationTable
Relation hash to be reformatted into a list.
=item RETURN
A list of field hashes.
=back
=cut
sub _ReOrderRelationTable {
    my ($relationTable) = @_;
    # Create the return list.
    my @resultList;
    # Rather than copy all the fields in a single pass, we make multiple passes and only copy
    # fields whose PrettySort value matches the current pass number. This process continues
    # until we process all the fields in the relation.
    my $fieldsLeft = (values %{$relationTable});
    for (my $sortPass = 1; $fieldsLeft > 0; $sortPass++) {
        # Loop through the fields. Note that we lexically sort the fields. This makes field name
        # secondary to pretty-sort number in the final ordering.
        for my $fieldName (sort keys %{$relationTable}) {
            # Get this field's data.
            my $fieldData = $relationTable->{$fieldName};
            # Verify the sort pass.
            if ($fieldData->{PrettySort} == $sortPass) {
                # Here we're in the correct pass. Denote we've found a field.
                $fieldsLeft--;
                # The next step is to create the field structure. This done by copying all
                # of the field elements except PrettySort and adding the name.
                my %thisField;
                for my $property (keys %{$fieldData}) {
                    if ($property ne 'PrettySort') {
                        $thisField{$property} = $fieldData->{$property};
                $thisField{name} = $fieldName;
                # Now we add this field to the end of the result list.
                push @resultList, \%thisField;
    # Return a reference to the result list.
    return \@resultList;
=head3 _IsPrimary
Return TRUE if a specified relation is a primary relation, else FALSE. A relation is primary
if it has the same name as an entity or relationship.
=over 4
=item relationName
Name of the relevant relation.
=item RETURN
Returns TRUE for a primary relation, else FALSE.
=back
=cut
sub _IsPrimary {
    my ($self, $relationName) = @_;
    # Check for the relation in the entity table.
    my $entityTable = $self->{_metaData}->{Entities};
    my $retVal = exists $entityTable->{$relationName};
    if (! $retVal) {
        # Check for it in the relationship table.
        my $relationshipTable = $self->{_metaData}->{Relationships};
        $retVal = exists $relationshipTable->{$relationName};
    # Return the determination indicator.
    return $retVal;
=head3 _FindRelation
Return the descriptor for the specified relation.
=over 4
=item relationName
Name of the relation whose descriptor is to be returned.
=item RETURN
Returns the object that describes the relation's indexes and fields.
=back
=cut
sub _FindRelation {
    # Get the relation's structure from the master relation table in the metadata structure.
    my $metaData = $self->{_metaData};
    my $retVal = $metaData->{RelationTable}->{$relationName};
    # Return it to the caller.
    return $retVal;
=head2 Documentation Utility Methods
=head3 _ComputeRelationshipSentence
The relationship sentence consists of the relationship name between the names of the
two related entities and an arity indicator.
=over 4
Relationship structure containing the relationship's description and properties.
=item RETURN
Returns a string containing the entity names on either side of the relationship name and an
indicator of the arity.
=back
=cut
sub _ComputeRelationshipSentence {
    my ($relationshipName, $relationshipStructure) = @_;
    # Format the relationship sentence.
    my $result = "$relationshipStructure->{from} $relationshipName $relationshipStructure->{to}";
    # Compute the arity.
    my $arityCode = $relationshipStructure->{arity};
    my $arity = $ArityTable{$arityCode};
    $result .= " ($arity)";
    return $result;
=head3 _ComputeRelationshipHeading
The relationship heading is the L<relationship sentence|/ComputeRelationshipSentence> with the entity
names hyperlinked to the appropriate entity sections of the document.
=over 4
=item RETURN
Returns a string containing the entity names on either side of the relationship name with the entity
names hyperlinked.
=back
=cut
sub _ComputeRelationshipHeading {
    # Get the FROM and TO entity names.
    # Format a relationship sentence with hyperlinks in it.
    my $result = "<a href=\"#$fromEntity\">$fromEntity</a> $relationshipName <a href=\"#$toEntity\">$toEntity</a>";
    return $result;
=head3 _WikiRelationTable
Generate the Wiki text for a particular relation. The relation's data will be formatted as a
table with three columns-- the field name, the field type, and the field description.
=over 4
=item relationName
Name of the relation being formatted.
=item relationData
Hash containing the relation's fields and indexes.
=item RETURN
Returns a Wiki string that can be used to display the relation name and all of its fields.
=back
=cut
sub _WikiRelationTable {
    my ($relationName, $relationData) = @_;
    # We'll create a list of lists in here, then call WikiTools::Table to
    # convert it into a table.
    my @rows = ();
    # Push in the header row.
    push @rows, [qw(Field Type Description)];
    for my $field (@{$relationData->{Fields}}) {
        # Create this field's row. We always have a name and type.
        my @row = ($field->{name}, $field->{type});
        # If we have a description, add it as the third column.
        if (exists $field->{Notes}) {
            push @row, WikiNote($field->{Notes}->{content});
        # Push this row onto the table list.
        push @rows, \@row;
    # Store the rows as a Wiki table with a level-4 heading.
    my $retVal = join("\n\n", WikiTools::Heading(4, "$relationName Table"),
                      WikiTools::Table(@rows));
    # Now we show the relation's indexes. These are formatted as another
    # table.
    @rows = ();
    push @rows, [qw(Index Unique Fields Notes)];
    # Get the index hash.
    my $indexTable = $relationData->{Indexes};
    # Loop through the indexes. For an entity, there is always at least one index.
    # For a relationship, there are at least two. The upshot is we don't need to
    # worry about accidentally generating a frivolous table here.
    for my $indexName (sort keys %$indexTable) {
        my $indexData = $indexTable->{$indexName};
        # Determine whether or not the index is unique.
        my $unique = ((exists $indexData->{Unique} && $indexData->{Unique} eq "true") ?
                      "yes" : "");
        # Get the field list.
        my $fields = join(', ', @{$indexData->{IndexFields}});
        # Get the note text.
        my $description = "";
        if (my $note = $indexData->{Notes}) {
            $description = WikiNote($note->{content});
        # Format this row.
        my @row = ($indexName, $unique, $fields, $description);
        push @rows, \@row;
    # Add the index list to the result.
    $retVal .= "\n\n" . WikiTools::Table(@rows);
=head3 _ShowRelationTable
Generate the HTML string for a particular relation. The relation's data will be formatted as an HTML
=over 4
=item relationName
=item relationData
=item RETURN
Returns an HTML string that can be used to display the relation name and all of its fields.
=back
=cut
sub _ShowRelationTable {
    # Start the relation's field table.
    my $htmlString = _OpenFieldTable($relationName);
        $htmlString .= _ShowField($field);
    # Close this relation's field table.
    $htmlString .= &_CloseTable;
    $htmlString .= "<ul>\n";
    for my $indexName (sort keys %{$indexTable}) {
        my $fullName = $indexName;
        if (exists $indexData->{Unique} && $indexData->{Unique} eq "true") {
            $fullName .= " (unique)";
        # Start an HTML list item for this index.
        $htmlString .= "<li><b>Index $fullName</b>\n<ul>\n";
        # Add any note text.
            $htmlString .= "<li>" . HTMLNote($note->{content}) . "</li>\n";
        # Add the fiield list.
        $htmlString .= "<li><i>" . join(', ', @{$indexData->{IndexFields}}) . "</i></li>\n";
        # Close this entry.
        $htmlString .= "</ul></li>\n";
    # Close off the index list.
    $htmlString .= "</ul>\n";
=head3 _OpenFieldTable
This method creates the header string for the field table generated by L</ShowMetaData>.
=over 4
=item tablename
Name of the table whose fields will be displayed.
=item RETURN
Returns a string containing the HTML for a field table's header.
=back
=cut
sub _OpenFieldTable {
    my ($tablename) = @_;
    return _OpenTable($tablename, 'Field', 'Type', 'Description');
=head3 _OpenTable
This method creates the header string for an HTML table.
=over 4
=item tablename
Title of the table.
=item colName1, colName2, ..., colNameN
List of column names.
=item RETURN
Returns a string containing the HTML for the desired table's header.
=back
=cut
sub _OpenTable {
    my ($tablename, @colNames) = @_;
    # Compute the number of columns.
    my $colCount = @colNames;
    # Generate the title row.
    my $htmlString = "<table border=\"2\"><tr><td colspan=\"$colCount\" align=\"center\">$tablename</td></tr>\n";
    # Loop through the columns, adding the column header rows.
    $htmlString .= "<tr>";
    for my $colName (@colNames) {
        $htmlString .= "<th>$colName</th>";
    $htmlString .= "</tr>\n";
    return $htmlString;
=head3 _CloseTable
This method returns the HTML for closing a table.
=cut
sub _CloseTable {
    return "</table>\n";
=head3 _ShowField
This method returns the HTML for displaying a row of field information in a field table.
=over 4
=item fieldData
Table of data about the field.
=item RETURN
Returns an HTML string for a table row that shows the field's name, type, and description.
=back
=cut
sub _ShowField {
    my ($fieldData) = @_;
    # Create the HTML string.
    my $htmlString = "<tr><th align=\"left\">$fieldData->{name}</th><td>$fieldData->{type}</td>";
    # If we have content, add it as a third column.
    if (exists $fieldData->{Notes}) {
        $htmlString .= "<td>" . HTMLNote($fieldData->{Notes}->{content}) . "</td>";
    # Close off the row.
    # Return the result.
    return $htmlString;
=head3 _ObjectNotes
    my @noteParagraphs = _ObjectNotes($objectData);
Return a list of the notes and asides for an entity or relationship in
Wiki format.
=over 4
=item objectData
The metadata for the desired entity or relationship.
=item RETURN
Returns a list of text paragraphs in Wiki markup form.
=back
=cut
sub _ObjectNotes {
    my ($objectData) = @_;
    my @retVal;
    # Loop through the types of notes.
    for my $noteType (qw(Notes Asides)) {
        my $text = $objectData->{$noteType};
        if ($text) {
            push @retVal, "", WikiNote($text->{content});
    return @retVal;
1;
