[Bio] / Sprout / DBConvert.pl Repository:
Log of /Sprout/DBConvert.pl
Removed obsolete use clauses.
Mon Jul 16 19:55:07 2007 UTC (12 years, 3 months ago) by parrello
Converted to use the latest version of PPO.
Fri Apr 27 22:21:00 2007 UTC (12 years, 5 months ago) by parrello
New script for converting ERDB database definitions to PPO databases.
