[Bio] / Sprout / DBConvert.pl Repository:
Log of /Sprout/DBConvert.pl
Tue Feb 5 05:47:32 2008 UTC (11 years, 9 months ago) by parrello
Removed obsolete use clauses.
Mon Jul 16 19:55:07 2007 UTC (12 years, 4 months ago) by parrello
Converted to use the latest version of PPO.
Fri Apr 27 22:21:00 2007 UTC (12 years, 6 months ago) by parrello
Diff to selected 1.3
New script for converting ERDB database definitions to PPO databases.
