[Bio] / Sprout / DeleteGenomes.pl Repository:
Log of /Sprout/DeleteGenomes.pl
Fri Nov 8 18:43:35 2013 UTC (5 years, 11 months ago) by parrello
Changes since 1.6: +4 -2 lines
Minor fix to allow blank lines in genome ID file.
Fri Nov 8 18:42:26 2013 UTC (5 years, 11 months ago) by parrello
Changes since 1.5: +25 -3 lines
Added genome ID input file.
Fri Sep 13 18:54:12 2013 UTC (6 years, 1 month ago) by parrello
Fixed bug in delete call.
Fri Sep 13 18:06:14 2013 UTC (6 years, 1 month ago) by parrello
Changes since 1.3: +5 -6 lines
Fixed to work for Sapling.
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_release_2008_09_29
Removed obsolete use clauses.
Tue Oct 3 02:48:59 2006 UTC (13 years ago) by parrello
Fixed default trace level.
Sat Jan 28 08:58:07 2006 UTC (13 years, 8 months ago) by parrello
Diff to selected 1.5
Added as a utility for deleting Sprout genomes.
