[Bio] / Sprout / ERDB.pm Repository:
Log of /Sprout/ERDB.pm
Revision 1.169 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Feb 22 03:28:31 2015 UTC (5 years, 1 month ago) by parrello
CVS Tags: HEAD
Changes since 1.168: +8 -4 lines
Diff to previous 1.168
Removed Shrub stuff. Updated ERDB for compatibility with Shrub DBD.
Revision 1.168 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 5 10:03:33 2015 UTC (5 years, 1 month ago) by parrello
Changes since 1.167: +21 -11 lines
Diff to previous 1.167
checkpoint before a big update from GIT
Revision 1.167 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 27 21:38:38 2015 UTC (5 years, 2 months ago) by parrello
Changes since 1.166: +30 -10 lines
Diff to previous 1.166
First pass over SEEDtk database changes.
Revision 1.166 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 5 17:08:05 2014 UTC (5 years, 4 months ago) by parrello
Changes since 1.165: +41 -11 lines
Diff to previous 1.165
Factored out a method for computing create-table field strings.
Revision 1.165 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 7 17:12:21 2014 UTC (5 years, 5 months ago) by parrello
Changes since 1.164: +15 -7 lines
Diff to previous 1.164
Miscellaneous loader fixes.
Revision 1.164 - (view) (download) (as text) (annotate) - [select for diffs]
Tue May 20 18:15:09 2014 UTC (5 years, 10 months ago) by parrello
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.163: +125 -2 lines
Diff to previous 1.163
CDMI and Sprout load fixes. Locations fixes.
Revision 1.163 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 3 20:50:43 2014 UTC (6 years ago) by parrello
Changes since 1.162: +113 -0 lines
Diff to previous 1.162
Added relationship cleaning function. Fixed some comments.
Revision 1.162 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 8 18:28:13 2013 UTC (6 years, 4 months ago) by parrello
Changes since 1.161: +23 -5 lines
Diff to previous 1.161
Added optional mode to UpdateEntity.
Revision 1.161 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 8 20:28:44 2013 UTC (6 years, 10 months ago) by parrello
Changes since 1.160: +57 -21 lines
Diff to previous 1.160
Updates for new incremental load.
Revision 1.160 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 4 19:04:31 2013 UTC (7 years ago) by parrello
Changes since 1.159: +210 -3 lines
Diff to previous 1.159
Support for PSEED load and updates.
Revision 1.159 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 19 21:42:15 2012 UTC (7 years, 3 months ago) by parrello
Changes since 1.158: +15 -7 lines
Diff to previous 1.158
Changed to make the primary index selection more explicit.
Revision 1.158 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Dec 10 08:42:03 2012 UTC (7 years, 3 months ago) by parrello
Changes since 1.157: +37 -29 lines
Diff to previous 1.157
Added "onlyRoot" option to Delete for deleting an entity instance without touching related records.
Revision 1.157 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Dec 9 01:36:05 2012 UTC (7 years, 3 months ago) by parrello
Changes since 1.156: +45 -12 lines
Diff to previous 1.156
Added support for nullable floats and integers.
Revision 1.156 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Nov 2 20:28:52 2012 UTC (7 years, 4 months ago) by parrello
Changes since 1.155: +14 -3 lines
Diff to previous 1.155
Delete fixes.
Revision 1.155 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 25 22:09:33 2012 UTC (7 years, 6 months ago) by parrello
Changes since 1.154: +3 -3 lines
Diff to previous 1.154
Final changes to whole LOCAL INFILE problem.
Revision 1.154 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 25 21:37:09 2012 UTC (7 years, 6 months ago) by parrello
Changes since 1.153: +1 -3 lines
Diff to previous 1.153
More presentation fixes.
Revision 1.153 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 25 20:33:15 2012 UTC (7 years, 6 months ago) by parrello
Changes since 1.152: +1 -1 lines
Diff to previous 1.152
Fixed another uninitialized variable bug.
Revision 1.152 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 25 19:08:05 2012 UTC (7 years, 6 months ago) by parrello
Changes since 1.151: +5 -2 lines
Diff to previous 1.151
Fixed to prevent a warning during index create.
Revision 1.151 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jul 31 18:52:48 2012 UTC (7 years, 7 months ago) by olson
Changes since 1.150: +3 -3 lines
Diff to previous 1.150
Quoting fix.
Revision 1.150 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Apr 18 19:31:29 2012 UTC (7 years, 11 months ago) by parrello
CVS Tags: mgrast_version_3_2
Changes since 1.149: +14 -3 lines
Diff to previous 1.149
Fixed handling of underscores in Update. Added delete count to return from Disconnect.
Revision 1.149 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Feb 21 18:58:18 2012 UTC (8 years, 1 month ago) by parrello
Changes since 1.148: +51 -59 lines
Diff to previous 1.148
Latest KBase changes.
Revision 1.148 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Feb 14 20:26:45 2012 UTC (8 years, 1 month ago) by parrello
Changes since 1.147: +9 -2 lines
Diff to previous 1.147
Changed to allow underscores in field name specifications.
Revision 1.147 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Jan 8 23:28:08 2012 UTC (8 years, 2 months ago) by parrello
Changes since 1.146: +48 -0 lines
Diff to previous 1.146
First group of KBase API methods.
Revision 1.146 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 3 20:11:28 2012 UTC (8 years, 2 months ago) by parrello
Changes since 1.145: +6 -4 lines
Diff to previous 1.145
New CDMI load stuff.
Revision 1.145 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Dec 22 18:28:09 2011 UTC (8 years, 3 months ago) by parrello
Changes since 1.144: +16 -16 lines
Diff to previous 1.144
New utility for dumping load formats.
Revision 1.144 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 6 19:05:55 2011 UTC (8 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.143: +33 -5 lines
Diff to previous 1.143
Updates for new model loading procedure.
Revision 1.143 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Oct 4 17:03:54 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.142: +9 -4 lines
Diff to previous 1.142
Fixed to allow ERDB objects not connected to databases.
Revision 1.142 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Oct 1 10:35:02 2011 UTC (8 years, 5 months ago) by parrello
Changes since 1.141: +42 -34 lines
Diff to previous 1.141
Conversion to support Postgres for ERDB.
Revision 1.141 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 21 21:05:15 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: rast_rel_2011_0928
Changes since 1.140: +67 -0 lines
Diff to previous 1.140
Changes to support complexes.
Revision 1.140 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 9 18:44:37 2011 UTC (8 years, 6 months ago) by parrello
Changes since 1.139: +1 -0 lines
Diff to previous 1.139
Added the ability to store a DBMS's quote character.
Revision 1.139 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jul 21 19:14:01 2011 UTC (8 years, 8 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1
Changes since 1.138: +7 -2 lines
Diff to previous 1.138
Add a bunch of modules to the SAS release for myRAST. Make use of FIG_Config optional
in places it isn't currently.
Revision 1.138 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 27 21:28:37 2011 UTC (8 years, 9 months ago) by parrello
Changes since 1.137: +1 -1 lines
Diff to previous 1.137
Changed index generation to insure index names are unique.
Revision 1.137 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Jun 15 19:16:05 2011 UTC (8 years, 9 months ago) by parrello
Changes since 1.136: +2 -10 lines
Diff to previous 1.136
Fixed a POD error.  Changed internal-DBD default to ON.
Revision 1.136 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 19 14:05:28 2011 UTC (8 years, 10 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_release_3_1_0
Changes since 1.135: +4 -4 lines
Diff to previous 1.135
Made row estimation larger to handle updates.
Revision 1.135 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 19 13:55:26 2011 UTC (8 years, 10 months ago) by parrello
Changes since 1.134: +4 -7 lines
Diff to previous 1.134
Increased the estimated rows for the size estimation.
Revision 1.134 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 21 19:58:18 2011 UTC (8 years, 11 months ago) by parrello
Changes since 1.133: +1 -1 lines
Diff to previous 1.133
Incremental load fixes and changes.
Revision 1.133 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 11 15:04:03 2011 UTC (9 years, 2 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2011_0119
Changes since 1.132: +54 -49 lines
Diff to previous 1.132
Updates for single-genome loader.
Revision 1.132 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Nov 1 15:12:09 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: rast_rel_2010_1206
Changes since 1.131: +23 -0 lines
Diff to previous 1.131
Updates for proteindata type.
Revision 1.131 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 14 17:27:37 2010 UTC (9 years, 5 months ago) by parrello
Changes since 1.130: +1 -0 lines
Diff to previous 1.130
Changes for expression vector support.
Revision 1.130 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Feb 1 20:14:28 2010 UTC (10 years, 1 month ago) by parrello
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.129: +2 -4 lines
Diff to previous 1.129
Sapling model updates.
Revision 1.129 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 11 21:21:26 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.128: +7 -6 lines
Diff to previous 1.128
Server database recovery fix.
Revision 1.128 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Dec 2 00:40:54 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.127: +26 -7 lines
Diff to previous 1.127
Added reconnection support.
Revision 1.127 - (view) (download) (as text) (annotate) - [select for diffs]
Sun Oct 11 19:52:19 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.126: +1 -0 lines
Diff to previous 1.126
Fixed the DecodeField bug.
Revision 1.126 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 8 21:30:33 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.125: +298 -201 lines
Diff to previous 1.125
Changed to allow for storing the DBD metadata in the database. This is currently only activated for Sapling.
Revision 1.125 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 8 17:00:51 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.124: +14 -10 lines
Diff to previous 1.124
Fixed some documentation errors. Added the database notes to the image display for the documentation widget.
Revision 1.124 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Aug 27 19:52:40 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.123: +1 -1 lines
Diff to previous 1.123
Updates to fix load problems.
Revision 1.123 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jun 30 19:53:00 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Changes since 1.122: +117 -77 lines
Diff to previous 1.122
Revision 1.122 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 18 01:29:34 2009 UTC (10 years, 9 months ago) by parrello
Changes since 1.121: +1 -1 lines
Diff to previous 1.121
Fixed a bug in join computation.
Revision 1.121 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 4 18:20:50 2009 UTC (10 years, 9 months ago) by parrello
Changes since 1.120: +18 -1 lines
Diff to previous 1.120
Added a switch to turn off query caching in the debug console.
Revision 1.120 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 28 18:06:58 2009 UTC (10 years, 10 months ago) by parrello
Changes since 1.119: +8 -8 lines
Diff to previous 1.119
Revision 1.119 - (view) (download) (as text) (annotate) - [select for diffs]
Mon May 4 18:49:49 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.118: +8 -5 lines
Diff to previous 1.118
Updated to use Bob's protocol for load options.
Revision 1.118 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 23 02:44:29 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.117: +19 -12 lines
Diff to previous 1.117
Fixed InsertNew to automatically update the id field definition the first time it is called for an entity.
Revision 1.117 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 2 01:34:24 2009 UTC (10 years, 11 months ago) by parrello
Changes since 1.116: +14 -1 lines
Diff to previous 1.116
Added a virtual method for cleaning up data structures during a load.
Revision 1.116 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 23 19:35:06 2009 UTC (11 years ago) by parrello
Changes since 1.115: +114 -11 lines
Diff to previous 1.115
Added support for ERDBDumper.
Revision 1.115 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 10 03:35:05 2009 UTC (11 years ago) by parrello
Changes since 1.114: +157 -27 lines
Diff to previous 1.114
Fixes to support FC updates.
Revision 1.114 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Mar 7 18:07:36 2009 UTC (11 years ago) by parrello
Changes since 1.113: +18 -11 lines
Diff to previous 1.113
Cleaned up some error messages. Fixed some bugs in search.
Revision 1.113 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Mar 2 22:13:52 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.112: +765 -285 lines
Diff to previous 1.112
Updated documentation. Improved diagram and documentation generation support.
Revision 1.112 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 23 13:44:51 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.111: +23 -2 lines
Diff to previous 1.111
Fixed a bug in InsertObject. Added support for demand-driven flow control.
Revision 1.111 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 19 21:46:21 2009 UTC (11 years, 2 months ago) by parrello
Changes since 1.110: +3340 -2963 lines
Diff to previous 1.110
ERDB 2.0 support
Revision 1.110 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 9 17:23:54 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.109: +5 -4 lines
Diff to previous 1.109
More loading bug fixes.
Revision 1.109 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 2 16:32:42 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.108: +8 -5 lines
Diff to previous 1.108
Revision 1.108 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 1 03:07:08 2008 UTC (11 years, 5 months ago) by parrello
Changes since 1.107: +44 -14 lines
Diff to previous 1.107
Revision 1.107 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 30 15:23:55 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.106: +325 -344 lines
Diff to previous 1.106
New loader technology.
Revision 1.106 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Sep 25 23:28:28 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.105: +1 -1 lines
Diff to previous 1.105
Minor bug fixes to loading.
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 23 20:43:42 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.104: +1 -1 lines
Diff to previous 1.104
Fixed a comment.
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 22 20:33:30 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.103: +14 -2 lines
Diff to previous 1.103
Added some new types for Sapling project
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 16 18:57:59 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.102: +0 -1 lines
Diff to previous 1.102
Added trace messages.
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 9 21:02:10 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.101: +1 -2 lines
Diff to previous 1.101
Changes for v24 database.
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 3 20:56:20 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.100: +8 -1 lines
Diff to previous 1.100
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Aug 12 06:07:06 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.99: +115 -12 lines
Diff to previous 1.99
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jul 11 01:04:08 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806
Changes since 1.98: +7 -7 lines
Diff to previous 1.98
Changed so relationships appear before table definitions in the wiki output.
Revision 1.98 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jul 7 19:05:55 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_07_21
Changes since 1.97: +66 -15 lines
Diff to previous 1.97
Added support for shapes and issue tags.
Wed May 7 23:08:19 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.96: +0 -1 lines
Diff to previous 1.96
Tue Feb 5 04:52:24 2008 UTC (12 years, 1 month ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.95: +2 -1 lines
Diff to previous 1.95
Added more statistics for the load.
Wed Jan 23 00:56:31 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.94: +276 -15 lines
Diff to previous 1.94
Thu Dec 6 14:58:03 2007 UTC (12 years, 3 months ago) by parrello
Changes since 1.93: +84 -83 lines
Diff to previous 1.93
Mon Jul 16 20:04:50 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.92: +3 -2 lines
Diff to previous 1.92
Mon Jun 11 18:51:23 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.91: +3 -3 lines
Diff to previous 1.91
Fixed some comments so they will be applicable to the new E-R model. Added more useful data to an error message.
Wed May 2 05:51:48 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.90: +68 -0 lines
Diff to previous 1.90
Added a new method for multiple-row deletion.
Fri Apr 27 22:19:49 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.89: +85 -8 lines
Diff to previous 1.89
Added a new method for mass field updates. Removed a dependency on FIG. Fixed a bug in the XML-PPO conversion.
Thu Apr 12 05:59:41 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.88: +221 -0 lines
Diff to previous 1.88
Added CreatePPO method.
Tue Apr 10 05:54:18 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.87: +5 -5 lines
Diff to previous 1.87
Sun Feb 18 21:28:19 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.86: +93 -13 lines
Diff to previous 1.86
Added alternate indexes on relationships. Added support for database transactions.
Mon Feb 12 19:23:32 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.85: +13 -10 lines
Diff to previous 1.85
Changed the comments to allow for a planned enhancement in index formation.
Fri Feb 9 22:59:53 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.84: +2 -0 lines
Diff to previous 1.84
Added more tracing.
Wed Jan 24 10:22:22 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.83: +1 -0 lines
Diff to previous 1.83
Added tracing.
Mon Jan 22 20:23:58 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.82: +24 -18 lines
Diff to previous 1.82
Fixed some XHTML violations and formatting glitches in the documentation generator.
Tue Jan 9 01:49:57 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.81: +38 -13 lines
Diff to previous 1.81
Added methods to make it easier to reload text search indexes.
Wed Dec 20 20:03:25 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.80: +4 -1 lines
Diff to previous 1.80
Fixed a bug that caused an error attempting to load the text search index.
Thu Nov 30 23:04:01 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.79: +1 -1 lines
Diff to previous 1.79
Fixed keyword searcher to make quoted strings required rather than optional.
Wed Nov 29 20:29:53 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.78: +55 -0 lines
Diff to previous 1.78
Fixed a bug in the delete methods.
Tue Nov 28 01:02:42 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.77: +249 -34 lines
Diff to previous 1.77
Added some methods to support the new attribute system.
Mon Nov 20 05:53:02 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.76: +6 -5 lines
Diff to previous 1.76
Wed Nov 15 12:08:26 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.75: +17 -5 lines
Diff to previous 1.75
Modified the DeleteValue method to allow for deleting all values of a specified field.
Thu Nov 9 21:21:49 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.74: +205 -27 lines
Diff to previous 1.74
Added support for indexes on text fields. Changed the index names to make them shorter. Added the ability to list all the secondary fields (which in the attribute database lists all the attribute keys. Enabled underscore as an alternative to hyphen in field names.
Fri Nov 3 16:49:44 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.73: +73 -2 lines
Diff to previous 1.73
Fixed some comments. Added tracing. Created new method for finding secondary indexes in the XML.
Fri Nov 3 00:33:26 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.72: +404 -552 lines
Diff to previous 1.72
Removed the never-implemented data generation stuff. Added support for special field attributes. Added support for methods that manipulate the XML.
Mon Oct 16 07:44:41 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.71: +7 -2 lines
Diff to previous 1.71
Added support for full text searches.
Sat Oct 14 18:08:12 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.70: +42 -1 lines
Diff to previous 1.70
Made keyword cleaning a virtual method that can be overridden.
Fri Oct 13 21:45:11 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.69: +386 -185 lines
Diff to previous 1.69
Fri Sep 29 15:06:17 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.68: +55 -0 lines
Diff to previous 1.68
Added a method for finding all represented values of a field.
Tue Sep 19 00:12:21 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.67: +2 -1 lines
Diff to previous 1.67
Fixed a comment.
Fri Jul 14 01:36:29 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.66: +11 -16 lines
Diff to previous 1.66
Removed unique-key support from "SortNeeded" since it doesn't work anyway.
Thu Jul 13 04:53:54 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.65: +4 -0 lines
Diff to previous 1.65
Fixed a bug in the table row counter.
Tue Jul 11 06:10:41 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.64: +0 -2 lines
Diff to previous 1.64
Removed the flush_tables command from the load process.
Mon Jul 10 10:04:41 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.63: +1 -1 lines
Diff to previous 1.63
Maybe this one will work.
Mon Jul 10 09:46:38 2006 UTC (13 years, 8 months ago) by parrello
Diff to previous 1.62
The specification of the field separator got goofy.
Mon Jul 10 09:42:34 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.61: +4 -2 lines
Diff to previous 1.61
Fixed a bug in the sort analyzer.
Mon Jul 10 09:05:17 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.60: +2 -0 lines
Diff to previous 1.60
Added tracing.
Sun Jul 9 21:16:12 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.59: +93 -22 lines
Diff to previous 1.59
Fri Jul 7 00:24:50 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.58: +1 -6 lines
Diff to previous 1.58
Wed Jun 28 22:22:42 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.57: +2 -0 lines
Diff to previous 1.57
Fixed to flush the tables after a MySQL table load.
Sun Jun 25 18:02:04 2006 UTC (13 years, 9 months ago) by parrello
Diff to previous 1.56
Fixed a comment.
Sun Jun 25 02:36:35 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.55: +1 -1 lines
Diff to previous 1.55
Fixed a comment.
Sat Jun 24 23:49:10 2006 UTC (13 years, 9 months ago) by parrello
Diff to previous 1.54
Moved "Exists" method from the Sprout object.
Sat Jun 24 15:55:37 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.53: +1 -0 lines
Diff to previous 1.53
Added more tracing to GetAll.
Fri Jun 23 23:04:55 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.52: +1 -1 lines
Diff to previous 1.52
Fri Jun 23 23:03:40 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.51: +1 -1 lines
Diff to previous 1.51
Fri Jun 23 22:53:08 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.50: +63 -0 lines
Diff to previous 1.50
Added a method for inserting new values into secondary relations.
Wed Jun 21 03:38:36 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.49: +2 -3 lines
Diff to previous 1.49
Fixed a bug in the ParseLine method.
Wed Jun 21 03:36:03 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.48: +1 -0 lines
Diff to previous 1.48
Added some tracing.
Wed Jun 21 03:12:20 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.47: +92 -0 lines
Diff to previous 1.47
Added some helper methods for data mining.
Sun Jun 18 05:14:56 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.46: +12 -2 lines
Diff to previous 1.46
Upgraded "GetCount" so that it can count relationship records as well as entity records.
Thu Jun 8 19:42:06 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.45: +34 -1 lines
Diff to previous 1.45
Added a method to compute a digested key.
Tue Jun 6 05:05:15 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.44: +484 -232 lines
Diff to previous 1.44
Modified interface for Sprout compatability. Added a method to return a count of records in a table. Split ShowMetaData into a method that writes a full web page and another that returns the page contents.
Sat May 27 02:02:28 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.43: +6 -0 lines
Diff to previous 1.43
Added support for shorter string keys.
Mon May 15 20:01:35 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.42: +2 -1 lines
Diff to previous 1.42
Fixed a bug in the SortNeeded method.
Wed Apr 19 03:34:15 2006 UTC (13 years, 11 months ago) by parrello
Changes since 1.41: +93 -0 lines
Diff to previous 1.41
Wed Mar 29 20:51:37 2006 UTC (14 years ago) by parrello
Changes since 1.40: +3 -3 lines
Diff to previous 1.40
Cleaned up some trace messages.
Wed Mar 29 20:03:05 2006 UTC (14 years ago) by parrello
Changes since 1.39: +3 -0 lines
Diff to previous 1.39
Added some trace messages.
Sun Mar 26 17:24:55 2006 UTC (14 years ago) by parrello
Changes since 1.38: +119 -31 lines
Diff to previous 1.38
Enhanced to enable objects to appear more than once in a single Get call.
Fri Mar 17 22:02:03 2006 UTC (14 years ago) by parrello
Changes since 1.37: +91 -30 lines
Diff to previous 1.37
Added a method for retrieving the field names that are useful when crossing a relationship.
Mon Jan 30 04:04:32 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.36: +3 -6 lines
Diff to previous 1.36
Fixed the Delete method to account for the database-dependent syntax.
Mon Jan 30 03:46:34 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.35: +3 -3 lines
Diff to previous 1.35
Fixed some bugs in the Delete method.
Sat Jan 28 09:57:43 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.34: +2 -4 lines
Diff to previous 1.34
Sat Jan 28 09:54:12 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.33: +5 -0 lines
Diff to previous 1.33
Sat Jan 28 09:36:47 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.32: +54 -53 lines
Diff to previous 1.32
Bug fixes to the delete method.
Sat Jan 28 08:58:53 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.31: +167 -0 lines
Diff to previous 1.31
Added a method for deleting objects.
Thu Jan 19 09:28:11 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.30: +56 -1 lines
Diff to previous 1.30
Added a method to validate proposed field contents.
Wed Jan 11 19:39:03 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.29: +22 -13 lines
Diff to previous 1.29
Changed to use the LIMIT feature to limit rows during queries.
Fri Jan 6 20:34:19 2006 UTC (14 years, 2 months ago) by parrello
Diff to previous 1.28
Prettied a line of code.
Thu Oct 20 09:31:02 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.27
Removed bogus "records" value from the statistics generated by a table load.
Tue Oct 18 06:52:35 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.26: +2 -3 lines
Diff to previous 1.26
Enhanced tracing for debugging of database queries.
Tue Oct 18 06:47:46 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.25: +1 -0 lines
Diff to previous 1.25
Enhanced tracing.
Thu Oct 13 01:16:47 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.24: +0 -4 lines
Diff to previous 1.24
Turned off transactioning, which was causing problems.
Wed Oct 12 02:56:04 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.23: +9 -2 lines
Diff to previous 1.23
Fixed the bug that was causing the spruious AutoCommit warning.
Changed to confess with an error if an error occurs creating an index.
Thu Sep 15 01:46:56 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.22: +13 -37 lines
Diff to previous 1.22
Changed LoadTables and CreateTables to use the GetTableNames method.
Wed Sep 14 09:56:58 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.21: +6 -3 lines
Diff to previous 1.21
Fixed misleading trace messages.
Tue Sep 13 18:32:02 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.20: +8 -8 lines
Diff to previous 1.20
Tuned some trace messages.
Sun Sep 11 17:02:33 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.19: +30 -60 lines
Diff to previous 1.19
Changed to load tables in a single pass.
Fri Sep 9 14:50:58 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.18: +9 -1 lines
Diff to previous 1.18
Sun Aug 14 23:32:08 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.17: +89 -38 lines
Diff to previous 1.17
Wed Jul 27 20:00:00 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.16: +10 -10 lines
Changed the trace level on some error messages.
Tue Jun 28 23:51:06 2005 UTC (14 years, 9 months ago) by olson
Need to vacuum outside the transaction.
Tue Jun 28 21:33:47 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.14: +1 -0 lines
Added a trace message that identifies the XML file used.
Mon Jun 27 15:41:24 2005 UTC (14 years, 9 months ago) by olson
Careful, "use packagename" is case sensitive on non-mac and non-windows.
Fri Jun 24 21:44:54 2005 UTC (14 years, 9 months ago) by parrello
Changed to analyze tables for performance data after loading.
Fri Jun 24 18:31:52 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.11: +8 -4 lines
Change to make the TO index unique for one-to-many relationships.
Thu Jun 23 21:24:49 2005 UTC (14 years, 9 months ago) by overbeek
finally
Wed Jun 22 21:29:28 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.9: +1498 -1489 lines
Replaced tabs with spaces for device-independent indenting.
Fixed some of the POD documentation.
Thu Jun 16 19:08:59 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.8: +26 -11 lines
Changed to detect and handle an improper number of fields during a table load.
Thu Jun 9 19:06:55 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.7: +228 -3 lines
Thu May 5 03:14:03 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.6: +88 -3 lines
Wed May 4 03:24:43 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.5: +202 -25 lines
Tue Apr 5 05:17:01 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.4: +10 -5 lines
Fri Feb 25 18:41:45 2005 UTC (15 years, 1 month ago) by parrello
Changes since 1.3: +21 -38 lines
no message
Wed Jan 26 22:26:09 2005 UTC (15 years, 2 months ago) by parrello
no message
Tue Jan 25 01:00:20 2005 UTC (15 years, 2 months ago) by parrello
Changes since 1.1: +19 -14 lines
no message
Sun Jan 23 16:12:29 2005 UTC (15 years, 2 months ago) by parrello
no message
